Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Serg SP
У Navstara лучше получается. Жаль, он быстро удалил свой пост с фоткой своего изделия, чтобы предприимчивые китайцы не переняли хау ноу. С Гиратора пример берёт, тот тоже свои решения показывает, потом удаляет.
Wasiliy61
Уважаемые, кто подскажет? Бывает такой лак в балончиках, чтобы платы покрыть, и как он называется.
Jorg63
Акриловый защитный бесцветный лак подходит для покрытия плат. используют при покрытии кузовов авто. высокая механическая стойкость.
Lemm
Plastik 71 есть еще Полиуретановый - получше будет . или автолак прозрачный с автобазара .
RUS5610
Много раз пользовался авто лаком.Результат отличный.
Kalin Ivanov
Oleg1ma, у меня такой ферит ,и я хочу спросить тебя могу ли я использовать его для силовой транс для Косой Мост. это должно быть сделано зазор и как он делается.
Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла
И какая и ндуктивност есть на транс.Тр 2 (ш5х5) для плата управление?
oleg1ma
Можно применить, предварительно проверить калькулятором проницаемость, действительно ли это ферит.Зазор можно сделать двумя способами:пропилить на 2/3 толщины кольца алмазным диском толщиной 0.4-0.5мм или сломать. вставить прокладку и склеить.По индуктивности напиши по какой схеме(плате) делаеш и на чем?
Wasiliy61
Ребята, спасибо за подсказку, съездил купил акриловый авто лак.
Kalin Ivanov
Я делал по етой схема и плата.Нажмите для просмотра прикрепленного файла
Jorg63
Kalin Ivanov! Такого цвета ферритовые кольца только R50 использую в преобразователях напряжения мостового типа.Проницаемость около 2000 у них. думаю для косого пойдут. Это точно феррит,если по спецификации EPCOS то это N27 похоже. на частотах до 40 кгц работает нормально.
По совету Олега протестите все же на проницаемость для успокоения души! icon_biggrin.gif
Kalin Ivanov
спасиба, нужно только сделать зазор толщиной 0.4-0.5мм ! А как могу предварительно проверить калькулятором проницаемость?
Jorg63
у Олега есть формула,спросите у него.А принцип такой,мотаеться пробная обмотка и измеряеться ее индуктивность а далее по формуле получаеться проницаемость.
KT117
программа Мюкалк. Нажмите для просмотра прикрепленного файла
И сравнить по даташиту проницаемость с Епкосом №87 http://ferrite.ru/uploads/pdf/products/epc...oroids/r_63.pdf
Alexzav
а при необходимости что-либо перепаять на пролаченной плате то лак, не нужно растворять т.к. он выгорает без следа!!!
Kalin Ivanov
Олег1ма ,
Икакая и ндуктивност сетавая витка есть на транс.Тр 2 (ш5х5) для плата управление, для косой мост?
[/quote]
я навил L1 31w. ,L2 31w. , L3 15w. сетавая 126 витки. Напрежение на 5 и 8 pin на HCPL здес -26V.,ценер я ставил 9,1V а не 10V как на схема .Может ли так ?
индуктивност сетавая витка 1450мкГн
Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла может ли делаю на етой ферит здес такая индуктив. на 10 витки.
KT117
Цитата(Kalin Ivanov @ 9.10.2013, 19:14) *
Олег1ма ,
Лучше покажи осцилки на R36 и R37. С нулевой линией, что бы увидеть отрицательную и положительную часть сигнала. Как осцилки выглядят- можешь посмотреть тут http://forum.cxem.net/index.php?showtopic=...60#entry1510806
Если бы индуктометр мог показывать мкГн-было бы точнее. а так проницаемость около 2400 плюс-минус, что близко к проницаемости материала №87 . подходит для трансформатора.
владимирон
Цитата(oleg1ma @ 8.10.2013, 20:29) *
Быстренько вынимай потраха...... дождусь резюме потолога анатома скажет что в морг значит в морг . я надеюсь что это клиническая смерть и есть шанс на оживление
oleg1ma
Цитата(Kalin Ivanov @ 9.10.2013, 20:14) *
Олег1ма ,
Индуктивность тр-ра EF20-на фото, кольцо твое на тр-тор не пойдет - это распыленное железо, подойдет на дросель.
Kalin Ivanov
Спасиба олег1ма , кольцо будет использовать его для дросел.А зазор нужен или нет ?
шумный
Приветствую всех ваятелей сварных инверторов!
Имеется трансформатор на сердечнике E70 материал N87, первичная обмотка 14витков, вторичная 5витков, собран без зазора. Частота 47,7кГц, заполнение 0,452
Появился вопрос: подходит ли трансформатор для работы в инверторе(косой мост) или будет насыщение?
RadioГубитель
зазор 0,1мм
oleg1ma
Нет не нужен.
шумный
Цитата(RadioГубитель @ 10.10.2013, 13:26) *
зазор 0,1мм
Спасибо за ответ, но трансформатор есть как есть, могу играть только частотой.
Вопрос с поста 18444 актуален.
Serg SP
ПМСМ, частоту придётся поднять на 15-20% от той, что была. Иначе будет насыщение магнитопровода. Либо предпринять принудительное перемагничивание сердешного.
Basill
Тогда однозначно только эксперимент.
