Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
golub
Чем морду делали? Надписи имел ввиду.
RUN1
Лазером можно фрезером но лазером качественней наверняка у вас в городе есть рекламные агенства где имеются такие станки морду рисовал дома на компе в кореле а потом со своим файлом к ним 15мин и морда готова со всеми отверстиями надписями и тд.... глубина надписей 0.2-0.3mm можно больше по желанию материал тоже
Александр_М
golub А схемку Вашего апарата можно?Тот что плату выкладывали ATX_TOP.lay
Д713
э-э,это рубликов за писят в хохло-харьковском мсполнении...
смешно,но это жисть торговцев ничем...
golub
Типпо пашутил? Или пива опять тёплое?
Тогда с какого бока это.
Д713
кабельщик,добил своего псевдо-гуся,ужо и расчет получил,скажем не менее 100$.
как у Вас продвигается дело?
убедили "клиента",шо ему кроме Вас никто не нужен?
golub
Никакие мы не производители. Ты хоть сам- то видел производителя, хотяб метров с десяти, тонна мяса и яйца по колени. А мы так, техники, типо юнные.
Д713
golub
Да, коллега, вижу Вас обидели.
Как и меня вчера. Вызывают срочно в офис, в чём дело- комп пошабашил. Давайте, говорю пылесос, четыре года, однако, на полу под столом стоит. Принесли. Я без задней мысли, чвырк кнопку, и в системник, он в обратку, а бугалтерша рядом. Ну ладно я в походном, типа в колхозном, а она при параде. Ну в общем, пришлось во всё оставшееся время её стирать. Но своё я всёт выбил.
Д713
а Вас не обидели фактом ползания на "полусогнутых" по офисам?
golub
Цитата(golub @ 30.7.2009, 18:12) *
Как и меня вчера.
Не могу избавиться от этой херни на фронте, под нагрузкой вообще юла.
Д713
golub
Прошу заметить, не я это предложил.
Д713
в чем вопрос?
golub
В погоде, не рискнул с пионэрами ехать, ани уже через неделю будут возвращатся, да тут ещё кот приболел.
Д713
не юлите,с первой оказией давайте прям к нам,вместе ст котом,или с облезшими котами..
DANTIST
Добрый всем вечер!
Вопрос ко всем, кто пользовался фоторезистом. Действительно ли так просто с ним работать, как объясняют торговцы на рынке? Я имею ввиду фоторезист в баллончиках.
Эта утюжная технология уже доканала. Маленькие платы, типа 50х60 получаются без проблем. Сегодня делал большую 170х270, половина дорожек отпадает. Плата подготовлена, я считаю, идеально. И Тайтом и Фери тер. Блистит как у кота яйца. Отпечаток сделал на классной, глянцевой бумаге. Слой тонера жирный, чернючий (специально ездил на фирму по изготовлению печатной продукции). А оно не держится, хоть убей. Два листа извел и бросил.
Кто, чего может посоветовать? Заранее благодарен.
Если кому интересно, могу приложить плату. На ней все, кроме драйверов. Они как раз на маленьких платах, которые уже и протравились.
Levs
Не в той ветке написал. Ровно на две ветки ниже нужно было.
Фоторезист тоже сам наносится не будет, руку набить нужно, хотя у меня с ним легко пошло,
а вот с плёночным не получилось - не держится.
Плату после очистки попробуй на минутку-пол в хлорное бросить, чтобы розовая стала,
как у кота яйца это лишнее, нам зеркальный блеск не нужен, наоборот - матовость некоторая нужна
для лучшего сцепления.
Две ветки ниже почитай.
Д713
пользую,совместно с Алексеем Николаевичем хитачевский
Цитата(DANTIST @ 30.7.2009, 21:00) *
Добрый всем вечер!
катаем,совместно с Алексеем Николаевичем хитачевский пленочный фоторезист,капризный собака,но ничего лучше пока не нашли..
DANTIST
Спасибо за направление. Почитал. Нужно попробовать. Хотя желание попробовать было и раньше.
Плату я до зеркального блеска не чищу , конечно, но и в железо не бросаю перед копированием.
Я думаю, а может качество переноса зависит от принтера. Маленькие платы я делал на одном, большую на другом. И бумага разная, хотя обе глянцевые. Но разной толщины.
Попробую еще раз. Осталась еще одна бумажная копия.
RUN1
Добрый всем вечер!
От принтера зависит очень многое у новых принтеров система нанесения тонера другая чем у первых лазерных принтеров все магазины оббегал хотел новый принтер взять для этих дел но не чего подходящего не нашол пришлось брать старый б\у,использую факсовую бумагу для печати предварительно ее прогладив и вперед сверху на факсовую бумагу ложу простую писчею и глажу писчая бумага служит как идикатор начала желтеть(равномерно по всей плате) так стоп хватит гладить плата 200х300 получается нормально а про мелкие вообще молчу
Александр_М
DANTIST А платку перед самым наложением бумаги с рисунком ацетончиком протереть? Очень помогает.
