Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Павел(Sp)
2 ома,поставил первый попавшийся похожий,потом думал подобрать
Там их кажись 2,какой из 2х?
Wasiliy61
Посмотри обвязку задатчика, особенно верхнее и нижнее плечё.
DANTIST
Нижний влияет на максимальный ток, верхний может быть связан со срывом генерации на мин. токе. Надо увеличить. У меня такое было. Чуть ли не в полтора раза увеличивал.
Serega30
Это об 1к3 и 510, или о 33к и 33к ?
DANTIST
Это обвязка регулятора тока. 1к3 и 510 или другие, в зависимости от номинала регулятора.
Поставь вместо 1к3 подстроечник где-то на 2к2 (4к7) и подбери номинал по устойчивой генерации на мин. токе. Может несколько подпрыгнуть мин. ток. А кто варит на токе ампер 30-40? Хотя, у меня практически не изменился. И это при том, что резистор я изменил с 2к2 чуть ли не до 3к при регуляторе 5к. Замена микросхемы ничего не дала. Думал с ней проблема.
Serega30
электрод 2мм
DANTIST
Цитата(Serega30 @ 14.5.2014, 12:23) *
электрод 2мм
Марка электрода?
Serega30
Цитата(DANTIST @ 14.5.2014, 15:33) *
Марка электрода?
это диаметр стержняicon_biggrin.gif. Ну вот читаю на пачке АНО-36: Мин. ток 50А, Uхх=50+-5В. Но, как на меня, качество у них ниже среднего. А вот на упаковке "Монолит"-а указан мин. ток 40А. Довольно-таки не плохие электроды.
Впрочем, я не сварщик..., я только учусь.
DANTIST
Serega, я спросил про марку электродов, которыми ты собрался варить таким током. Когда доделаешь аппарат.
Хотя это дело хозяйское. Хочешь варить этим током - вари. Все, что нельзя приварить, можно присрать.
SERGIO84
Добрый вечер!Возможно ли мотать силовой трансформатор не эмальпроводом,а к примеру набрать необходимое сечение из провода ШВВП.Для увеличения поверхностного сечения(для снижения СКИН эффекта) к примеру увеличить сечение шины.
Serega30
Так я и так уже варю. Металл до 2мм двойкой варится нормально при токе 40...45А. Будет на что сфоткать-выложу фотки.
Serega30
Сколько примерно надо витков обмотки дроселя(феррит 2 строчника, сложеных в Н), на частоту 53 кГц? Сейчас дроссель снаружы болтается, намотано 8 сварочного кабеля. Хочу намотать нормально, нужна длина провода. Читать, п-та, не посылайте. Спасибо.
and_w
У меня получалось где-то 11 витков....длина -около 120 см, точно уже не помню..
Павел(Sp)
Заработало.
Резистор 1,3к поменял на подстроечник.получилось 3к ровно.
Дантист, если б тебя и таких как ты не было,не знаю чтоб делал..но знаю что б точно не делал ,так это Бармалея. durak.gif
Я сначала пробовал увеличить этот резисстор, ..но не 200%...
Serega30
Павел(Sp), интереса ради, измерьте диапазон изменение U на 1 ноге 3845... Мне вот тоже интересно сколько там у Васicon_biggrin.gif
Сергей_74
Мотни любым тонким изолированным проводом, некоторое кол-во витков и померь L и набрав нужную индуктивность будешь знать сколько мотать нужно и с длиной примерно будет ясно, добавишь длины на запас и вперед..
Я так делал и не парил никого.
Serega30
Сергей_74, нечем L мерять у меня.
ACER
Ребята а как на форум файлы в лайке выкладывать?
Serega30
В архиве, или разширение измени
KSV
Я мотал на одиночных (2 шт) и двойных рогах (4 шт) шинкой и жгутом под завязку, получается примерно 25-30 микрогенри. По ширине, ПК средние, от ЧБ телика были узкие. Дросель готовый лежит в подвале если нужно точно, могу померять не ранее чем завтра, прибор на работе. Посмотрите в схеме ,замерял.Нажмите для просмотра прикрепленного файла
Serega30
KSV, спасибо, пока-что не надо. Как насчет нагрева и тока если сравнивать "роги" 2шт и 4шт ?
KSV
В схеме написано, я делал на одиночных, двойной дросель лежит в подвале, так и не пробовал.Больше 150а я не делал, и особо не заморачивался.
Serega30
Намотал на скорую руку дроселек на одном рогатом строчнике проводом 6,9мм2-10витков. Как ни странно, если верить сварщику, имвентор стал варить лучше (по сравнению с рогами на двух строчниках и обмотке из сварочного кабеля-8 витков). Феррит не греется, обмотка чуток теплая.
KT117
Посмотрите еще дроссель на трансформаторном железе из ветки про AVT200
Толян выкладывал фото
Павел(Sp)
Короче..нашел косяк..резистор на 33кило почемусь не был припаян.Припаял,так и все заработало с резистором 1,2к в обвязке(кстати , чем чревато 1,2к а не 1,3к?)
