Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Serega30
Цитата(KT117 @ 22.4.2014, 16:44) *
А если принять Ктр=2.8 (для слабой сети) ?
При уменьшении Ктр растет ток КЗ со всеми последствиями.
KT117
А с чего это он должен расти? icon_smile.gif Интересная теория-хотелось бы узнать подробности.
Serega30
Почему теория?icon_biggrin.gif По крайней мере у меня так было. Я тут недавно уже выкладывал
Vs55
Цитата(Павел(Sp) @ 22.4.2014, 13:13) *
Кто поключал осциллятор к инвертору?
Подключен к одному бармалейнику. Параллельно каждому диоду варистор на 150 В и на выходе перед ВВ трансом варистор на 120В и параллельно резистор 2к7 5W. Только у нас искра пробивала на воздухе примерно на 0,5 см, в аргоне немного больше.
Павел(Sp)
Спасибо.
Правда параллельно диодам нет возможности ставить что-то.На входных клемах прилепил пленочников почти 17мкф,резиторы 2х10к впослед 2х ватных и параллельно клемам(видел такое в одном месте) и варистор на 130в.ПальцАми трогал вроде не щипает,осцил почти сразу отрубается(USB),правда за 3-4 секунды успевает запечатлить что то, выбросов бидимых таких нет,вроде воль9-10..
Serega30
при падении напряжения в сети и поддержании тока на выходе стабильным, ток через ключи будет увеличиваться. А значит и греться будут сильнее.
То есть, больше шансов взорвать ключи если инвертор питать сильно заниженым напряжением при отслеживании тока по вторичке СТ ?
tranzistor3102
Цитата(Serega30 @ 23.4.2014, 21:59) *
То есть, больше шансов взорвать ключи при просадке сети до уровня, при котором ключи будут работать на максимальном токе, если ток ключей не будет ограничиваться еще чем-то на безопасном для них уровне.
все равно при напряжении в сети(140-150v)производить нормальную сварку металла практически невозможно зачем изобретать какие-то ограничители? icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Serega30
Можно, но только если уменьшить Ктр.
shevcha
Я подключал, при кондере на выходе обязательно диоды на 400 вольтей. У меня кондер блокировочный был на 2 мкф и в паралель 1,5КЕ350. Пользовался с год даже на штучных электродах, понравился поджиг, особенно на УОНИ и им подобных, пока кнопка на держателе не сломалась...
tranzistor3102
Serega30
Цитата(tranzistor3102 @ 24.4.2014, 15:53) *
Это я лишнее ляпнул не подумав как следуетicon_biggrin.gif. Вы уж извините, сейчас исправлю.
tranzistor3102
Dominys
Ща модератор мне надает.
DANTIST
Да, Винница - это ж не Славянск, Донецк и даже не Одесса.
Павел(Sp)
DANTIST,
A скажи как будь ласка, как бармалея в тиг превратить???
Вот лежит он у меня по кускам собранный, что надо переиначить, шоб с него тиг получился.
А то вот заморочка с осциллятором получилась.Там на выходе(инветрор Praxair) в режиме тиг 100в, искра осциллятора зажигает бумагу(уже зажигает).
Главная дуга на тиге не хочет зажигаться, если чиркнуть електродом инвертор уходит в глухую защиту по температуре,вернее загорается перегрев,хотя токового по сути нет.Поэтому решил его больше не мучать,пусть живет..А поскольку я нахожусь на пол-пути решил у умных людей совета поспросить, а то сам ничего нинкак не нарою на эту тему.
DANTIST
Цитата(Павел(Sp) @ 2.5.2014, 20:44) *
DANTIST,
Главная дуга на тиге не хочет зажигаться, если чиркнуть електродом инвертор уходит в глухую защиту по температуре,вернее загорается перегрев,хотя токового по сути нет.Поэтому решил его больше не мучать,пусть живет..А поскольку я нахожусь на пол-пути решил у умных людей совета поспросить, а то сам ничего ни как не нарою на эту тему.
Павел, ТИГ я не собирал. Была мысль, но пока нет. А Бармалея в ТИГ превратить практически без проблем. Я надеюсь, схема у тебя есть. Если нет, показываю. Не помню чья, Кабельщика,вроде, или кого-то другого могучего.
Где-то у меня был небольшой интересный материал по ТИГу. Не могу сейчас с ходу найти. Найду - сброшу. Не общее описание сварки не плавящимся электродом в среде инертного газа, а именно по работе инвертора в разных режимах.
