Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Serega30
RadioГубитель, уловил. Спасибо.
RadioГубитель
Цитата(Serega30 @ 6.4.2014, 0:59) *
ingener99, закон Ома пока еще никто не отменял
Тут не Ома вспоминать надобно, а коэффициент заполнения... icon_biggrin.gif 0,42 на максимуме, а на токах в 100 А максимум 0,2-0,3 на максимуме.
Velgosh
Хочу выставить Ток по ограничению по таком принцыпу:
Расчитывается по формуле:
I(max) = N*Uпор/Rs
где I(max) - максимальное значение тока перед ограничением, А (в первичной обмотке
Тр.3)
N - количество витков вторички трансформатора тока
Uпор - порог ограничения компаратора контроллера (вольты)
Rs - внешний резистор обратной связи по току (омы)
Так, как у UC3845 - порог ограничения 1 вольт (третья нога), то для UC3845
Uпор=1вольт, поэтому из формулы выбрасываем, что толку на один умножать. Поэтому
получаем: I(max)=N/Rs
Посчитаем маленький Бармалея: (который до 100 А)
N=50, Rs = 1,5ом
I (max) = 50/1,5=33A
Если сопротивление резистора уменьшить до 1ома, получим ограничение на 50А
I(max) = 50/1 = 50А
но немагу понять што такое Rs - внешний резистор обратной связи по току (омы)?
Сварочник работает, но 3-ку нетянит, варит толька 2-ой, поетаму решил поднять ток
может кто подскажет, заранее спасиба
Velgosh
Цитата(golub @ 7.4.2014, 8:27) *
а до сколька можна поднимать ток если у меня два силовых IRG4PC50U?
K.AA.M
Проверте фазировку обмоток выходного трансформатора
DANTIST
А, что, у тебя был такой случай?
Цитата(Velgosh @ 7.4.2014, 7:04) *
... но немагу понять што такое Rs - внешний резистор обратной связи по току (омы)?
Брось ето занятее. Ето не тваё.
Serega30
Насчет фазировки СТ: проверял на своем, с рисунком все совпадает. Для опредиления фазировки достаточно посмотреть как намотан СТ.
K.AA.M
Был вроде все собрал правильно, роботает дуга горит, а електрод еле плавится на максимальном токе (електрод 3) вот и я думал поиграться с резистором на 3 ноге который шунтирует токовый трансформатор, хорошо что добрые подсказали про фазировку силового трансформатора, проверил оказалось неправильная фазировка (видимо он работал как обратоходовый) после исправления ошибки все заработало как надо даже 4 кой варит (бармалея делал 165 А но ограничил ток на 150А).
DANTIST
Так там и выходное напряжение на ХХ должно было быть за сотню.
Было у меня такое. До сварки только я не дошел.
Magnitogorsk
На те же грабли наступал два раза Фазировку трансформатора ошибался тоже дуга горела вроде чуть чуть ,а не хрена не варил помял фазировку сразу все в норме , потом подогнал витки на ТТ на 155 ампер ограничил.До сих пор трудится).
Serega30
Это что за новшество такое...? Не резистор под Тт подбираете а витки под резистор на Тт?
Jorg63
разницы абсолютно никакой!!!!!. просто резаками удобней все лишь вести подбор нужного тока
golub
Не ново это, читать больше нужно. ШОБ не вопрошать впустую.
slavyann
tranzistor3102
Цитата(Serega30 @ 9.4.2014, 1:56) *
Здравствуйте! Провел ''боевое крещение'' инвертора на плохой сети: швеллер 4-6мм, электрод 3мм 4шт один за другим на макс. токе. Особого нагрева силовых элементов инвертора не заметил. Провар вроде не плохой. КЗ было много раз, т.к. металл слишком ржавый был. Пока полет нормальный.
а когда будет ''боевое крещение'' инвертора на хорошей сети? icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
DANTIST
Цитата(DANTIST @ 25.3.2014, 11:22) *
Сереги, Вам давно уже пора варить! А Вы все херней страдаете. Сравниваете амперы с вольтами и Омами.
Уж если так сильно нравится, - балласт в пластиковый тазик с водой и накручивайте кВт/ч*0,3648. icon_biggrin.gif
Jorg63
Цитата(Serega30 @ 9.4.2014, 9:07) *
DANTIST,согласен, я и варю и тестирую заодно.
Смотри Серега дотестируешься! icon_biggrin.gif Работает аппарат нормально и не дури голову себе и людям!
Wasiliy61
Так он теперь ключей накупил, и наверно хочет узнать предельно допустимый ток у них, не зря веть он так в даташитах тчательно разбирался.
