Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
golub
http://www.electrik.org/forum/index.php?ac...st&id=21361
не корысти и рекламы ради, ещё два года назад, по мотивам Толяна.
Пенсионер2014
Ув.Golub спасибо! Очень интересно.
avlozitski
Цитата(golub @ 8.1.2015, 0:17) *
по мотивам Толяна.
golub, спасибо, а какую микросхемку применяли в качестве тригера Шмитта на термоконтроль?
golub
4093
kotofei
А почему все экономят на копеечных 1-2 амперном мостике и высоковольтном электролите 22-47 мкф, запитывая "дежурку" от основных банок? Сами ж себя наказываете...
Wasiliy61
А чем наказываем-то. Если дежурка на ТОРике запускается от 80 вольт, то она будет стабильно до этого предела-пока на силовых литах будет оставаться это напряжение, а там уже и на страшно ключи без присмотра, т.е. без контроля оставить.
golub
Цитата(Пенсионер2014 @ 8.1.2015, 18:26) *
где можно прочитать подробнее про обвязку UC3845,
по обвязке почитайте на Толяновской ветке, здесь переделано под ТТ и добавлена ОС по напряжению на двух полевиках и двух биполярах.
Serega30
Доброго времени суток! Насколько достоверные значения Imax, которые показывает Sprint-Layout ? Например, при толщине меди 0,035 мм и ширине дорожки 9 мм - Imax 27,7А.
DANTIST
Цитата(KT117 @ 9.1.2015, 18:09) *
А где это в Sprint-Layout есть такая фича? Что то раньше не встречался с таким расчетом
Серега, посмотри вот это. А заодно и КТ117.
KT117
Velgosh
На счет силовых ключей - чем можно заменить IRGP4063DPBF, ну кроме IRG4PC50U? И можно ли на IRF740 пробивать зажигать дугу или они только для настройки?
oleg1ma
Для настройки.
kotofei
Вполне вариант снизить количество витков вторички (увеличив тем самым рабочий ток) и при этом не потерять поджигаемость. Картинки взяты из этой же ветки (в районе 450-500 страницы), но тогда обсуждения как такового не было, все свелось к "глядите как я могу".
На мой взгляд оч. рациональное использование далеко не безграничной мощности инвертора.
Небольшое пояснение: ЕЕ55 там не просто так стоит, очевидно рабочая частота порядка 100 кГц. Соответственно для "традиционного" 35 кГц Бармалейника нужно будет подобрать емкость резонансного контура (там где написано 0,68 мкФ поставить 1,5-1,8 мкФ) или пошаманить с индуктивностями если боитесь возросшего до 150В х.хода.
Положение переключателя "2" (TIG) как и дополнительная вторичная обмотка большинству сборщиков не пригодится.
Детальки все копеечные или вообще условно бесплатные icon_smile.gif - сердечники от АТХ или дохлых CRT мониторов, диоды - кламперы строчника оттуда же и т.д. - фантазия подскажет. У кого уже собран косой - попробуйте эту приблуду плз
PS как сменить тип подписки на эту тему? (хочу "сообщать раз в неделю" или что-нить вроде этого)
TSL2
Цитата(kotofei @ 10.1.2015, 10:12) *
Да, интересная, если это действительно позволит увеличить коэффициент трансформации СТ.
Похожая примочка стала неотъемлемой частью резонансника Негуляева. И вот там, если я не ошибаюсь, и говорили
о её минусах. Типа портит качество дуги (дуга трещит).
Интересно бы это дело симульнуть, или кто может пользовал эту хрень?
kleverbig
Пользовал, но именно в резонанснике, хотя она и многим не нравится, и дуга не трещит - а посвистывает. Это скорее всего для ленивых, не надо болгарки, поджиг превосходный даже на ржавом металле. А вот какой шов получится на чистой деталюхе и со ржавчиной это другой вопрос.
nikon
Снижение напряжения в дуге не есть гут, некоторые виды тугоплавких электродов при этом не сгорают полностью а осыпаются раскалившись до красна. Я в своих аппаратах наоборот виток добавляю во вторичку.
kotofei
Да пусть шкворчит, свистит - хоть пукает! Какая разница?! Примочку можно отключабельной сделать. Или даже регулируемой. Или (omg!) модулированой таймером (типа 2-3 раза в секунду) или микроконтроллером согласно непонятно какого анализа ржавости поверхности. Кстати!
