Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
владимирон
Цитата(Wasiliy61 @ 18.4.2013, 20:54) *
А какой ширины лента, если 32-35мм то хватит на первичку. А количество витков от сечения провода не зависит, а зависит от частоты на которой будет работать. А от сечения сердечника зависит.
ну не знаю раньше мотал трансы на 50гц так там чем больше площадь железа тем меньше витков чтоли на феритах другое
Wasiliy61
Да нет тоже самое. Я подумал Вы про сечение провода. Извиняюсь.
oleg1ma
Примерно тоже самое, но вот зависимость мощности от сечения ферита не так выражена, как в железе.Как пример тор R63 с сечением всего 3см2, спокойно выдаст 200а на дуге.
владимирон
такое дело намотал пробную обмотку проводом 0,8 мм 18 витков первички ток хол хода 95ма питалово 220в а потом попробовал лентой толщ 0,1 ширина 3,5см 18 витков изоляция между лентой фторопласт напругу через латр так уже на 25вольтах ток под 200ма чо за хрень перематал 2 раза такаяже байда а вот осцила на резюке 1 ом питание 220в как по калькулятору лысого скажите как она это 18 витков провода 0,8
Lomaka
Доброго всем времени суток.
Убил уйму времени но так и не смог найти в темах как сделать силовой транс для 165-ки на кольцевых ферритах. кто нибудь делал такое?
slavyann
ломаешь кольцо или пропиливаешь, как любит Олег, мотаешь 33/11 равномерно
Lomaka
Если я его сломаю, его ж надо потом склеить с зазором. Какой зазор должен быть у сломанного кольца?
А вот пропилить, это мне более по душе. И какой ширины сделать пропил?
Кстати я хочу сделать в 2 кольца, их как потом сложить, пропилами в разные стороны или в одну?
slavyann
если ломать, то зазор делаешь исходя из необходимой индуктивности, на шашках ставят чек с банкомата; если пилить, то Олег советовал на 2/3,
а зачем 2 кольца ? если у тебя 63-е кольцо - то до 200 А хватит, или мало ? icon_smile.gif
oleg1ma
А почитать форум, что-бы поменьше вопросов которые неоднократно поднимались и вот, что удивительно - найдете даже чем клеить кольца и чем красить. icon_biggrin.gif Как пилить тута писал, диск желательно не более 0.5мм толщины, слаживать кольца можете, как угодно или по феншую.
ingener99
можно ничего не пилить и не ломать, если частота высокая (> 50...70кГц)
kvaka
Олег. Вы мне не ответили. Вся управа потребляет ток 80мА. С драйверами поднимается до 110мА. Это нормально??
Транс 1- 75витков.Первичка разделена на 2 части.
oleg1ma
Как Вы измеряете потребление драйверов непойму.У меня по цепи +12в потребление не более 180мА. по одному каналу 25В драйвера 50мА, по другому 90ма. Общее потребление 12 х 0.18=2.16Вт; 25 х 0.05=1.25Вт;25 х 0.09=2.25Вт, всего 5.66Ватта.
Lomaka
Немного не понял, пилить кольцо нужно не до конца, а лишь на 2/3 площади сечения?
Нет, у меня кольцо 100*60*15 мм у него площадь сечения в половину меньше чем у Ш65 вот и решил взять 2 штуки.
не получилось прочитать 8 тем по 600 станиц (( спасибо за ссылку
владимирон
уважаемые ответе пожалуйсто на вопрос в посте 16016
slavyann
у вашего кольца сечение такое же, как и у 63-го, т.е. 180 А можно вытянуть,
НО, надо знать какая у него проницаемость.
насчет пилинга - смотрите ссылку Олега.
Wasiliy61
Серёгин, добрый вечер -есть вопрос к вам.
Wasiliy61
Цитата(Серёгин @ 20.4.2013, 0:36) *
Добрый .Если знаю ,отвечу .
Тот антистик что мы обсуждали, он у Вас тоже до конца не глушит шим. У меня полность не глушит, ключи конечно он разгружает.
Lomaka
проницаемость 2000 НМ
Я так понял для кольцевого транса площадь сечения сердечника нужна значительно меньшая... Это радует.
Серёгин
Да , на одном аппарате не до конца глушит ,примерно до 25-30 ампер ,
для пробы так сделал. А на другом полностью глушит.
Wasiliy61
А Вы делали трёх обмоточный ТГР, если да то как он в работе, не хуже 4ёх обмоточного.
владимирон
ФЕРРИТ КОЛЬЦО 100*60*10 PC40 скажите на таком можно транс силовой намотать для 165а
Серёгин
Трех обмоточный не делал .Не знаю как работает.
nikon
Мне потребовалось подобрать стабилитрон по напряжению пробоя, чего не требуется при 4-х обмотках, вот и вся разница.
Wasiliy61
Понятно, спасибо.
kvaka
Цитата(oleg1ma @ 21.10.2011, 16:15) *
Вот доклепал очередного "липинского клона" на заказ.В этот раз поставил дешевые 50U, частоту снизил до 36кГц.Уже неоднократно выставляю на обозрение этот сварочник для повторения желающим, хотелось-бы отметить хорошую повторяемость этого девайса и отличное качество дуги(мягкая и варит 3-кой от 40А).Еще не маловажная деталь - это стоимость девайса, не более 100баксов на все, включая кабеля, байонетные разьемы,держатель и т.д.Правда корпус делаю сам, остальное на рынке и инет.магазине.[/img][/img][/img][/img][/img]
Олег подскажите размеры корпуса.
oleg1ma
Те размеры уже невспомню, вот тут посмотри.Это я отсылал Игорю(Gor) эскизы для изготовления корпуса, кстати у него их можно и приобрести.На фото можно посмотреть тут
kvaka
и ещё вопрос. для повышения тока резистор на 15 ноге тл надо увелитчивать или уменьшать??
oleg1ma
Задавайте правильно вопрос, для увеличения тока нужно применять прошивку с нужным током, а резистор тот, что на 15ногу 494 служит для установки правильного показания тока по индикатору и шунту или КЗ.