Серега,я Вам как родному,т.е. как земляку скажу..Шо на 1 -й лапе напруга крутится от 1.5 до 4,4 вольта не знаю гуд это или швах..
DANTIST
Вот так всегда. Сначало нужно всем мозги затрахать, а потом искать косяки!
(кстати, чем чревато 1,2к а не 1,3к?)
Ну поставь и посмотри. Или ты как Serega30-тый, спрашиваешь, чтобы просто потрындеть. Форум расшевелить.
Basill
icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif Ну сколько можно объяснять, что цель форума как интернет-ресурса - постоянное общение, добавление постов (в пределах правил форума). beer.gif
Отсюда трафик, рейтинги ресурса и т.д. и т.п.
Это ж не справочник и не печатное издание с ограниченным объемом в листах!!!
А то, понимаешь, возмущаются (не к Вам лично относится), что мол, "сколько можно талдычить об одном и том же", "достали", "читайте форум", "уже тыщу раз обсуждали"... flag.gif icon_biggrin.gif
Павел(Sp)
А из рогатки в меня не хочеш выстрелить,или песком покидаться.... duel.gif duel.gif duel.gif
Не святые горшки лепят ведь..
DANTIST
Цитата(Basill @ 16.5.2014, 8:11) *
...Отсюда трафик, рейтинги ресурса и т.д. и т.п.
А Serega30, часом, не засланный казачок, типа для подъема рейтинга? icon_biggrin.gif
Цитата(Павел(Sp) @ 16.5.2014, 8:12) *
А из рогатки в меня не хочеш выстрелить... ..
Не, Паша, уже поздно. Как говорил О. Бендер, - таких нужно в детстве из рогатки убивать.icon_biggrin.gif
Ну ты ж вроде не вчерашний.
Serega30
DANTIST
Цитата(Serega30 @ 16.5.2014, 9:58) *
Павел(Sp)
Всё, что не греется - лишнее...или сгорело.............или не припаяно..
Меня тоже вычеркуй.
Дантист,а где посмотреть -почитать как происходит процесс регулировки и ограничения тока в косом.тсть теория.плс если помнишЬ
DANTIST
Меня тоже вычеркуй.
Понял, вычеркиваю.
А по поводу процесса... Тут без пол литра не разберешься. Вроде бы все просто, но в тоже время, если рассмотреть работу на основе структурной схемы 3845, то ХЗ. Некоторые моменты мне не ясны. Теоретик с меня хреновый. Честно говоря, я сам нигде не читал более-менее толкового описания работы схемы управления. В шите разрозненные описания отдельных узлов. А так, чтобы доходчиво объяснялась работа в целом, такого не встречал.
Думаю, полную ясность мог бы внести Сам Бармалей. Но я его ни разу не слышал и не видел. А может кто-то из оставшихся на ветке могучих растолкует.
Т. е. оно как бы понятно. Пила + постоянное напряжение - получаем ШИМ. ТТ подрезает задний фронт импульсов ШИМ при превышении напряжения 1 В на 3-й ноге.
Короче, если тебе горит, поспрошай у гуру. Если нет, сообщу чуть позже.
KSV
Меня тоже вычеркуй.
В соседней ветке, ММА на атмега 8, сообщение 6670.
DANTIST
Павел, ты понял? Устраивает такое объяснение?
Serega30
Сообщение #6706 "... 3-ка электрод при отключенном Хот Старте хорошо
горит(варит) на 50А +-погрешность
golub
чем клаву впустую топтать, слепили бы себе RLC-метр. Там работы на два вечера на коленке.
Serega30
golub, на инфу взлянуть можно?
KSV
http://monitor.espec.ws/section44/topic143209.html http://radiokot.ru/circuit/digital/measure/91/ меряет индуктивность и не только. Вариантов море, с разным питанием и индикаторами.
Serega30
Гуглить я то и сам умеюicon_biggrin.gif Мне бы че нибудь по-проще, если можно
KSV
Это не гугл, сам собирал. Если проще то в магазин, проще не придумать. Там и сварки на любой вкус и кошелёк.
Serega30
. Ага... Только не у каждого кошелек это позволяет.
RadioГубитель
Самому собирать дороже порой выходит. Задумайтесь над этим...
Serega30
...когда сам собираешь, приобретаешь еще кое-что очень важное-опыт.
RadioГубитель
Удачи! Главное чтобы не случилось впоследствии как в поговорке: не в коня корм icon_smile.gif
SL12
посмотрите на такой LCF: http://aukro.ua/lcf-izmeritel-induktivnost...4247527899.html
SchVePs
У меня такой же; хорошо работает только частотомер.
igorka
А вы не пробовали разобраться , почему он так работает?Или лень?У меня напротив частотомер со странностями...
Вот посмотрите http://www.electrik.org/forum/index.php?sh...st&p=320191
Alexzav
плюнул на эксперименты и, с"экономив на пиве и бензине, купил себе вот такой приборчег.....
на фото виден ещё дроссель.... проводим теперь опыты с ним вместе!!!так сказать под его присмотром или, смотря на него.