А зачем тебе там, собственно, осциллятор? Это ж не ТИГ АС. Осциллятор нужен если не хочешь касаться детали для поджига дуги. Например, чтобы не сместить детали друг относительно друга. Да и дроссель такой могучий по выходу нужен для сварки тонких деталей.
Павел(Sp)
Спасибо.
Если я правильно понял, то нужно только кнопку где ,,пуск,, написано и оптрон которым она управляет..еще в этой схеме на выходе оптрон стоит, он со стабилитроном вместе рубит шим при достижении -+65в.Дроссель только не пойму, как то жидко выглядит 2,24мм вдвое,хватит на 100а?Фотка красивая..
В принципе тот же бармалей только чуток разного понацепляно, типа осциллятора,кстати гдето я много читал и люди его очень хвалили,цепляли его на инвертор..
А осциллятор именно нужен чтоб дугу бесконтактно запалить.Делаем одну штуковину частенько, варитьь надо в токарном станке зажат фланец и труба подперта ,кажись это пиноль нзывают.. шов надо начинать чем подальше назад ну, практичаски вслепую, чем меньше стыков,тем лучче,ну и как начнеш вслепую тыкать.. если рука верна с утра и не дрожжит-нормально, а если ...труба дюйм с четвертю, нержавейка 1мм стенка такого понатыкаеш бывает,короче 2 детали и меняй електрод, бо он превращается в дубину,только без сучков..
Кстати я себе на ебее принтер лазерный приобрел,б/у но 12 месяцев гарантия,мисцева инет-лавченка ,HP1160,чуть со смеxy не помер...за 2,50Е..
Wasiliy61
Всех с праздником ПОБЕДЫ.
Serg SP
С Днём Победы! Жить в мире - большое счастье, так говорил неоднократно мне мой дед Климов Сергей Петрович, прошедший три войны.
Желаю всем мирного неба над головой!
С уважением, Сергей.
Сергей_74
Поддерживаю, с днем Победы!!! Мира всем, всем кто хочет мирно жить!
Фашизм не пройдет!!!
RUS5610
С Днем Победы!!! Гитлер ЧМО!!!
RadioГубитель
Всех с Днем Великой Победы!!!
Vs55
Всех с Днем Победы! Мирного неба над головой!
OlegarX-RUS
Спасибо Деду за победу!!!
Павел(Sp)
Какой формы сигнал должен быть на 3й ноге UCки- пила?а то у меня вообще никакого нет...на обмотке тт есть,а после диода нет.Все менял,..диоды,стабилитрон,сам тт ставил..какие только попадались из коробочки..ничего не помагает,все заканчивается на резисторе 1,5ома каимито иголочками..
RadioГубитель
На третьем пилы быть не должно, сюда ТТ в гости ходит...
Павел(Sp)
Не,ну это я понимаю...а есть каой нибудь способ проверить работу части схемы ТТ-3я нога?
Vs55
Как и фазировку ТТ. Если она правильна и импульсы схлапываются, хначит все работает.
Павел(Sp)
мда, цеплял обратную связь с 8й на 3ю, резистивный делитель..все рабботает как в книге..
а когда подключен тт со всей трахомудией для формирования импульса то на резисторе 1.5Е при 310 питания какаято дрожжащая муть.пробовал как на`писано в одном мануале делать кз на выходе при 40в чтоб видеть схлопывание импульса то вот это получилось..
правда без дросселя... исчо не подключал его пока.
tranzistor3102
[quote name='Павел(Sp)' post='339844' date='11.5.2014, 23:21']мда, цеплял обратную связь с 8й на 3ю, резистивный делитель..все рабботает как в книге..
Павел(Sp) поставь вместо резистора 1.5Е резистор 8-10е будет виднее схлопывание импульсов icon_biggrin.gif
Serega30
Во многих вариантах намотки силового транса вторичку мотают большим сечением чем предполагает Ктр. Например: 4мм2 и 16мм2 при Ктр=3. С чем это связано?
DANTIST
Serega, это связано с тем, что у человека была такая шина. Запас, как известно, ... Ну ты понял.
Хотя, смотря для каких целей ты делаешь аппарат. Если с целью сбыта и обогащения, то лучше мотать сечение впритык. Потратишь меньше - заработаешь больше.
Есть умельцы, мотающие первичку проводом мм 3 кв (не китайцы) и ниче. И 4-кой шмалят, аж шуба заворачивается. icon_biggrin.gif
Serega30
Думаю, тут надо ставить вопрос ''раком'':D Что будет происходить при нехватке сечения провода обмотки?: а)обмотка будет нагреватся, но будет отдавать нужный ток; б)обмотка не сможет обеспечить нужный ток
DANTIST
Serega, ну нихрена не понятно, чего ты так озаботился этим вопросом. Почитай хотя бы Энциклопедию юных сурков.
