Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
TSL2
Цитата(Alexzav @ 15.12.2014, 6:15) *
Спасибо, буду - делать, отпишусь если кому интересно....
Alexzav, отпишись когда испытаешь. Тоже интересовался данным девайсом, но делать было без надобности...
Цитата(KSV @ 15.12.2014, 16:50) *
Сегодня испытал свою управу, ранее выложенную, работает всё, единственный недостаток, мал заброс горячего старта
KSV, а какой был поджиг на старой прошиве? Сварному не понравился?
KSV
Сам я не варил, и сказать не могу, при испытаниях сварочника Юрия, он говорил, что заметно, включал без его ведома и спрашивал, есть или нет горячий старт.
Serega30
Цитата(Lemm @ 15.12.2014, 3:34) *
. в сварочнике Толяна первичная часть сидит на сети .
Лучше один раз увидеть, ...
А воще меня интересует возможность запитки сей схемы от ИБП +14v, т.к. сейчас его Транс мотаю, и использовать лишнюю обмотку только для этой схемы считаю нецелесообразно. Может диодом как-нибудь развязать можно ? ....
KT117
icon_smile.gif Смотрите http://www.electrik.org/forum/index.php?showtopic=24604
http://www.electrik.org/forum/index.php?ac...st&id=13758
Фишка сей схемы в гальванической развязке выхода от управы. И намотать лишних 18 витков для дополнительной обмотки совсем нетрудно icon_smile.gif
А так конечно можно запитать и от общего источника питания, развязка диодами в схеме есть
Serega30
KT117, понял, спасибо.
sergey777.68, http://www.electrik.org/forum/index.php?sh...44&st=21140
sergey777.68
Wasiliy61
Начинаю потихоньку блоки питания.
sergey777.68
Молоток support.gif support.gifВот и я запустил малыша(160а)Проц со своими возможностями отрабатывает правильно.(как автор прописал) icon_biggrin.gif Неправильно продетые провода через кольцо не давали заявленный ток. icon_biggrin.gif Можно скачать. https://yadi.sk/d/50gYIeyadSbCq
Wasiliy61
Цитата(sergey777.68 @ 16.12.2014, 19:24) *
Сергей, благодарю.
Pavel.I
Цитата(sergey777.68 @ 16.12.2014, 18:24) *
Молоток support.gif support.gifВот и я запустил малыша(160а)...
Так скоро всех на малышей потянет, заявленые амперы интригуют, однако. icon_smile.gif
Итиресно а больше 160 А можно выжать, трансик типа 65-того. Кое какие задумки есть, вернее ориентируюсь на косого. Мостик боюсь не осилю. icon_wink.gif
sergey777.68
В первый раз делаю на кольце(не ломал не пилил)Олег помог с данными для данного кольца и я не задумывался их и намотал. icon_biggrin.gif На экране можно задать только 250а. icon_biggrin.gif Если сложить два кольца то наверно можно выжать и больше (но у меня стоят только 4 транзистора 4068)и разгонять дальше нет смысла.Мостик боюсь не осилю я тоже раньше боялся такой схемы.Вот перешел и оказался на другой стороне. upal.gif
KSV
Цитата(Serega30 @ 16.12.2014, 18:02) *
Слепил хорошо. На выходе, правда, без дросселька, и ТL431 Б/У.
Если даже не "ИКАЕТ" , то совсем беда, проверяйте всё и главное ТОР
DANTIST
Цитата(Serega30 @ 16.12.2014, 17:57) *
Всем привет. Слепил ИБП на TOP224Y - не стартует. Фазировка транса не перепутана. Подскажите где искать. Спасибо.
Проверь розетку или вилку.
DANTIST
Цитата(Serega30 @ 16.12.2014, 19:06) *
Во дуракь, а резистора 6,8R последовательно с 47mF забыль запаятьicon_biggrin.gif
DANTIST
Цитата(Serega30 @ 16.12.2014, 21:18) *
DANTIST, не люблю растягивать.
Navstar
Serega30, Раз заговорили об удовольствиях, вон насколько я растягиваю брал детальки еще когда бакс по 8 был icon_biggrin.gif icon_biggrin.gif
хотя некоторую часть деталек нужно докупить, в основном моточные и на корпус
KT117
oleg1ma
Serega30
Navstar, сделано вроде не плохо.
... не то, что у меняicon_biggrin.gif иногда сам удивляюсь как оно работает. Положение спасают только блокировочные кондеры на ключах. Силу, все-же, надо будет переделать, а то подвывает иногда.