По поводу пористости - наверно стоит прикинуть, какое тепло несет "основная" дуга и какое - такой поджигатор. Несоизмеримые величины! Соотв. и флуктуации сварочной ванны не будут заметными.
KSV
Где то в начале дебрей, человек, помню с Нижнего Новгорода мотал доп обмотку не толстым проводом и через диод и резюк типа зелёный огурец подключал к выходу. Поджиг улучшался, но резюк грелся, нужно было довольно мощный ставить.
Serega30
Можно и конденсатор присобачить на место резюка.
oleg1ma
Нельзя, дросель можно.
Dr. Санчес
Здравствуйте , коллеги !
Возник вопросец по выпрямительным мостикам , я стараюсь применять получше , чтобы не было мучительно больно ...
Раньше покупал GBPC3508W производства Vishay ( такие , как на фото слева ) , теперь попались мосты ( на фото справа ) , судя по логотипу производства General Semiconductors . Смущает то , что первая компания вроде как поглотила вторую , и их мосты должны быть со знаком V , но откуда эти 3508 могут быть с логотипом GS ? Либо раннего выпуска ( до слияния ) или просто левак ? Мож кто встречался с такими изделиями ?
DANTIST
Раньше покупал GBPC3508W производства Vishay ( такие , как на фото слева ) , теперь попались мосты ( на фото справа ) , судя по логотипу производства General Semiconductors . Смущает то , что первая компания вроде как поглотила вторую , и их мосты должны быть со знаком V , но откуда эти 3508 могут быть с логотипом GS ? Либо раннего выпуска ( до слияния ) или просто левак ? Мож кто встречался с такими изделиями?
Я в последнее время тоже ставлю такие мосты. Пока проблем не было. Справа - это 3-х фазный. Остался после баха. Пробило один диод (ножка откушена). Остальные целые. Вот и думаю, что с ним делать. В принципе, живой мост. Но после аварии.
На том, который поставил на замену, было написано тоже самое, но на наклейке, как у тебя. Продавац сказал, что все нормально. Во всяком случае, уже практически год отработал.
Dr. Санчес
Понятно , всем спасибо ! Буду пробовать мостики GS на практике . В принципе , те которые от Vishay , к ним вопросов нет - проверены эксплуатацией ( на 140а - 1 мост ) , видел такие и в Торус-200 - неслышал чтоб они горели . Мосты от GS пока не проверял , по этому и решил спрость , мож кто что ...
ingener99
немцы ставят такие в аппараты до 140А (тиг 170А)
Практически не выходят из строя.
Wasiliy61
Вот, доделал сегодня силовую часть, там конечно мелочи остались-подложить по бумажке в транс.Что-то я растянул на этот раз, почти два месяца- даже ещё не пробывал. Вот такая наверно бяка получилась.
Чёт интернет переклинил, едва загрузил.
Сергей_74
Красиво получилось!
Смотрю всё клепаете и клепаете.. Солите их?
oleg1ma
Похоже на то, управа может и распаятся от дросселя.
Wasiliy61
Олег, ты думаешь дроссель так будет температурить, да там и расстояние 1 см, Может ты имел ввиду наводки на управу полезут.
oleg1ma
Возле зазора в тр-торе и шпильки металические раскаляются, а здесь какое-то олово icon_biggrin.gifТакой дросель - это ведь электромагнит в чистом виде, сифонит он не по детски, при таких токах.