Wasiliy61
Цитата(Serega30 @ 9.4.2014, 13:31) *
У меня предложение: во избежание лишних вопросов(что-то нужное найти на форуме очень трудно) подчистить форум(удалить ненужные сообщения и сообщения, к которым имеются цитаты).
Серёга, да кто-ж его теперь лопатить будет, время убивать.
Jorg63
Цитата(Serega30 @ 9.4.2014, 9:46) *
Если тех персонал не в состоянии этого сделать-то каждый сам свои посты. P.S. это всего-лишь предложение.
чтобы ничего не чистить не надо "пустышки"посты писать.
DANTIST
Serega, если сейчас каждый свои сообщения частично поудаляет, то хрен поймешь, о чем базарили. Кое что можно поудалять. Ругань всякую. Так вроде спокойно пока на форуме. Скучновато... Наверно, Gyratora давно не было.
И вот это мое сообщение можно потом удалить.
Вопрос на засыпку: А делал ли кто из присутствующих чоппер? Не мотоцикл. icon_biggrin.gif
Wasiliy61
Цитата(Serega30 @ 9.4.2014, 16:49) *
Чо́ппер (от англ. chopper — нож для нарезки продуктов): Чоппер — стиль мотоцикла; Чоппер — силовая часть регулятора ШИМ; Чоппер — одно из древнейших орудий труда эпохи палеолита; Чоппер — имя одного из персонажей аниме-сериала One Piece; Чоппер — другое название жанра компьютерных игр слэшер; Чоппер — измельчитель (кухонный комбайн); Чоппер — часть оптической схемы ИК-спектрометров,
переключающая поток ИК
излучения.
Вот это не хрена,- ответ.
DANTIST
Цитата(Serega30 @ 9.4.2014, 9:49) *
...Чоппер — силовая часть регулятора ШИМ...
Вот это меня интересует в данный момент. icon_biggrin.gif В плане того, что нет ли там каких-то подводных камней. Каких-то особых тонкостей в плане запуска, настройки.
igorka
http://valvol.ru/topic150.html
eger
Цитата(igorka @ 9.4.2014, 23:29) *
почти собрал эту штуку .только с блоком питания пока не разобрался .так как в схеме есть опечатки
DANTIST
Всё, забыли про чоппер. Говорим исключительно о Бармалее.
oster
Подскажите пожалуста,где можно скачать архив последнего вариата Бармалея?
Wasiliy61
А что за последний вариант Бармалея, есть 100а и 165а, правда есть делают на оптике, или что-то изменяют под себя.
владимирон
подскажите спецы в силу дизайна передней панели хочу поставить движковый переменый резистор. Нужного номинала 2,2 ком нет имеется 4,7 ком вопрос какие должны быть резисторы на землю и на 8 ногу
Wasiliy61
Что-то мне такие переменники не внушают доверия, может не все такие. Помнится пошли они на усилителях- вроди как крассиво и модно было в то время, но они быстро приходили в негодность. А что-бы не парится с расчётом, подпаралель ему постоянный резак 4.7к, получится 2.35к- будет работать, и ни чего менять в обвязке не надо.
Нажмите для просмотра прикрепленного файла Вот такие, ну просто изумительные переменники- переживёт любого переменника с напылением, но они встречаются всё реже.
awf1234
Сделал сборный каркас для Бармалейника, феррит Е70. Подскажите, пожалуйста, оптимальное количество витков обмоток - 15/5 или 14/5? Конечно, понимаю, что это уже много раз разжевывалось на форуме, но перечитать больше 1000 страниц еще одной жизни нет в запасе. Сделал управление Юры на атмега, сейчас делаю силу. Также интересует вопрос сравнения резонансника и бармалейнимка. Резонансники 3 шт. сделал,все разные, все работают, теперь очередь за Бармалейником. Очень интересно сравнение, может кто сравнивал.
Wasiliy61
Вообще-то Ктр лучше сделать1/3., т.е. 15/5. -естественно в соответствии с частотой.
awf1234
Встречал данные 14/5, вот и интересуюсь, может на хорошую -плохую сеть и т.п.? Частота около 50кГц.
awf1234
На схеме Юрия ММА 30-220А указано 14/5, вот и пытаю народ что лучше.
Lemm
Цитата(awf1234 @ 10.4.2014, 21:04) *
что лучше.
это харчи могут быть лучше-хуже . тут надо понимать что делаешь и для чего . мотайте 14/5 - для наших сетей то что надо . а если жить в будке с трансформатором - то 15/5 icon_smile.gif
awf1234
Все теперь понятно, спасибо. Буду мотать 14/5 без сомнений.