Wasiliy61
Серёга, что у тебя за зверь в силе завёлся- подвывает-то.
Serega30
Wasiliy61, да коряво собрано все, не по правилам силовой электроники.
Wasiliy61
Понятно, а меня зима угнетает, как-то всё медленно движится, а то пади стареть начал. Правда сёгодня успел силу травануть.
Хотя летом у меня дела идут шустрее, а зимой на меня что-то типо дипрессии нападает.
Navstar
Цитата(oleg1ma @ 17.12.2014, 16:26) *
Конечно, только канифоль и спирт!
Ну это на первый взгляд, я же обратную сторону не показываю чтобы не портить впечатление!
Wasiliy61
Олег наверно имел ввиду термо пасту. Ну а если применить только чпирт, то наверно после этого и канифоль не нужна будет.
Ну а ты не скромничай, засвети народу обратную сторону луны.
KT117
Женился парень а жену никому из друзей не показывает. Вот и пристали они с расспросами, что да как, как выглядит.
Парень говори:т-Замечательная жена попалась, все кто видят-говорят, что она прямо как Божья матерь.
Ну пристали заинтригованные друзья:-Так ты хоть фотку покажи!
Парень достает фотку и показывает.
Все кто ее видит хватается за голову и восклицает:-Матерь Божия!
VOVA 555
Гульчатай покажи личико . icon_biggrin.gif Увас вполне нормальный вид. Ребята тут видали и пожошче кишочки инвертора .
Navstar
както-так
KT117
Цитата(Navstar @ 17.12.2014, 21:45) *
както-так
-Матерь Божия!
Wasiliy61
Цитата(Navstar @ 18.12.2014, 1:45) *
както-так
Непонял??????? Ни хрена шутка-вот это пучёк.
Пока смеялись, малость обработал плату блока питания. Завтра если будет хулиганский настрой, может набью плату деталями, правда транс на дежурку не готов.
DANTIST
Цитата(KT117 @ 17.12.2014, 20:14) *
Вы, случайно с Василием не в одном вигваме живете?
Все хорошо на лице. Но вот эта желтая кнопочка на желтом фоне... Специально, что ли?
Корпус очень неплох. Почему только практически всегда плата управы стоит сразу за радиаторами? Вся пылюка будет на нее сыпаться.
Что еще хотел сказать. Эти радиаторы не для такого расположения вентилятора. Как правильно-сам знаешь.
Еще немного добавлю. Похоже корпус делался на заказ. Рекомендую внутри на задней и передней стенке приварить небольшие уголки для крепления полки. И тогда на лице не будет винтов крепления.
Честно говоря, не понятно из каких соображений стоит сетевой выключатель посреди лица? Не место ему там, совершенно. Хотя бы в верхний левый угол, или на заднюю стенку.
Serega30
Wasiliy61, подробнее о лужении, если можно.
Navstar
KT117, Симпатишно! А на какой пиковый ток расчитан?
KT117
icon_smile.gif В одном-планета Земля называется
Случайно, сначала цвет корпуса планировался быть другим
Плата будет покрыта лаком. Вскрывал ранее изготовленные аппараты после полугода работы-платы чистые (относительно, слегка запыленные). А вот чем мне нравится такое расположение-управа отделена от силовой металлическим экраном
Все верно, но что было под рукой то и пошло в работу. Делал ранее аппараты на таких радиаторах-работают, а ими сварные и варят и арматуру режут icon_smile.gif . Чистить просто нужно чаще
А так максимальный ток в этих аппаратах ставлю 160А. На перегрев еще никто не жаловался. Вентилятор крутит постоянно.
Это Липинский, компоновка oleg1ma. В теле ветки можно найти инфу по печаткам и прошивкам
Я вот навострился лудить сплавом Розе в кипятке с лимонной кислотой
Неплохо получается
oleg1ma
Еще одна компановка липинского, зима идет, а они все сварочники заказывают.. icon_biggrin.gif
VOVA 555
Неплохо получается
Хорошо у вас получилось . Я как то пробывал лимоная кислота + сплав розе очень не понравилось после лужения , дорожки тусклые получились . Почему так вышло так и не понял.
Navstar
oleg1ma, А вы силовой пропитываете? Я бы все делал в термоусадке стремает что может коротнуть после работы и первого аппарата такая фобия icon_smile.gif .
oleg1ma
Не пропитываю, просто промазываю эбоксидкой после намотки первички, заодно получается жесткость сердечника, если он ломался.Вторичку обматываю двумя слоями каптона и после намотки, опять промазываю эпоксидкой.Когда ничего не шевелится, ничего и не коротнет, а термоусадка ухудшает охлаждение провода.
