Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Jorg63
При правильно расчитанном трансе коэфицент заполнения хоть 0,42 хоть 0,46 не имеет никакого значения для живучести прямохода. Если с трансом проблемно то при любом заполнении будет косяк.О правильности намотки транса можно судить по осцилограмме на К-Э нижнего ключа.Какая должна быть осцилограмма расписано вдоль и поперек.
oleg1ma свои дешевые сверкальники прямоходы делат на 494 микре и у нее по умолчанию от экземпляра к экземпляру заполнеие от 0,42 до 0,46 и никакой кореккции по 4 ноге микры не наблюдаю подстройки под заветные к примеру 0,42 коэф заполнения.
oleg1ma
Цитата(igorka @ 24.8.2013, 8:58) *
Но вот выставлять его по аналоговому осциллографу ( у которого самого погрешность 10% ) как то не самое точное дело Мультиметры с этой функцией стоят непомерно дорого ,
Для отладки , купить лучше недорогой оцил-приставку у которого на борту куча измерительный приборов, сам пользуюсь не один год таким, обратите внимание на набор функций.
igorka
Ну , дело хозяйское.Каждому свое , бюджетный вариант , мне понравился , наши частоты перекрывает.А на счет правильного транса , если витки не лезут?Все это дело компромиссав , так что сдесь не совсем уместно , правильно-неправильно.
DANTIST
Да, igorka, ну ты и написал! Похоже, когда все дети в школе грамматику изучали, ты за углом бычки докуривал.
igorka
Просто на остановки стоял , и по быстрому намалякал.
oleg1ma
Понравился конструктив аппарата из этого ролика, решил склепать, что-то похожее, с такими же размерами.По ходу сборки буду выкладывать фото.Это основная плата(210х100) и платка управы(39х34).
vladim60
oleg1ma на ето смотрели http://www.mastercity.ru/showthread.php?t=179761&page=17
oleg1ma
Да это все видел, но схемы то нет, будет аля телвин.Процесс пошел.
oleg1ma
Продолжение процесса.
soud
Цитата(Jorg63 @ 21.8.2013, 11:07) *
что то смотрю никто не желает использовать вместо ТГРа дрова на IR2110 в бармалеях! многих знакомых бармалеелюбов на 2110 дрова перевел,проблем нет абсолютно. дешево и сердито.
Можно глянуть на вашу схему подключения?
aog1996
Олег, как получаются такие аккуратные плоские дырочки? Не уж то надфилем?
сулейман
Всех приветствую!В нашем "бравом" icon_biggrin.gif деле для жевучести устройства имеет значение max Коэф.зап.Поэтому для прямоходов , его следует ограничить на уровне примерно на уровне 0,42- 0,44.Но вот выставлять его по аналоговому осциллографу ( у которого самого погрешность 10% ) как то не самое точное дело , да и не самое удобное.По этому поводу я сделал не хитрый прибор для измерения Коэф.зап. импульса.Мультиметры с этой функцией стоят непомерно дорого , а эту штучку осилит здесь каждый!Короче вот Измеритель.rar , хоть я и не автор , но автору благодарность!
Интересный прибор. Только не пугайте народ 10%погрешности, может он и соврет при измерении абсолютной длительности импульса, но при определении соотношения импульс/пауза ничего критичного
pansim1
Вот ето самое важное.
igorka
1.Интересный прибор.
2.Только не пугайте народ 10%погрешности.
1.Действительно , приборчик не плох , во всяком случае мне нравится.
2.Та то я так , для "красного словца" , конечно это мелочи на которые не стоит обращать внимание.
VOVA 555
сулейман Да интересныв прибор . Немоглибы выложить фото фюзов каторые у вас в девайсе.
oleg1ma
Цитата(aog1996 @ 26.8.2013, 9:26) *
Не уж то надфилем?
Если имеете в виду прорези под ебуки, то все делается обычной сверлилкой.Сверлится ряд отверстий, как можно ближе один к одному, потом сверлилку поворачиваю под 45-60 градусов и с небольшим нажимом делаю из нее фрезер.Вот продолжение процесса.
igorka
Я думаю правильнее было бы у меня спросить writer.gif icon_biggrin.gif .По вашему вопросу смею предположить что вы собрали устройство без кварцевого резонатора , а индикатор блымает.Приношу свои извинения , устройство собирал давно и забыл что в статье очепятка icon_redface.gif вспомнил лишь тогда когда прочитал ваш пост !
