Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
tnttnttnt
[quote name='UVM' date='10.6.2011, 11:42' post='188926']
Короткий транс на баласте будет работать великолепно, а вот на холостом ходу разорвёт хреновые кондёры и потом всё по цепочке.
Я думаю причина была не в трансе,делал три совершенно одинаковых транса 18\6 два комплекта ферритов Е65 Р3 частота 30кгц,два нормально трудятся с автоматами по питанию,а этот сделал через клавишник и предохранитель на заднюю стенку по плюс питания, шнурки получились длинноватые наверное из за этого.
Да и лампа даже намек не давала на накал на холостом ходу, а сеть почти 240в подстанция под боком.
И еще конденсатор все таки порвало под нагрузкой на боластнике, по этому и остановил испытания треск услышал.
Dr. Санчес
Цитата(РУС18 @ 9.6.2011, 20:20) *
приветствую форумчан! собираю 165. силовой из 6 комплектов ТВС, 18 витков пока что тонким проводком(проверял сколько мотать). частота 35кгц. заменил пару HFA15(снаберные) на 2 паралельных кд213 . остальное все так же. проверил ток намагничивания силового (1.4А) все осцилограмки в норме но греются размагничивающие диоды! за пару минут палец терпит. дольше держать не стал... боязно. это так и должно быть???
Рассеивание у транса велико , вот и греются размагничивающие диоды , например пробная обмотка намотана как придётся ( витки накиданы " в навал " , кольцами , бухтой и т.д. ) . Даже при подборе желательно керн на котором будет находиться обмотка , хотябы временно заизолировать и эту пробную обмотку намотать более ли менее равномерно .
213е зачем параллелить ? Ток у них для снаббера нормальный а вот по напряжению их надо бы последовательно включать , с выравнивающими резисторами .
aleksandr64
Цитата(UVM @ 10.6.2011, 15:50) *
Это если без зазора, и желательно половинки малость притереть (транс на ТВСах сплошной зазор icon_biggrin.gif ), а если зазорчик ввести то всякое может быть. Ждем что автор расскажет icon_smile.gif
А если с зазором, то тем более пойдёт.
РУС18
обмотка намотана аккуратно на текстолите 1 мм не в навал. 213 стоят по 2 штуки послед они стоят в цепи ключей ,а размагничивающие стоят нормальные HFA15TB60.один кондер стоит на 1 мкф СВВ21. трг намотан на комповском сердечнике Е28( по 23 витка на всех обмотках) зазора нет.
РУС18
213 не греются а вот размагничивающие греются
tnttnttnt
Ребята кто по подскажет, где собирают инверторы для аргонно-дуговой сварки?
UVM
в полуавтоматах
urdint
РУС18 , и я подтверждаю - 6 ТВСов на трансе отлично работают, 18/6 витков 32-33 кГц. в качестве зазора 1 слой бумажки от кассового чека.
АлексейС
Мужики привет!Посетила меня мысля сделать 165-го Бармалея на двух комплектах Е80,т.к. с Е65 очень много возни (окно маленькое,задолбаешься впихивать).Может кто делал?Сколько витков,какой зазор?Частота-30кГц.Заранее спасибо,с уважением.
Лопух
http://www.electrik.org/forum/index.php?s=...ost&p=42322
АлексейС
Спасибо за ссылку,очень полезно,но вопрос о зазоре остается открытым
Лопух
Цитата(АлексейС @ 14.6.2011, 13:18) *
... вопрос о зазоре остается открытым
Там же указано, где есть зазор, а где нет. Да и "калькулятор лысого" никто не отменял.
АлексейС
ОК,понял.Но,согласитесь,всегда намного приятнее и дешевле идти по кем-то протореной дорожке.Еще раз спасибо
K.AA.M
Посоветуйте пожалуйста колечко К20х12х6 2000НМ хватит 1шт для токового трансформатора? или ставить побольше есть ещо К31х18,5х9 2000НМ зарание спасибо
РУС18
попробовал с зазором.....греются размагничивающие еще быстрее.попробовал притереть половинки....все равно греются.
решил попробовать на другом материале. нашел кольцо размером 102х65х15(1) и 125х80х12(2 шт) на таких кто нибудь делал? сколько мотать? или калькулем Лысого искать ?мужики дайте совет ! а то жуть как доделать и поварить хочется
вот что еще подумал про феррит ТВС...может мне плохие попались? а то пишут работает ведь и на них???
СМК
РУС18,все бармалеевские сварочники делал на сердечниках ТВС (брал у знакомого в телеателье) - все работали нормально.Кстати,в трансе делал всегда зазор.Единственно,что трансы получаются большие,зато окно для намотки большое и продувается лучше.
ostap
http://www.electrik.org/forum/index.php?au...mp;showfile=360
возможно ето поможет - зазор по мере надобности
РУС18
попробовал заменить один HFA15tb60 на FR805. FR еле теплый после нескольких минут работы, а HFA горячий. надпись на hfa фрезерована а на fr краской. что за эфект?
при этом ток намагничивания 1.8А при зазоре 0.1мм
АлексейС
Спасибо за таблицу!Даже не знал что бывают Е110,128,160.Еще раз спасибо
РУС18
мужики а в качестве замены HFA15tb60 что в защите ключа стоят подойдет 6А10(Р600М) 6А 1000В по две штуки последовательно
spesso
Это вопрос, или утверждение? Зачем последовательно?