Pavel.I
А где драйвер находится, или та платка с боку, тогда вопрос, проводки на затворы не длиноваты. Раньше не где такого не видел, что-то новое.И дроссель рядом, тоже не очень-то хорошо.
RadioГубитель
Фиксировал транс косого (с зазором) сплошной медной лентой шириною 2 см. 4 года сверкальник отпахал на старой работе (и пашет пока). И ниче там не раскалялося
Wasiliy61
Проводки по 8см, это не так уж много, вот дросселёк не на месте, но он уже впаян- легче открутит управу, и поместит её на радиаторы.
Так может и здесь дроссель ни чего не расплавит, хотя управа получается в магнитном поле.
ingener99
Если сверху сердечника, то лента оказывается расположенной вдоль линий поля и нагреваться не будет. Но управу с торца дроселя ставить опасно из-за возможных наводок. Думается, достаточно будет закрыть плату управы экраном. Если и будет греться, то не сильно - дроссель не транс.
Wasiliy61
Да я уж тоже подумал сделать экран между управой и дросселем, а то что проводки по 8см думаю не сильно страшно.
DANTIST
Василий, да не переживай ты раньше времени. Включишь, посмотришь, посчупаешь...
Wasiliy61
Николай, это ведь твоя машинка, как она себя ведёт.
oleg1ma
Медь немагнитный материал, в отличии от стали.
OlegarX-RUS
Ну тогда и обмотки надо делать из стали icon_smile.gif Если следовать твоей логике
DANTIST
Василий, я узнал ее. Это моя машинка. Но она сделана довольно давно, передана в надежные руки и больше я ее не видел. Надеюсь, что работает. Иначе уже бы позвонили.
oleg1ma
Можеш следовать, раз своей нет.
OlegarX-RUS
Олег я тебе про то что в переменном магнитном поле охрен какой материал всё ровно будет действовать ЭДС.
https://www.youtube.com/watch?v=sV-8fcfzrp0
витя
OlegarX-RUS." Ну тогда и обмотки надо делать из стали. Если следовать твоей логике." Ответьте тогда на вопрос, почему на индукционной плитке алюминиевая сковорода не греется?
Pavel.I
27, 0... Мгц
ingener99
Потому, что удельное сопротивление алюминия намного меньше, чем у нержавеющей стали, и вихревые токи его греют намного слабее.
OlegarX-RUS
27, 0... Мгц
Wasiliy61
Так на счёт драйверов, и проводков- которые всего по 8см, мароки ни какой нет. Даже в заводских аппаратах встречаетя такое соединение,аж сантиметров по 15, а тут какие-то 8см-это ерунда. А вот дросселёк конечно не удачно, дело всё в том, что изначально планировался дроссель на кольце, было-бы не так страшно-так как это бублик, но мне колечки не привезли, и я поэтому переиграл, ну и вот результат.
DANTIST
Цитата(Wasiliy61 @ 14.1.2015, 8:20) *
...колечки не привезли, и я поэтому переиграл, ну и вот результат.
Василий, не заморачивайся. Все будет класс!
Wasiliy61
Спасибо Николай, я пока взял маленький тайм-аут -перевариваю всё в голове, думаю может стоит дроссель чуть развернуть, или отодвинуть управу-это позволяет, тогда расстояние меж дросселем и управой получится 3,5 см- может этого будет достаточно.
oleg1ma
Нестоит, а может?А вот это попробуйте icon_biggrin.gif , найдите колечко, как и планировали.
DANTIST
Цитата(Wasiliy61 @ 14.1.2015, 10:13) *
... я пока взял маленький тайм-аут -перевариваю всё в голове, думаю может стоит дроссель чуть развернуть, или отодвинуть управу-это позволяет, тогда расстояние меж дросселем и управой получится 3,5 см- может этого будет достаточно.
Василий, включи, послушай. Будут проблемы - будешь думать. А сейчас это напоминает мужика, который украл рельсу, приволок домой и представлял, как к нему придут с обыском. icon_biggrin.gif