Сергей_74
Красота!!! И радиаторы от компа вместе с куллерами отлично встали.
Олег можно лайку этой силы глянуть?
Wasiliy61
Мне почему-то не нравится выключатель на задней стенке, делаю всё вперёд. На одном корпусе тоже стоит почти по серёдке, смотрится как циклоп, но теперь что уж получилось. За-то смотришь на него наглыми глазами, и говоришь- я тебя сейчас включу, а то надо заглядывать ему в жопу. Есть у меня один такой аппарат, свиду Кратон- а внутри косарь, так вот всем он мне нравится, а то что надо заглядываить в зад- нет.
Да, ничего здесь хитрого нет, лужу обычным пояльником- с широким жалом, мощьностью наверно вт 60, на нём что-то не написанно.
Мелкие пайки конечно делаю другим паяльником. Ну ладно дальше о лужении- плату иногда мажу вот таким флюсам.
иногда просто разотру кусочек канифоли в порошок, и посыплю плату-тоже хорошо лудится, ну а затем олово на паяльник, и вперёд- растягиваю по дорожкам, потом смываю растворителем. Ещё говорят хорошие результаты (вместо флюса-аптечный глицирин) я правда не пробывал, но после его надо хорошо мыть плату.
Цитата(Serega30 @ 18.12.2014, 5:58) *
VOVA 555, со сплавом Розе у меня тоже тусклое покрытие получается, а вот знакомый лудит Розе - так у него блестит как у кота ..... icon_biggrin.gif Тоже не понимаю пока что не так делаю.
Сплавом Розе не пробывал, может и попробую- так как живу в сельской месности, и в наших магазинах Розе нет, есть конечно кое какие флюсы, припои- до города 90км, каждый раз не наездиешься. Село тоже умирает, за последние лет 10-15. население проредилось где-то до 5тысяч. Тоже всё заводы и фабрики разбомбили, нынешним летом так в речь порту оставили один кран, второй демонтировали, ну ладно -эт я не по теме.
tranzistor3102
кстати это дешевый сварочник от oleg1ma собирал такой 1.5-2 года назад только транзисторы использовал 4063d и диоды 150ebu02 работает до сих пор. использую на работе. нормальный компактный сварочник.хотя уже не такой дешевый по данным ценам на комплектуюшие icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
DANTIST
Цитата(Wasiliy61 @ 18.12.2014, 4:39) *
...так как живу в сельской месности, и в наших магазинах Розе нет, есть конечно кое какие флюсы, припои- до города 90км, каждый раз не наездиешься. Село тоже умирает, за последние лет 10-15. население проредилось где-то до 5тысяч. Тоже всё заводы и фабрики разбомбили, нынешним летом так в речь порту оставили один кран, второй демонтировали, ну ладно -эт я не по теме.
Василий, а в Алтайском крае зима настоящая? Со снегом? А то у нас зима уже закончилась. Даже был снег и мороз. А сейчас туман. В 20-ти метрах ниче не видать. icon_sad.gif
По поводу выделенного слова - это в метафизическом смысле?
KT117
Наткнулся в интернете на производство корпусов, может кого заинтересует http://metallokorpus.ru/the-hull-of-the-product.php
oleg1ma
Вот держи, сила и управу делал под этот корпус, почти на халяву досталось 15 шт.Единнственное неудобство, ширина его 95мм, поэтому пришлось и управу уменьшить по ширине до 90мм.Сам аппарат, будет таким.
ingener99
А какие функции у квадратной кнопки под цифрой 140?
oleg1ma
ingener99
DANTIST
Цитата(oleg1ma @ 18.12.2014, 9:31) *
...почти на халяву досталось 15 шт.
Везет людям! А тут бегаешь целый день по лесу и никто, просто так, косточку не даст. icon_biggrin.gif
KSV
Провёл очередное испытание своей управы, после изменения прошивки (модернизация горячего старта) сварной остался доволен, сказал, что теперь эффект при розжиге есть. Немного позднее окультурю документацию и выложу всё вместе. Что то этот сварочник как то туго делался, началось со сгорания силового транса, и закончилось непонятным интерпульсом во время сварки icon_biggrin.gif или новый год на носу или экономический кризис icon_biggrin.gif
oleg1ma
Подробнее можно про транс, непонятный интерпульс - это скорее всего пропуски шима из-за неудачной разводки или проложенной ОС.