Wasiliy61
Дык, для 50кгц первичка будет длинновата- транс будет очень далёк от насыщения, а значит будет работать с большими потерями.Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла
and_w
Почему длинновата- все нормально.... Про потери-ну если это небольшой нагрев на ХХ, то автор вопроса писал ранее, что управу на атмеге сделал- а там 3 мин. бездействия и рубится ШИМ....
Wasiliy61
Не ребята, моё мнение такое; в данном случае лишний виток на вторичке-для того что-бы получить желаемое на выходе, это желаемое мы теряем когда мотаем лишние витки на первичке. Отсюда и нарушение Ктр. При частоте 50кгц, на транс Е70-достаточно 12 витков...это моё мнение. Во всех аппаратах, делал согласно этой программы. При первом запуске через лампочку-90вт, ни в одном аппарате лампочка не дала накал, значит витков на первичке-более чем достатачно, если конечно феррит не гав.. .
tranzistor3102
здраствуй василий лично я мотал транс на е70 15/5 частота 50кгц все отлично работает icon_biggrin.gif
Wasiliy61
Дык он будет работать, на хорошей сети сильно заметно не будет. Вообще-то эти данные 15/5 для феррита Е65 -на 50кгц. Я думаю что если на Е70 мотнуть 12/4 - то можно избежать не нужных потерь, да и взять с транса и побольше мощи можно. Моё мнение.
tranzistor3102
ну если хорошая сеть это 190 V ( у меня дома)= то пускай дальше трудиться icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Wasiliy61
Да, конечно- если аппарат работает нормально, и хватает тока- то пусть работает на благо народа, что его трогать. Я просто думаю так, что чем больше лишнего на первичке, тем глубже будет проваливаться вторичка при нагрузке, но это опять -же моё мнение.
санекнс
Всем привет подскажите пожалуйста собрал сварочный косой мост по схеме на фото управа один в один драйвера буферные с отрицательным смещением в 4вольта. но что то не так, спалил 8 транзисторов. ставил по одному в плечо на пробу. фазировка правильная, время спада 80нс, ттр 80 витков сопр 1 ом временно поставил 8ом на выходе КЗ на 40 вольтах от латра импульс на затворе схлопывается, начинаешь прибавлять резистором тока ток импульс расширяется с 1.5мкс до 4-5мкс дальше начинает дрожать и резко расширяется до максимума частота 50кгц транс Е70 эпкос 2шт , прокладка кассоввый чек на всех трех кернах. первичка 7 витков вторички 2.5витка , витки первички подбирал по прибору гумерова - зуева загиб начинался с 14мкс. транс размагничивается, четкий загиб в конце импульса на коллекторе нижнего ключа. что делать не знаю подскажите ведь при регулировке импульс не должен дергаться то шире то уже становиться, а плано расширяться
AS65
СТ неправильно включен,обратноход получился если схеме соответствует.
Похоже ты пытаешься сам себя перехитрить,зачем такой огород с драйверами?
oleg1ma
Все там правильно с фазировкой.
санекнс
СТ НАМОТАН ПЕРВИЧКА И ВТОРИЧКА ПАРАЛЕЛЬНО НЕ КАК НА СХЕМЕ,
ДЕЛАЛ С РАСЧЕТОМ ПО ТРИ 50U ПОСТАВИТЬ
oleg1ma
На Вашей схеме фазировка указанна верно, если у Вас все на оборот - значит CТ подключен не верно.
DANTIST
Цитата(санекнс @ 11.4.2014, 6:11) *
...спалил 8 транзисторов. ставил по одному в плечо на пробу.
что-то пробовал менять? Может что с резистором. Транс силовой при этом звуки какие-то издает?
Так, что, после скачка импульса вылетают ключи?
Не, что-то здесь не так... Ты ставишь задатчик на минимум, КЗ и начинаешь добавлять задатчик? А зачем? Что это за проверка? Если импульс схлопнулся по сигналу ТТ, то он расхлопывается только после снятия КЗ. Ах, блин. Здесь же 3845. Это для Кольта на 3525. Пардон. Тут, наверно, не так. Не пробовал такую проверку.
...что делать не знаю подскажите ведь при регулировке импульс не должен дергаться то шире то уже становиться, а плано расширяться
Импульс регулируется при подключении специальной цепочки с выхода 3846 на вход. Других проверок не предусмотрено. Но никто и не запрещает. Чем ты и занимаешься.
Прочитай настройку на 1-й странице 1-й части форума Бармалейного. Там все расписано.
Удачи.