Вот правильная таблица № 2 Нажмите для просмотра прикрепленного файла
VOVA 555
igorka извените невнимательно смотрел.
Павел(Sp)
Цитата(Nikolay1 @ 19.8.2013, 14:49) *
как говорил один мудрец: на этом форуме кроме ников ничто не меняется. Тот же Павел СП со своими вечными духовно политическими проблемами (кстати вещайся друг мой вещайся...) Калин иванов уже достали одни и те же вопросами. К нехватку тут еще "ТнттнтттнТ" шка проснулся после долгих снов
Уважаемый.
Одна из 1000001 причин по которым я не посещаю форумы гомосексуалистов , форумы о балете и форумы по благотворительности в центральной Африке -мне не интересно.(хоть и отношусь с терпимостью)
(извиняюсь,но не догоню никак аллегорическое значение слова ,,вещайся'' ,звучит как угроза...)
Товарищи,господа и панове!( кажыся никого не обидел).
Здравствуйте,я вернулся.
Как прийду в сознание -задвину какое нибудь ,,духоно-политическое '' ессе о добре и зле.
Олег....ну хоть бы царапину какую гвоздиком с краю,а то аж не верится шо оно самодельное...круто одним словом.
slavyann
Олег, а почаму такое хитрое включение мостов ?
igorka
Все нормально.Лучше скажите как у вас дела с прибором.
KT117
Паралельное
Вы ведь делали ММА на Атмеге??
VOVA 555
igorka icon_biggrin.gif Пока никак комплектующие есть а принтера нет . На поеду днях напичатаю в магазине на глянцевой бумаге тогда буду делать .
Павел(Sp) Олег....ну хоть бы царапину какую гвоздиком с краю,а то аж не верится шо оно самодельное...круто одним словом.
icon_biggrin.gif Он фанат своего дела (в хорошем смысле етого слова ) да плюс терпимый к новичкам .
Abama
oleg1ma. Я так понял в новом сварочниге флая не будет? а защиту от заниженного питания как нибудь реолизовал?
принципиалка есть ? поглядеть было-бы любопытно
VOVA 555
oleg1ma
А сверло победитовое или из р6м5 ?
oleg1ma
Да простое сверло из хоз. магазина, дорогие не беру, лучше сломаю 5шт. чем одно.
Вот по этой схемке будет.
VOVA 555
oleg1ma
Почему дорогие совсем нет . У нас на радиорынке мужик продает победитовые от 0.8 до 2.5 мм в диаметре по цене 3 или 4 гр за шт . Но правда хрупкие очень но режущую держат хорошо . Правда толька у него есть больше нигде нет . Хвостовик у них в неколька раз больше за режущую кромку .
oleg1ma
Простые беру по 80-90 копеек.
VOVA 555
Ну каждому свае.
SchVePs
Для подобного вида работ использую зубопротезные боры, цилиндрические (б.у)
oleg1ma
Все по ТГР учел первички 20в, вторички 30витков на колечке 22х13.7х 12.5мм из материала Т38.
Abama
Да так думаю нормально будет, и фронты по круче станут. Желаю удачи!!!
Павел(Sp)
[quote name='VOVA 555' date='26.8.2013, 19:27' post='30236
[/quote]
Они не победитовые,победит это пресованый поршковый материал,обычно серого цвета( если конечно мы говорим сверлах белого цвета,или золотистого.золотистые со спецпокрытием,не уверен что это так,но тут его называют титановым покрытием).
Ладно,не вдаюсь в тонкости...просто из опыта ( тут этот материал называют быстрая сталь или быстрорез) не любит высокой скорости,даже об ПВХ тупится,а на малойто если поднапрячся то и подшипник можно проточить по внешнему диаметру..
aog1996
Цитата(oleg1ma @ 26.8.2013, 13:16) *
Если имеете в виду прорези под ебуки, ...
Признаюсь: первое предположение было что это робота хитрого пробойника. А оно вон как.. Выходит тренироваться надо..
Про Телвин: все вроде понятно. Зачем Т3.2 - не понятно.
Jorg63
Обмотка Т3.2 для питания схемы в штатном режиме. стартовый запуск идет от выпрямителя силы. разве не обратили вы ,что нет классического блока питания?