Печатаем на любом лазернике (XEROX SAMSUNG)На тонкой фотобумаге для струйника, плату чистим мелкой наждачкой протираем ацетоном и сразу прикладываем бумагу. через 2 листа обыкновенной бумаги гладим. даем остыть(обычно под небольшим грузом пара-тройка книг) в в воду отделять бумагу.
Результат вполне приемлемый.
golub
К сожалению, нет схемы. Разрисован только БУ. Сила- классика жанра, снабберы RC- 10 om на 4n7 на ключах, и 10 om на 10n на диодах, дежурка на 224 ТОРе по шииту, драйверы-кольт, блокировка по силе МКР, транс Е65 15х5, 50 кгц. ATX_TOP рисовалась под размер двух корпусов от БП АТХ, в дальнейшем размер по вертикали увеличен на 5 мм из за применения радиаторов от 939 сокета. При срабатывании термика, или по силе или диодам- блокируется задание по входу интегратора и засвечивается красный св/диод.Нажмите для просмотра прикрепленного файла
при распаковке не забыть .txt убрать из расширения.
кабельщик
DANTIST, поясню... Подобная проблема с большими платами при использовании ЛУТ есть не только у вас, и причина вовсе не в принтере или бумаге. На самом деле причина в утюге (его размере). Просто нарушается принцип равномерного прогрева бутербода бумага-текстолит. От поочередного прогрева на разных участках бумагу немного коробит, тонер начинает отслаиваться , не успев прилипнуть.
Нужен утюг XXXL-размера, еще лучше гладильный пресс (из советской прачечной) icon_biggrin.gif
golub
И всё одно, ровно не получитса. Тем более если учесть, что БФ, которым приклеена фольга, долго терпеть издевательств не будет.
Александр_М
Две красных перемычки в правой нижней части платызто что будет?
golub
Если я правильно понял вопрос, то эти две косых соединяют последовательно термики, один из которых на дальнем от вентиля ключе, второй на диодах.
Wiew
А кто-нибудь пробовал лут на новых принтерах типа: LaserJet P1005, LaserJet P1006, LBP3010? Хочу принтер, а "классики" уже не найти icon_sad.gif
RUN1
LaserJet 1005 Вот вот он и есть со своей новой эконом технологией хрен что получится на нем слой супер тонкий на полном черном нет полной заливки слегка видна бумага . Может пойти LaserJet 6L но эт тоже под вопросом хотя он из старых самсунг 1430 эт супер без вопросов про ксероксы точно не знаю говорят технология нанесения порошка у них подходит для наших целей но это надо смотреть при покупки на пробном листе мож что и удасца подобрать из новых принтеров но я пока не нашол
Д713
если стоят сурьезные задачи,то от принтеров лучше отказаться,вернее печатать на них только фотошаблон.
азы-
http://www.radiokot.ru/lab/hardwork/06/
Ewgeniy_RZ6LYE
платы печатаю на Samsung ML-2015 на полной заливке и глянцевой бумаге из журналов получается нормально, пользуюсь года 2, технология ЛУТ.
golub
азы-
Ну блин какие задачи, раз- два плату катануть.
Д713
не скажите,хорошая печать дорогого стоит,это Вам не по пол-часа ретушировкой заниматься,а потом с матами лудить нелудимое по площадям (есть в принтерах такая экономная гадость-печатать сеткой по площади).
технология "пленки" проста-самое главное накатать ее без пузырей,а дальше дело техники,засвечиваю 1ваттным ультрафиолетовым светодиодом,минут 10-15 (на качестве не отражается).
mosnik
Работаю на 6L, проблем не было, любого размера плату делаю. После протирки заготовки ацетоном обязательно чистой тряпочкой удалить с поверхности налет, который образуется после испарения ацетона. Утюг небольшой, советский еще. Стараюсь всю поверхность носиком утюга больше налегать, до тех пора пока через бумагу не будет просматриваться рисунок. Бумага глянцевая, мелованая. А отстает порошок от неполного прогрева.
Александр_М
Опробованы многие XEROX PHASER 31.. Результатом довольны
Шас XEROX и SAMSUNG как родные братья, кроме надписей на морде ничем не отличаються.
RUN1
Ну вот с принтарами малеха разобрались парни эт радует!
А вот фоторезистом где он водится не подскажите парни? хочится попробовать!
С уважением
Д713
"пленка" водится на радиорынках,продается погонными метрами (сантиметрами icon_biggrin.gif ).
ширина 250мм обычно,это я про HITACHI.
последняя цена была 4$ за метр,от отечественного производителя наверно дешевле.
RUN1
ширина 250мм,обычно,это я про HITACHI.