РУС18
Lemm
нет , это низкочастотный диод , для частот 50/60 Гц . можно набаянить вместо входного моста .
Зы: в ликбез бы вам , уважаемый .
РУС18
спасибо. буду знать
UVM
В даташите есть параметр измеряемый в наносекундах, обратите на него внимание.
именно
Серега 220
здарова мужики. настраиваю свое чудо (Б165) и возник вопрос . с такими осцилограммами на верхнем ключе аппарат будет жить?Нажмите для просмотра прикрепленного файла на затворе верхнего 5 В/дел 5
Нажмите для просмотра прикрепленного файла на КОЛ-эмитттер верхнего 5В/дел 5
осцилограмки на нижнем в норме
ключи пока стоят ирф 740
частота 33кГц с копейками
tnttnttnt
Цитата(Серега 220 @ 19.6.2011, 12:19) *
здарова мужики. настраиваю свое чудо (Б165) и возник вопрос . с такими осцилограммами на верхнем ключе аппарат будет жить? на затворе верхнего 5 В/дел 5
не не будет.
lapa
Цитата(tnttnttnt @ 19.6.2011, 12:59) *
не не будет.
Аргументы в студию! Я полагаю будет. Если помрет, то от других причин.
tnttnttnt
не красивые они!
EVDOGW
Привет всем! Подскажите как избавиться от свиста? Свист появился после замены ключей на более мощнее...
tnttnttnt
а что свистит?
UVM
Во вторичку ТГР виточков малость добавить и осцилограмма станет красивее!
Серега 220
fantom-2011
Нормальные. Утебя звон на осцилограммах от щупов. Смотри у тебя всплески что на затворах что на кол-эмимт. одинаковы. Про эти ньюансы уже писали. Это у тебя какой по счету Бармалей ? Или ты первый так долго собираешь ?
ROMAN 3
Серега 220,
я в сообшчение 10468 тоже задовал этот вопрос, такае-же ситуацыя, пробуи запитать инвертор от разделителиного трансформаторе у меня было 380/220В и сигнал боле мение красивее стал, то выводы толико от звон шчюпов, инвертор уже пол месяца трудится проблем нету.
RUS5610
Попробуй шнур щупа намотать кольцо фер. и на центральный щуп резюк припаяй ом на 100.говорят помогает.
Серега 220
нет не первый ...третий icon_smile.gif но на тех такого не было
RUS5610 колечко пробовал малость получше стало а вот резак не пробовал ставить( попробую)
ROMAN 3 буду тоже надеяться и верить icon_biggrin.gif что будет трудиться без сбоев
спасибо мужики за советы
serbun
Всем привет. Тут появилась проблемка при сборки аппарата- дроссель на двух сердечниках от больших строчников тупо невлазит в корпус. Я знаю вопрос заезженный до дыр уже но все же кто может подскажите плз количество витков и приблизительный зазор дросселя на е65 для макс тока 200а и частоты 35кГц шинка 22мм кв.
UVM
Лучше возьми транс железо ШЛ 20х30 (размер будет примерно как Е65) с зазором милиметров 5 и мотай сколько влезет. Или, если по длинне пройдёт, то на железе от дросселя (стержне из пластин) люминисцентных ламп витков 30-40. На самый крайний случай делают и без сердечника.
Lemm
в его случае
Цитата(serbun @ 21.6.2011, 23:24) *
и частоты 35кГц
придется частоту задрать вдвое , а без дросселя плохо будет .
UVM
Ну если аппарат под корпус и не влазит, то дроссель можно сделать выносным icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif !
serbun
кароче все понятно никто не мотал. от 6 до 10 витков и подбирать. А так хотелось время сэкономить.По поводу железа- я его принципиально не использую так как это всетаки инвертер и вес его должен быть как можно меньше.
UVM
На ШЛ очень неплохой дроссель, разница грамм 100
zato4nik
Дроссель 200А на сердечнике Е65 с нормальным зазором (около 3мм) можно сделать индуктивностью не более 4 мкГн, при 10мкГн - зазор около 6 мм- для этого сердечника перебор.Лучше использовать железо (распыленное, смесь -52) салатового с голубым цветом кольца размера Т 225- штуки 3 вместе сложить, или от трансформатора с зазором.У железа выше индукция насыщения раза в 3 поэтому сердечник будет меньше ферритового .
serbun
ogromnaja prosba- skagite skoko vitkov merjat ne4em.
UVM
На ШЛ сколько влезет, на стержне от дросселя ЛДС и "рогах" витков 18-20, про альсифер нискажу, не делал.
serbun
Уговорили- феррит это хорошо но в насыщение зараза легко вскакивает. На работе имеются дроссели от "инвертера" ист 125. Так вот там есть пара небольших в них гдето думаю 20*30 и есть. Главное чем его намотать есть шина 18кв есть прибл 20кв есть 25 и есть 32. Чем лудше всего? Или какое лудше сечение взять.
RUS5610
Мотай шинкой 18мм2.Поставишь под обдув ничего ему не будет.Конечно чем выше сечение тем лучше,но шинкой большего сечения тяжелее мотать.Наверное еще и в стеклотканевой изоляции? Прикидывай 1мм2-10ампер.
serbun
в стекле тоже есть но гадость редкая- сдирается оч легко и эта мелкая шелуха ведается в кожу, есть шинка гдето 20кв в нормальной изоляции ею и намотаю. Спасибо за ответ.
RUS5610
Лакотканью можно обмотать или бумажным скотчем.Потом пропитать и будет вещь!
