Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
oleg1ma
Цитата(vovaan @ 6.2.2012, 12:12) *
oleg1ma у меня к Вам вопрос по поводу Липенского . Включил плату управления без силовой платы , блок питания ,срабатывает защита,когда выключаешь на 180 вольт включается. Я так понимаю ,что при 180 В он работает. Где искать или что сделать ? КЗ. нет от отдельного БП, плата работает ,индикатор светится.
Бп в липинском с микрухой TNY 264 расчитан всего лиш на мощность 6 Вт, это нужно учитывать при выборе релюхи, запускается он прекрасно с 70-90 вольт.Измерьте сколько кушает току управа по 12 вольт току.Один раз почти также вел себя БП попутал местами диод BYV26 и P6KE200CA, поменял местами и все встало на свои места. Ну и есно фазировка тр-ра должна быть правильной иначе будет с трудом включатся, а как выключите и снова включите то не включится .
Gre-Kir
А никто не сталкивался с кольцами из феррита от блока розжига ксеноновой лампы в 20кВт? там был дроссель на 2 кольцах 150х100х10 мм на глаз? намотан в один слой проводом 10 кв мм.
может можно чтонибуть из них сотворить. а то цены дикие на феррит. могу и фото выложить
ГонZа
Приветствую всех на форуме.Viktor V,у меня сначала тоже не схлопывался импульс,и я поменял концы на ТТока и все хорошо.
Viktor V
Праветствую всех. Менял концы на ТТ, лечению не поддаеться, обвязку ТТ проверил, наверное надо менять UC3845. На четвертой ноге пила, на первой 2,3В на второй 2,5В.
Осцылограмма на 3 ноге
vovaan
Я забыл написать у меня стоит BYV36 , может поэтому он вкл при 180вольт ? A фазировку Я проверил генератором и стрелочником ,всё в порядке. Один раз попробовал поменять синфазность по первичке , пришлось менять МС , BYV36 - 2шт. и два по 100 Ом 5ВТ
oleg1ma
Может еще что забыли написать, гадать не умею, вообще-то если не отступать от схемы и тр-тор намотан правильно, БП заводится с пол оборота.Какая индуктивность первички?
Viktor V
Приветствую всех. Нужна подсказка, в каком диапазоне на 2 ноге UC3845 должно меняться напряжение при изменении задатчика тока.
ГонZа
Приветствую всех на форуме.Запускал сегодня аппарат от 220вольт на irg4pc50ud,но силовое питание подключал через тэн от чайника(на всякий пожарный).Замкнул выход на КЗ и амперметр показал где-то 50ампер(это на тэне 2квт).Немного подождал-вроде ничего не греется.Вопрос знатокам:у меня дроссель выходной индуктивность 55мкГн(шина 18мм2,15витков)-хватит или надо перематывать?С уважением Гонза.
oleg1ma
50а - на минимальном задатчике?И какое в это время было напряжение на входных электролитах?Дроссель пойдет.
ГонZа
50ампер на максимуме,но на входных электролитах напряжение упало с320вольт до180вольт при замкнутых проводах.По дросселю-спасибо за ответ.Ещё один вопрос:амперметр(голова)-2ампера,шунт-200ампер.Будут ли соответствовать показания амперметра(головки)- току,проходящему через шунт?С уважением Гонза
oleg1ma
Будут если шунт и головка на 75мв, гдето у тебя косяк при КЗ потребление небольшое и ток дожен быть намного больше.
vovaan
Oleg1ma спасибо за ответ. Я действительно перепутал BYV 26 с P6KE200. Плата сразу заработала. BYV36 тоже подходит.
шумный
Для Viktor V!
У меня при изменении задатчика тока напряжение на 2 ноге UC3845 было 2,495В, а на 1 ноге менялось от 1,76 до 4,26В. При питании пониженным напряжением ( сила от латра примерно 80 В переменки) при КЗ на выходе сварочника импульсы иногда не схлопываются, я для проверки увеличиваю нагрузочный резистор ТТ. Включать аппарат не убедившись в срабатывании токовой защиты это жесть.
Viktor V
Приветствую всех сваркостроителей.
Шумный спасибо за помощь, у меня показания практически совпадают.
