Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
KSV
Цитата(Velgosh @ 23.12.2014, 16:20) *
типа етаво
Velgosh
Цитата(KSV @ 23.12.2014, 18:28) *
уже все сделано, icon_biggrin.gif , остались некоторіе мелочи ну и самое главное - настройка
eger
Цитата(KSV @ 23.12.2014, 19:52) *
Город невест был когда фабрики работали по производству тряпки, а теперь все фабрики переделали в торговые центры, их теперь больше чем в Москве. Последний губернатор вложил наши деньги в развитие текстильной промышленности, открыл ещё два( две последние фабрики закрыл icon_biggrin.gif ). А за компом я на работе сижу, и паяю тоже, так, что невест никто не отменял icon_smile.gif .
когда нибудь этих 7ук ( губернаторов ) подобных пересадят надеюсь icon_sad.gif
Navstar
KSV, Молодец! Хороша управка!
Serega30, FR мне не нравтся в блоках питания уже давали сбой из-за перегрева (возможно паленка космодромовская) но те же HER, SF, 1N работают куда лучше
DANTIST
Цитата(Serega30 @ 23.12.2014, 20:16) *
Сляпил ИБП на TOP224.
Николай Г.
Цитата(KSV @ 23.12.2014, 13:31) *
Доделал свой сварочник, немного изменил прошивку, добавил блокировку настроек, и в настройках сделал некоторые коррекции. Нарисовал схему и написал небольшую инструкцию по прошивке (работе), всё в архиве.
Сергей, молодец. Фирма smoke.gif .
Что-то Олег с вторым Сергеем от тебя отстали. Начали вроде одновременно duel-1.gif.
С уважением.
Wasiliy61
Длбрый вечер. Вот доделал сегодня блок питания 2а в одном, как говорится появился хулиганский настрой- и я взялся с утра за него. Результат- это лучьший из 5и сделанных мною на ТОР224, имеется ввиду дежурка- хотя все работают нормально. Просто 3и дежурки не зажигали лампочку 12V-21W, четвёртый пытался зажечь-2-3 раза лампочка чуть подмигивала, и ТОР уходил в защиту. Прогретую лампочку он зажигал, а 5ый импульсник нагруженный на холодную лампчку запускается в лёгкую. Правда пока запускался- пол стены вынесло (шутка),нет всё нормально-ни чего не температурит. Только вместо супрессора, я собрал кламперочик. Осталось знездо для предохранителя впаять. Вот что получилось.
oleg1ma
Wasiliy61
Цитата(oleg1ma @ 25.12.2014, 22:44) *
Олег, благодарю- торопился и не заметил 0, завтра впихну другой. Хотел то 47ом воткнуть, но при запуске все выдержало. Наверно старею, не внимательный стал и слеповатый.
KSV
Отлично получилось, а натписи на плате, утюговая технология? И как потом, лаком, а то помоеш спиртом и сотрётся. icon_biggrin.gif
Wasiliy61
Да утюговая, на подложке от самоклейки, потом лаком.
Alexzav
Молодец - Василий Михайлович!!!! красиво и, раз от раза лучше и лучше получается..а по надписям перед лакировкой лучше пройтись яичным белком а, как высохнет уже лакировать.
aleks77671
Я пользуюсь термотрансферной бумагой для лазерных принтеров, получается лучше чем на подложке.
Wasiliy61
Санёк, блогодарю за оценку, и спасибо oleg1ma-что нашёл ошибку, впихнул не тот резистор по запарке. Сегодня исправил положение, перепаял резистор- и малость поправил пайку, а то вчера торопился, и наляпал как попало.
KSV
А на сколько сварочник будет, если два моста стоят и на сколько напряжений БП, деталюх многовато. Я вот тоже пайнул на досуге, предновогодний рывок, деталей в БП поменьше. ТОПов не хватает, радиаторы выпилил, но рабочий день как назло закончился. Нажмите для просмотра прикрепленного файла
Wasiliy61
Красота получается. А сварочник я планую сделать на 160а, просто мост 5010 ставлю один, а это МВ3510-поэтому поставил 2а, может и один бы выдержал, но как говориться бережоного бог бережёт. А питальник обычный 15v и 300VНажмите для просмотра прикрепленного файла
Есть и на один мост,его тоже делал Нажмите для просмотра прикрепленного файла
Ну а третий вариант я как-то потерял.