владимирон
уважаемые сваркостроители ФЕРРИТ КОЛЬЦО 100*60*10 PC40 скажите на таком можно транс силовой намотать для 165а ,бармалея
oleg1ma
Можно, но частоту нужно задрать где-то до 70кГц.
владимирон
а счем это связано
oleg1ma
Мало сечение и при меньшей частоте пропорционально будет уменьшатся ток, на частоте 40кГц к примеру более 130а думаю не снять.
Lomaka
парни дайте пожалуйста ссылку где обсуждали глубину пропила кольца силового транса. никак не пойму откуда взялась эта величина в 2/3, почему не до конца пропил?
saschai
Доброго времени суток коллеги!
Подскажите пожалуйста, где лежит схема и прошивка на данный вариант? Как я понимаю, Бармалейчик на 100А с управой на меге8.
Можно в личку, если есть архивчик.
Благодарю!
картинка1
картинка2
картинка3
oleg1ma
Все найдете тут, нужно только почитать немного.
Lomaka
Цитата(nikon @ 20.4.2013, 20:42) *
Я для этого аппарата кольцо сломал и склеил, полет нормальный.
была мысль по поводу жесткости, но я её отмел, думал чтото серьезнее.
толщины клея хватает для зазора?
владимирон
ФЕРРИТ КОЛЬЦО 100*60*20 PC40 а на таком можно или в 2 штуки как я понимаю на кольце место для намотки больше и мотать легче в плане выбора сечения. а количество витков такоеже как на ш-образном
Lomaka
Бегло прочитал почти всю тему в архиве, в итоге еще сильнее встал в тупик. Ктото пишет что зазор нужен лишь для уменьшения количества витков и в косом мосте он вообще не нужен, ктото утверждает что без зазора феррит уйдет в насыщение и транзисторы сразу бабах. помогите разобраться пожалуйста.
И еще один момент, как и должно было быть, я нечаянно сломал феррит не пополам а на 2 части по 90 и 270 градусов. Их смело можно на свалку отправить?
Wasiliy61
У меня Е70 тоже одна половинка сломанна, я склеил суперклеем-работает нормально. Мне подсказали на форуме.
oleg1ma
Вставь чек с банкомата с каждой стороны и склей, будет работать, некоторые склеивал из трех частей, в косом работают превосходно.Делал тр-сы разные и с зазором и без, и баха совершенно небудет ежели он правильно расчитан.
kvaka
Олег. Закупился я по случаю транзистрами Stgw45hf60wd теперь чешу репу а пойдут ли на 140А или всёже лучше G80N60UFD??
oleg1ma
владимирон каждый раз пишеш разный размер кольца, определись наконец-то какие у тебя кольца.
Подойдут.
владимирон
такие есть в продаже 100-60-20 и 100-60-10 какие лучше взять и сколько и что значит PC40
oleg1ma
А зачем тебе такие громадные кольца, когда можно взять такие какие нужно тут на форуме в разделе барахолка и по нормальной цене.В профиле укажите с какой Вы планеты.
Lomaka
вот именно. А как его расчитать, я не знаю. На 100% я не уверен в характеристиках своего кольца icon_sad.gif Всякие калькуляторы Лысых и Волосатых предпологают наличие косого моста, но ведь я его еще не сделал! Поэтому свойпервый транс решил смотатьиз 4-х строчников 3000НМС который уже посчитан и проверен. А дальше, как я понял, с помощью собранного аппарата можно из любых сердечников мотать трансы.
nikon
Lomaka, вас уже не раз просили указать с какой вы планеты, и что за проблема вообще с сердечниками. На форуме полно готовых решений на разных сердечниках. Для лысого не обязательно иметь готовый сварочник, нужен генератор с регулируемой частотой. Лично я обхожусь без него.
ingener99
Да не нужно ничего рассчитывать, мотаете пробную обмотку сколько влезает используемого провода в 1 слой и включаете в свой мост, а электролиты в сеть через лампу - только обязательно сигналы на затворы ключей (от отдельного БП) надо подать ДО включения моста в сеть. Если что - лампа все сохранит и позволит оценить потребление.
Lomaka
все, кажется дошло. я принципиально не с того начал собирать своего бармалея. Походу силовой трансформатор надо делать и настраивать только после удачно сделанных остальных элементов.
Исправил свой недочет.
klementiu
В принципе в аппарате всё присутствует. Но от всяких неприятностей никуда не денешься. Особенно порадовали выпрямительные диоды производства Ташкентского завода "фотон" . Не подумайте чего(сам такой!)-- без мысли подколоть.
klementiu
В этих диодах ни чего плохого не вижу ( в своё время конечно) они были не хуже разроботок именитых фирм. Тем более ,что там они стоят "военной" приемки. Вот тоже, что бы не пропадать добру намотал транс силовой. Феррит будет от строчников 6пар.Нажмите для просмотра прикрепленного файла