VOVA 555
Павел(Sp) Они не победитовые,победит это пресованый поршковый материал,обычно серого цвета( если конечно мы говорим сверлах белого цвета,или золотистого.золотистые со спецпокрытием,не уверен что это так,но тут его называют титановым покрытием).
Все вышеперечисленое мне извесно и не по наслышке ( когдато несколько лет работал слесарем инструментальщиком ) . Вы меня немнога непоняли . Вот о таких я вел речь справава победит слева р ка
oleg1ma
Cегодня запустил сварочник, час гонял на ХХ , вернее на лампочке, все холодное, тр-тор около 40градусов, такие-же и резисторы в снаберах обоих.Осталось мотануть дроссель и буду пытать на баласте.Вот какой вышел конструктив, второй ветродуй пока неставил.
Rysikkk
Качество сборки как всегда на высоте icon_wink.gif .
DANTIST
То, что сделано аккуратно - это факт.
Я смотрю, Павел, ты там одичал в своей Испании. Вот фабричное производство. Хотя, и это не образец для подражания. Есть, наверняка и краще.
Здесь, кстати и Телвин есть.
Вот когда будем делать что-то подобное, тогда и будем их царапать, чтобы отличить от самопала. Впрочем, платы подобного качества народ уже с успехом заказывает. Конечно, они стоят определенных денег. Аппарат, конечно, получится не бюджетный.
Павел(Sp)
Олег.
Я конечно не претендую даже на степень эскулапа от силовой электроники,но в моем понимании конденсатору может быть жарковато в процессе работы,я планирую конденсаторы поставить подальше от ключей,на разумной дистанции конечно, и както страшновато от вида двух толстых проводов над платой,..это силовые шины на ключи и транс?Ну да ладно, мое мнение-мнение человека со знаниями на уровне плинтуса в этой области..
Вова,фотка размыта очень,то что с утолщенным хвостовиком очень похоже на фотке на фрезу из тогоже быстрореза,ну ладно, это не принзипиально,Вы как инструментасльщик несомненно знаете режимы работы режущего инструмента.
Да я чего...просто в себя толком еще не пришел,в этот раз умудрился уложить 3400км в 51час, это с заправками,остановками по нужде природной ну и поспать тож надо было, а то в день перед отъездом у тестя картошку копали,так шо на трек я как говорится вышел не в лучшей форме..
Кстати купил за 60 украинских долларов одну штукень,думаю шо до бармалея как дроссель выходной можно прицепить,короче выходной дроссель с какогото милитаристического агрегата,намотан на узком п-образном феррите медной фольгой сантиметров 5 шириной и 0,5мм по толщине будет.
Позжей фотку покажу,как БП изваяю...
Вот, теперь сижу после каникул практику делаю,тсть перед выпускным по Бармалею БП импульсный из лампочки ваяю, нужно около 10А 13,5-14в..
oleg1ma
Цитата(Павел(Sp) @ 27.8.2013, 21:52) *
Олег.
Конденсаторам будет холодно, я ведь написал, что второй ветродуй пока неустановлен, а он, как раз и будет обдувать радиаторы ключей и конденсаторы и диодные мосты в том числе.По поводу длинны проводов, то представте, что ключи - это розетка, а тр-тор - вилка с лампочкой, до полуметра, никаких проблем.
KT117
icon_smile.gif Смотрю, и здесь все пугаются вида проводов
oleg1ma
Просто Гонза давно свои шедевры невыкладывал, вот там то естть чему поучится по поводу компоновки. icon_biggrin.gif
Павел(Sp)
кратко и вразумительно,спасиба
ingener99
И правильно делают, близость проводов с ВЧ током в десятки А к слаботочным цепям управления затворами ничего хорошего не обещает
на месте автора проложил бы под этими проводами изолированные экраны из фольги
Wasiliy61
oleg1ma, а силовой транс намотан сначала полностью первичка, потом вторичка, да?
oleg1ma
Именно так.
Wasiliy61
Это что за БП у тебя будет, из энергосберегайки что-ли.
VOVA 555
Павел(Sp) Вы как инструментасльщик несомненно знаете режимы работы режущего инструмента.
Для сверл от 1 до 3 нужны обороты от 2000 до 3000 соответствено с водяным охлаждением
Wasiliy61
Цитата(oleg1ma @ 28.8.2013, 2:55) *
Именно так.
Понятно, а первичка во сколько слоёв поместилась