KT117
icon_smile.gif Вы мужики-не тормозите. Доделывайте сварочники побыстрее и не ленитесь-до Нового года осталось 5 дней
KSV
Торопимся, а то после НГ всё подорожает, придётся по дорогому паять (труд тоже денег стоит ), а так по дешовке получается icon_biggrin.gif . Всех с наступающим НГ, мира и дешовых деталей (не перемаркер конечно icon_lol.gif ) и хороших клиентов (чтоб поменьше варили, а стояли в гараже наши сварочки, больше для декора icon_biggrin.gif ).
sergey777.68
Появилось и у меня время для испытания малыша на штучный электрод. icon_biggrin.gif Показал он себя как очень ласковый и очень мягкий (на 160а даже брызг не замечал)варил электродом уони(3мм)С наступающим новым годом. Желаю чтоб завершили все свои поделки в старом 2014 и были готовы к новым творческим открытиям для себя. support.gif
Wasiliy61
Спасибо за пожелания. Так а малыш-то ведь кажется не косарик, а полный мост- если я ни чего не путаю. Вот он себя так ласково и ведёт.
sergey777.68
KSV
Цитата(sergey777.68 @ 27.12.2014, 14:08) *
Я когда KEMPI ремонтировал, проверял на балласте, и действительно, когда отрываешь держак с болтом от балласта дуга совершенно другая, мягче. Те KEMPI были двухтактный полумост, сделаны на одной сборке ,25кГц. Но у моста есть один существенный недостаток, транзисторы кончаются в два раза быстрее icon_biggrin.gif
DANTIST
Цитата(sergey777.68 @ 27.12.2014, 13:42) *
...Показал он себя как очень ласковый и очень мягкий (на 160а даже брызг не замечал)варил электродом уони(3мм)...
Электрод 3 мм, ток 160 А, брызг не видел... С закрытыми глазами варил, что ли? А видео есть? Или поверить на слово? icon_biggrin.gif
VOVA 555
Тоже хочу присоединится к поздравлениям . Всех с наступающим Н Г хочу пожелать МИРА , удачи , здоровя , чтобы ваши желания ( хотелки ) всегда совпадали с вашими возможностями . Ну и само соброй творческих успехов и чтобы знаменитый на здесь Бах шарахался от вас , как от маестро Гонзыы icon_biggrin.gif .
KSV
Цитата(nikon @ 28.12.2014, 7:52) *
Для себя уяснил что топология не играет решающей роли. Собрал малыша AVT. дуга мягкая шипящая, варить одно удовольствие. Дроссель намотан на 50м колечке не понятного происхождения 32 мкг, частота 40 кгц. Особенно приятно варить тонкий металл, вероятность сквозного прожога намного меньше чем у остальных собранных мной аппаратов.
АВТ это тот же косарь, а по поводу двухтактов или косых в противофазе , многие говорят, что варят мягче. Мне уже потом мысль пришла, посмотреть , что у этих КЕМПИ на выходе под нагрузкой, дросель там стоит на Ш железе. Наверное всё познаётся в сравнении. Меня давно тянет на двухтакт, только полумост почему то, я сварку qaki не раз начинал делать, и не раз заканчивал, но пока только в мыслях icon_biggrin.gif
ingener99
Цитата(nikon @ 28.12.2014, 21:19) *
А я собирал, и после того как спалил 2 диода забросил это дело. Только позже узнал что нужно было ставить более высоковольтные а не 150EBU02 которые я ставил.
Странно, в двухтакте обычно как раз напряжение меньше на диодах. А EBU02 даже в косом стоят нормально.
Basill
Цитата(KSV @ 25.12.2014, 21:06) *
надписи на плате, утюговая технология?
Боюсь показаться занудой, но не советую слишком увлекаться маркировкой на плате по методу ЛУТ. В состав тонера, говорят, может входить графитовый порошок, магнетит и т.п. А это ненужная электропроводность. И если после травления меди мы его удаляем как выполнившего свою функцию, и его свойства нас далее "не колышат", то здесь он остаётся. Поскольку мы работаем с напряжениями поболее нескольких вольт, то зачем нам ещё одна лотерея и риски? Шампанского захотелось? Так Новый год для этого есть icon_biggrin.gif .
В производстве маркировку ПП делают краской с диэлектическими свойствами. Если очень хочется маркировать красками не вручную - осваивайте любительскую шелкографию, есть форумы в инете. Кстати, навыки работы с фоторезистом там очень пригодятся.
С наступающим Новым годом всех!
И пусть приходящий год будет лучше нынешнего.
KSV
По идее маркировать или даже на переднюю панель , то можно и плёночным ФР, пользуюсь давно, только импортным Ordyl ALPHA. Как то при накатке испортил (первый раз делал ещё без ламинитора) и оставил на балконе летом, потом смою и через неделю только наждаком можно было "смыть". Вот и возникла идея на переднюю панель использовать, но пока что то руки не дошли до эксперементов.