Еще вопрос можно уменьшит ток КЗ добавлением 10 - 15 витков в транс ТТ.
oleg1ma
Что-бы уменьшить ток рабочий нужно отматывать витки с ТТ, ну а проще увеличить сопротивление отвечающее за мак. ток.
шумный
Для Viktor V!
Как написано в теме бармалея ток КЗ должен превышать установленный сварочный ток на 30-40А (его называют хвост КЗ т.е. разница между установленным сварочным током и током КЗ). ТТ и его нагрузочный резистор определяют сварочный ток. Хвост КЗ определяется задержкой сигнала от ТТ до 3 ноги UC3845 и постоянной времени цепочки R6C6. Хвост КЗ проверяю при мин. задатчика, т.к. при мах. задатчика сварочный ток может ограничиваться входной сетью а ток КЗ нет.
Viktor V
Всем спасибо за помощь, РТ ограничил на 150А КЗ буду уменшать.
oleg1ma
Может и не стоит этого делать для ММА сварки даже рекомендуют ток КЗ побольше, а для аппарата нормально сделанного ток КЗ даже в 300А неопасен.
ГонZа
Приветствую всех на форуме.У меня такая проблема:на работе аппарат варил и 3и4 электродом(А ВАРИТ ОН КЛАССНО!!!),замерял напругу в розетке ,там 212вольт,но работает.Привёз аппарат в гараж,подключил к розетке(там221вольт),начал крутить регулятор(даже не ткнул электродом),раздался хлопок и оба 50ud,ушли в мир иной.Может быть кто-то сталкивался или у кого-то была такая проблема,подскажите плиз.Опишу отступления от схемы:регулятор тока установлен на 10к;резистор от 3 ноги на массу не 1,6ома,а 2ома;в место каждого диода HFA15TB60 установлено по 3 в параллель HER506;блок питания на трансике,стабилизация на КРЕНке. С уважением Гонза.
Vytelis
Вечер добрый,сделал Бармалеейку 100А,временно поставил IRF740 как советовалли в форуме,нагрузил резистором 0,5 ом,поднял напрежение латра до мах, всё нормально,хотел проверить ограничения тока, на КЗ неуспел поднять напрежения и до 30В полетели транзы.
Помогите люди добрые советом,счего начять.
Viktor V
Между РТ и КЗ на малом напряжении разница 60А, можно так и оставить.
шумный
Для Vytelis!
На 740 можно только посмотреть осциллограммы на ХХ, погонять на ХХ, но не более того. ИМХО.
Для ГонZа!
Возможно насыщение трансформатора, если не проверял ток намагничивания тр-ра при высоком входном напряжение. Если , что то Гуру поправят.
Lemm
Цитата(ГонZа @ 8.2.2012, 18:30) *
подскажите плиз.
если платы не лачЕнные , то могло быть такое . на прежнем месте пылью припало - а на новом по сырости прошило .
fantom-2011
[quote name='ГонZа' date='8.2.2012, 17:30' post='221272']
Приветствую всех на форуме.У меня такая проблема:на работе аппарат варил и 3и4 электродом(А ВАРИТ ОН КЛАССНО!!!),замерял напругу в розетке ,там 212вольт,но работает.Привёз аппарат в гараж,подключил к розетке(там221вольт.....
Может 3845 от холода глюканула. Щас такие сильные морозы стоят...
maxon
Вариантов из-за чего такое могло произойти много. Я бы обратил внимание во первых на частотозадающий конденсатор. Вполне может быть что он невысокого качества и его емкость довольно сильно зависит от температуры (на работе тепло, в гараже холодно, ну и как следствие проблемы). Ну и второй момент на который стоит обратить внимание это трансформатор. В процессе перемещения возможно изменились его характеристики (увеличился зазор, причины могут быть разные). Примерно вот так, что непонятно спрашивайте.
ГонZа
Приветствую всех на форуме.Большое спасибо за ответы и советы.Ключи(транзисторы)будут только в среду,до этого времени проверю всё(руки так и чешутся поварить).По поводу сварки-очень понравилась работа аппарата,электрод не липнет,дуга разжигается сразу,не надо долбить электродом(до этого аппарата делал аппарат на тирристорах-ни какого сравнения с этим аппаратом).С уважением Гонза.
kvaka
А поподробнее можно??
evgen250
автор наверное этот имел в виду
http://www.radioradar.net/radiofan_technol...varka_home.html
kvaka
Тот форум я перечитал уже давно. И прешёл к выводу что этот аппарат ( на теристорах полное г....но).