Расскажи первоисточник твоих проблем. У тебя нет шины нужного сечения?
Чем сильнее греется проводник, тем меньше току он будет пропускать. И наоборот, при температуре абсолютного нуля он становится сверхпроводником.
Wasiliy61
'Serega30 привет, ты где потерялся- что-то тебя долго здесь не было. Серёга, при малом сечении- естественно будет нагрев, но и есть ещё что-то, как ты думаешь- если посадить сварку на тонкую проводку, то просадка сети всегда будет больше, чем сварка на хорошем проводе- вывод...?
Serega30
Цитата(KT117 @ 12.5.2014, 13:54) *
как ведет себя проволочка предохранителя при разных токах через нее? А при КЗ в сетевом проводе и дубовой защите на подстанции-какой максимальный ток пройдет по проводам? icon_biggrin.gif
1)не греется, греется, сгораетicon_biggrin.gif 2)максимальный, тут два варианта: а)либо защита после счетчика не такая дубовая как на ТП и она сработает; б)либо мгновенное сгорание шнура/проводки в доме.
Про сурков потом поговоримicon_biggrin.gif Есть медная шина 11мм2. Если принять плотность тока 10А/мм2-снять с нее будет можно соответственно 110А. Как-то не впечетляет...
oleg1ma
Jorg63
Снимешь ты со своей шины и 150 ампер при хорошей сети не напрягаясь.Все равно по заполнению тока коэффициент 0,44 примерно,можешь считать что реально твоя шинка работает с плотностью тока 5а/мм2
Насчет предохранителей то использую автомобильные,вроде проблем нет с ними. Конечно использовать качественные а не аси-сяйский фуфел icon_biggrin.gif
Serega30
Ага, приветicon_biggrin.gif я не терялся, форум чего-то затих. Да, ибо нефиг цеплять тонкую проводку на сварочник. Шнур питания, пропускающий 50гц и обмотка, работающая на 50кГц немножко разные вещи.
Wasiliy61
Серёга, вещи-то разные, но ток и сечение всё равно связанны.
Serega30
Цитата(oleg1ma @ 12.5.2014, 17:04) *
Спасибо, Олег, за хороший советicon_biggrin.gif Остается только придумать как запихнуть 5 витков 22мм2/33мм2/44мм2 в окно Е65...
у меня стоит медная проволочка 12мм, диаметром 0,8-1мм. 125А вых тока держит
oleg1ma
Вот и придумай, окно Е65 имеет площадь 540мм2, а площадь 5витков сечением 22мм2=всего 110мм2. icon_biggrin.gif
KT117
http://www.cqham.ru/fuse.htm
При диаметре 1мм медной проволочки в предохранителе-она сгорит при токе 80А. Если этот предохранитель у вас во вторичке-то 120А не выдержит. Если по первичке-то ключи сгорят первыми и спасут предохранитель icon_smile.gif
Jorg63
Цитата(Serega30 @ 12.5.2014, 18:55) *
Для Бармалея тебя хватит и одного комплекта Е65 за глаза.второй про запас icon_biggrin.gif ,можно и для вых. дросселя использовать
Serega30
Jorg63, это понятно.
Эл.литы-Предохр-Ключи. Диаметр точно не помню, вроде как 0,8мм
отдельная ветка
по моточным трансформаторам на
инверторы- ткните носом, пожалуста
KT117
отдельная ветка
Да леххко icon_smile.gif вот, первое что на глаза попалось на соседней ветке http://www.electrik.org/forum/index.php?showtopic=29492
Serega30
Цитата(KT117 @ 12.5.2014, 17:46) *
А чего вы людям мозг выпариваете?
Не выпариваю, просто решил немного форум оживить.
Павел(Sp)
спс за ответы всем.
новый вопрос..
почему в верхнем по схеме положении задатчика, не доводя процентов 15 до самого верхА,пропадает генерация на ХХ? (на 1й ноге 0,8в, на 2й 2,5в и вырубается..)
микруха TL3845
KT117
Цитата(Павел(Sp) @ 14.5.2014, 0:15) *
спс за ответы всем.
новый вопрос..
микруха TL3845
Верхнее положение-минимальный ток. Какой резистор на нагрузке ТТ стоит?
RUS5610
Надо немного поиграться резистором в обвязке руля,по моему тот что на 33ком,убавить его.