Serega30
Всех с наступающим ! В сервисе Толяна на входе (по схеме) UF4007(1А/1000V/75нс), зачем такой запас по напруге, и чем можно заменить ? Спасибо.
oleg1ma
Cтавь любой, 1n4002-7 там тоже будет работать.
ingener99
Ибо эти "low cost" диоды обычно используют в самых дешевых устройствах типа энергосберегаек и о быстродействии речь совсем не идет
rcmk
А накой там быстродействие? Чтоб за зарядом электролитов поспевать? icon_surprised.gif
ingener99
наоборот, чтоб успевать разряжать времязадающий лит за те очень короткие промежутки времени, пока в дуге КЗ
rcmk
Мне почему то кажется, что если посчитать постоянные времени RC цепей, то быстродействие диодов на фоне полученных величин получится весьма и весьма великолепным. Емкость 100 мкф и сопер 220 Ом дают возможность забыть о быстродействии диодов. ИМХО.
pansim1
Не менее 10 сварочника сделал с антистик по схемку Толян
Всегда ставил диоди М7 - 1N4007 в СМД изполнение
Работают прекрасно!
peter49
Bcех с Наступающим! Пытаюсь собрать Бармалейник на 165а. По схеме в снаберной цепи стоит 40ом.5вт.,ау меня есть 23 и 50 ом. Какое лучше поставить? А кондер в этой цепи 5600пф. Спасибо,что ответили
Velgosh
ребята а есть ли смысл у силовой мост добавлять по два ключа? и как будет выглядит схема?
Velgosh
Цитата(kleverbig @ 30.12.2014, 12:15) *
А зачем в мосте по два транзистора icon_rolleyes.gif ? Или что имелось ввиду?
так вот из за етаво и спрашываю http://radioskot.ru/forum/3-1824-5 (Сообщение # 46)
nikon
Так речь идёт о косом а не мосте. Но смысл есть всегда для увеличения площади теплоотдачи.
Wasiliy61
С настутающим! Хотел поздравить Форумчан песней, в исполнении моего друга-но время не умолимо, перетрёс все старые бобины, и не нашёл .Разрешите новогоднюю байку. Лет 35 тому, приходит ко мне друг с гитарой- он в то время на танцах играл, и говорит -Васёк, есть такая песня-вот послушай. Когда я её прослушал, я оболдел от смысла песни, и от исполнения- он умел в то время преподнести. Песня именно для друзей. Вскоре мы собрали консилиум у меня, и записали песню в две гитары- через самодельный ревебратор, на магнитофоне с дополнительной головкой, и песня вообще зазвучала класно. Но время -увы. Встретил на днях друга, и спросил у него, он ответил- да врят-ли и у меня сохранилась, да и вообще я лет 30 гитару в руки не брал- сказал он. Старею потихоньку продолжил он, что со мной твориться не знаю, чихнёшь- очки спали, пукнешь- трусы слетели, засмеялся и пошёл. И я остаток пути смеялся над Юриным постарением. Пришёл домой, и сказал жене как Юра постарел, а она отвелила- да иди ты, а то ты не знаешь этого баламута.
УВАЖАЕМЫЕ ФОРУМЧАНЕ, от всей души , и от чистого сердца я поздравляю ВАС с наступающим Новым Годом, желаю счастья, крепкого здоровья, успехов и всего всего...., а ребятам с Украины ещё мирного неба над головой. Пусть для Вас (друзей) прозвучит эта песня, конечно не в Юрином исполнении, но Гриша её тоже исполнил достойно. С уважением Василий. За байку простите- а то развёл гимогогию.
http://youtu.be/lH2OLrIxMic
KT117
Сергей_74
Ээээ где ж ты раньше то был?? Сегодня попробовал эту бумагу, результат просто офигенный, быстро, качественно и без геммороя. Спасибо за информацию!!!
С наступающим всех, творческих успехов в новом году и доступных по цене деталек..
Serega30
Цитата(rcmk @ 30.12.2014, 0:33) *
Емкость 100 мкф и сопер 220 Ом...
На п.п, что я делал, вместо резистора (220 Ом)- дорожка (перемычка). И ниче, работает. P.S: Шаблон на п.п. не я рисовал, здесь кто-то дал готовый.
rcmk
Ну тогда тебе сам Бог велел ставить UF4007 иначе не успеет кондюк разрядитсо icon_biggrin.gif
DANTIST
Всем Бармалеестроителям, и не только, творческих успехов в Новом Году и большого человеческого счастья!
Wasiliy61
Ребята, да оторвитесь Вы от своих дел, гляньте какую я себе сверлилку для плат урвал по случаю- на базаре сегодня попал на новогоднюю распродажу- в драку, едва досталась.
Ребята, да с Новым Годом Всех- МИРА, СЧАСТЬЯ и ДОБРА ВАМ. Пост не цитировать- шутку потом уберу.
cot
kvaka
Здрасти народ вот и пролетел ещё один год. От солнышка - тепла, от людей - добра, От друзей- верности. Счастья побольше, жизни подольше. Молодости вечной, теплоты сердечной! И поменьше БАХОВ. Сделал себе очередную игрушку по схеме Липина на платах Олега. Можете ругать!
KT117
icon_smile.gif Да ты такой-сякой, да у тебя корпус квадратный, а кулеры круглые, И проводочки медные (где урвал? ) а детальки фирменные.
А в остальном молодца! Удачной сварки в Новом Году!
kvaka
Цитата(KT117 @ 31.12.2014, 17:45) *
icon_smile.gif Да у тебя корпус квадратный
Нет вот здесь позвольте он не квадратный он ПРЯМОУГОЛЬНЫЙ. Больше длинный чем широкий.