HIT
День добрый.От тиристорных сварок польза есть.Кто их делал уже ничего не страшно.Даже
сгоревшие транзисторы.Можно спросить у более опытных,переделать и радоваться.
А с тиристорами все неопределенно.
ГонZа
Приветствую всех на форуме.kvaka,я сделал порядка четырёх аппаратов на тирристорах(BT151),аппараты работоспособны,но раздражжает писк на дуге и самого аппарата.После сборки Бармалея я увидел как он хорошо работает, и тирристорные собирать больше не буду!!!!!!Плюс тиристорных аппаратов в том,что тиристоры не убиваемы,но больше настроек.
HIT
ГонZа, но согласитесь,если найти качественные высокочастотные тиристоры ,то писк
отпал бы сам собой,и настроек уменьшилось потому что параметры тиров были бы стандартные.
HEMELL
Не искушайтесь, а то потом будите жалеть.
ГонZа
Приветствую всех на форуме.HIT,Если вы заинтересовались,попробуйте,а мне хватило настроек на четырёх аппаратах!!!Первый аппарат я настраивал почти год,а бармалея 165А-я сделал за две недели.Настраивал только ТТока,и то по низкочастотному ослику.Прошу прощения у форума,что не в тему.
fantom-2011
Отчего же. Все в тему. Если ХВАЛЫ про Бармалея - то в тему. Но голый Бармалей это уже не актуально. icon_smile.gif
Серёгин
Уважаемые специалисты ! Подскажите , кто знает . У меня на сварочном (Бармалей 165 ), на 1/3 регулировки тока от минимума , начинает свистеть трансформатор.А при уменьшении или увеличении тока свист исчезает . Что это может быть ?
oleg1ma
Попробуй одеть на провод от ТТ маленькое феритовое колечко из негодных лампочек экономок.ТТ правильно сфазирован?
Серёгин
ТТ сфазирован правильно .Сварочный нормально работает , варит 2-кой , 3-кой .А колечко на оба провода ТТ одевать ?(Простите за глупый вопрос).может ещё какие мысли есть ?
АУ....кто нибудь ?..... Подскажите , кто знает . У меня на сварочном (Бармалей 165 ), на 1/3 регулировки тока от минимума , начинает свистеть трансформатор.А при уменьшении или увеличении тока свист исчезает . Что это может быть ?
yura_
Скорее всего сам переменный резистор, попробуйте поменять на более качественный.
АУ....кто нибудь ?
Выходные однако
Серёгин
переменник здесь ни причём !я другой ставил.
HIT
А у Вас с первой ноги UC3845 конденсаторы 100n ,а не 100р случайно стоят?
oleg.sv
Добрый вечер. oleg1ma подскажите пожалуйста какая индуктивность дросселя в Липинском инверторе?
oleg1ma
У Липина непомню, а у себя на схемке писал 26мкГн.
UVM
Уважаемые HIT, ГонZa и другие, убедительная просьба в тексте, после знака препинания ставить пробел(как требуют правила русского языка), а то читать ваши сообщения невозможно.
кабельщик
Еще можно добавить, что не стоит мучить себя написанием ника другого пользователя путем стучания по клавишам (можно ошибиться, человек может обидеться icon_biggrin.gif ).
Жмайте кнопку ...
oleg.sv
Извините за невнимательность, действительно на вашей схеме указано icon_smile.gif Спасибо.
Serg2146
Добрый вечер уважаемые форумчане, переделал свой аппарат по вашим рекомендациям, осциллограммы на затворах хорошие, пробовал варить, не варит, нашел причину, исправил, ток стал лучше но до идеала далеко, 2,5 электрод не проваривает на макс токе. Я в печали, вот осцилла вторички тр-ра.
П.С. Делаю аппарат на 100А
К зап.= 0,41-0,43 частота 41,5 кГц
golub
если земля осцилла на минусе, то у вас не сфазирована вторичка, т.е. варите на обратном ходе.
Serg2146
я не помню как цеплял землю. Пробовал варить и плюсом и минусом, результат одинаковый.
yura_
имелось ввиду не концы кабеля, а конец или начало певички трансформатора