С уважением
4-5 баксов вполне приемлимо если качество будет как напечатанный шаблон на томже лазернике или струйнике без всяких манипуляций с утюгом и лишним разогревом фальгированного текстолита что не желательно icon_smile.gif
yjriy
На рынакх пленки нет давно. а фирмы- поставщики ее по 42 метра в рулоне продают на 3000 грн. В Днепре есть по листам 1000*300. 27 грн-цена вопроса и жидкий по 124 грн за 200мл. Всеравно дешевле чем на космодроме на полтильник
Д713
На рынакх пленки нет давно..
ну не знаю,у нас в Симферополе все есть (почти как в греции icon_biggrin.gif ),причем широко пользуют этот материал любители химгравировки.
насчет жидкого ничего не могу сказать,но как и в любом деле наверняка есть тонкости.
RUN1
Цитата(Д713 @ 31.7.2009, 14:55) *
ну не знаю,у нас в Симферополе все есть,причем широко пользуют этот материал любители химгравировки.
Да, везет вам! Сейчас позвонил в магазин можно сказать в единственный в своем роде у них только жидкий имеется пленка кончилась но думаю с жидким не сложней будет чем с пленкой я надеюсь
Д713
можете сразу готовить "центробежку",без нее качества не получите.
Camelot
центробежка вроде девайс нехитрый, как мне кажется. выдрал из старого флоппаря двигатель, у него в качестве ротора большой железный блин, маленько поколдовать с обвязкой микрухи на плате и обороты будут регулироваться в широком диапазоне, далее дело техники, крепим плату с двигателем гденить посреди картонной коробки, типа как от материнской платы, на железный блин - ротор лепим три кусочка двусторонней липучки, лепим на липучку плату, подаём 12 вольт и вперёд на мины. сам тока собираюсь так поступить, это мысленный проэкт но двигатель от флоппаря уже выдран и ждёт своего времени. у меня всё затормозилось когда посыльный из радиомагаза сказал что у них нет транспарента, а плёнку дорого покупать. вот думаю может маслом бумагу мазать, вроде тоже прозрачной становится. никто не пробовал.
ЗЫ.
лазерник у меня HP LaserJet 1020 за два года превратился в дерьмо, очень пачкает бумагу, в лайауте при печати смещаю плату вниз листа, тогда в начале он отпечатывает дерьмо от предыдущей платы а потом собственно плату. когда только купил отпечатывал длинные предложения мелким шрифтом на платах идеально, и травилось всё на ура, теперь большие полигоны надо проходить поверх тонера нитроэмалью. ещё прикол в том что дорожки 0.3 - 0.6 получаются идеально а вот с 1 - 2 уже проблемы, сначала печатал на глянцевой мелованной. теперь на ней нормально не получается, печатаю на глянцевых рекламных буклетах, особенно хорошо выходит на рекламе от местного провайдера "Balticom" icon_smile.gif
ЗЗЫ.
оффтоп
maxx
Всем привет. Camelot попробуй как и говорил Кабельщик сделать дорожки 1-2 мм. на платке 3*2 см., чем больше плата и меньше утюг... . Вроде Мультик описывал способ с толстой книжкой, у меня всё прекрасно(более-менее) получается-равномерный нагрев, прижим(зависит от веса человека icon_smile.gif ) и т.д. .
Wiew
оно то так! да вот купить эти шедевры прошлих лет, теперь не реально icon_sad.gif
пробовал через тоненькую обычную белую бумагу, плотность не скажу какая , но меньше 80, только засветку немного продлить надо (экспериментально подбирать, ничем типа транспарента не брызгал), можно еще на кальке попробовать.
yjriy
А кто мешает разобрать и полностью вычистить хорошенько картридж, а если сам не хошь-- отдай на чистку и заправку. 1020- машинка супер
Так вроде нет проблем с прозрачной как для лазерника, так и для струйника. Цена вопроса- 3 грн за А4
petr0757
Добыл кольца К130х80х40, уже писал, но феррит какой то ВЧ, при 17 витках
всего 70 мкгн. Трансформатор однозначно на наших частотах не получится,
а как насчет дросселя ?
RUN1
Парни не подскажите чем можно заменить этого зверя может кто сталкивался мож на мосфет?Нажмите для просмотра прикрепленного файла
С уважением.
Есть у меня чтото похожее проницаемость 400 написано сероватое крупное зерно думаю тоже дроссель на них замутить главное чтобы не насыщался
golub
Может, если по управлению, т.е. по затвору пройдёт. По горелым матерям надо поискать, в районе дежурного источника, только там корпус поболе будет, что-то типа sot123.
RUN1
golub благодарю как раз тоже об этом думал материнок валом дохлых есть вот только ихние ироглифы замудренные на мордах транзисторов типа 1P, 7E дешифратор нужен или расшефратор icon_smile.gif