Собираем калькулятор Лысого с ЛАТРом, и смотрим загиб - появляется или нет. Или используем имеющийся бармалейник, сделав для UC3845 цепочку регулировки длительности импульса на ХХ. Выставляем сначала минимальную длительность, на управе без подачи силы, затем подаем силу и смотрим, появляется ли загиб при достижении максимальной длительности при выбранном Кзап. Появляется загиб - увеличиваем частоту, и снова повтjряем эксперимент, начиная с минимальной длительности (или минимальной напруги ЛАТРа при фиксированной максимальной длительности на ХХ). Попутно смотрим/щупаем нагрев феррита при работе в течение определенного времени (соблюдая электробезопасность).
matlah
Добрый день или вечер всем. Тему читаю давно. Решил себе сделать Бармалея 165. Уже всё собрал и начал тестировать. Частота 30 кГц, К зап 043. Силовый транс собрал из 4 компонентов ТВС. Обмоткы намотав 21виток первички и 7 виков вторички. Но вопрос у меня к вам, почему свистит силовый транс. Где то читал что нужно увеличить сопротивление 1.3К на 1.5К. Свист не пропал. От сижу и ломаю голову чего не так, и как устранить етот свист. Платки я взял у Nextora.
шумный
Всем спасибо за ответы, все понятно.
RadioГубитель
Поет под нагрузкой али без?
Wasiliy61
Свист во всём диапазоне задатчика?
matlah
Транс без нагрузки, даже диодов не ставил. Свист происходит колы Резистор на минимуме.
nikon
Поставьте диоды и смотрите сигнал на выходе, я подозреваю на минимуме у вас уменьшается заполнение, подстраивается резисторами в обвязке переменника, или же пропуски импульсов, тут придется копать глубже.
Wasiliy61
Поиграйся с обвязкой переменного резистора, а в первом аппарате в добавок кажется ещё поменял 33к на36 или 39к- точно не помню, свист убрал.
aog1996
Транс без нагрузки... Свист происходит колы Резистор на минимуме.
Та же картинка. И не первый год. Работе совершенно не мешает. А когда замешкался в какую сторону крутить резистор, свист даже выручает.
Kalin Ivanov
Oleg1ma ,вот мое фото по липин, скажи осцилограми правилни ли ,я получил Кзап -0,43. Нажмите для просмотра прикрепленного файла
soud
А оптику нежелательно ставить на панельки!
владимирон
стоит и работает оптика на панельках
Wasiliy61
Нажмите для просмотра прикрепленного файлаЗатвор нихнего 5мкс 5в.дел. Нажмите для просмотра прикрепленного файлаЗатвор верхнего 5мкс.5в.дел.
Нажмите для просмотра прикрепленного файлаЭ.К. нижнего 5мкс 100в. Нажмите для просмотра прикрепленного файлаЭК.вегхнего 5мкс. 100в.
Нажмите для просмотра прикрепленного файлаНа обратном диоде 50в.
Осциллограммы с моего крайнего Бармалея, может чуть искажения- делитель самодельный.
oleg1ma
Правильно, частота 43кГц, заполнение 0.43%
Kalin Ivanov
soud
Вот сколько простоит и сколько проработает это вопрос. Ведь как правило аппараты хранятся сараях , гаражах.
truevoxdei
Парни, подскажите, ежели не трудно, сколько мотать на кольце epcos R63? 15/5 или 18/6 или 21/7 или 30/10 ? Пропил (пилил 0.5 мм. диском мини алмазным) в кольце на 2/3 толщины. Понятное дело, что чем меньше, тем легче и быстрее намотать. Частота 50 кгц.
oleg1ma
Цитата(truevoxdei @ 12.10.2013, 20:51) *
на кольце epcos R63? 30/10
В самый раз.
truevoxdei
Цитата(oleg1ma @ 13.10.2013, 1:32) *
В самый раз.
Благодарю. И ещё тогда вопросик. Первичку в два слоя если уложу или за сечением не гнаться?
nikon
Провод 1,6мм укладываю в две жилы в 1 слой.
владимирон
ну это вопрос свой берегу как зеницу ока
tranzistor3102
а что его беречь? им надо работать!
Wasiliy61
Так и работать можно по разному, можно и на дожде бросить, а вообще инвертор не любит грязи.
tranzistor3102
http://www.youtube.com/watch?v=Rwn0a9rb-pY
Павел(Sp)
Вот, после долгой и продолжительной борьбы с вдохновением, недра моей импровизированой лаборатории извергли часть Бармалея, без генетических изменений и ментальных мутаций.
Заработало сразу без странных звуков и ядовитых выхлопов.
Представляю на суд(так и хочется сказать--божий..) осциллограммы.
На мой взгляд вроде так ничего вроде противоприродного , но я могу смотреть на это дело взглядом искаженным в порыве любви к моему детищу.
Знаю что я уже поднадоел, тем более с моими темпами...Но честное слово это почти последний раз.
1) на 6й ноге шим
2) на входе драйверов
3) на затворах ключей(подпаял чтоб была входная емкость навешана,+300в еще пока не готово)
Замеры с включеным делителем на 10
DANTIST
Цитата(Павел(Sp) @ 13.10.2013, 20:09) *
1) на 6й ноге шим
Годится. Ваяй дальше. Надоесть не бойся. До "Коли" тебе еще чуть больше, чем от Мадрида до Пекина.
