Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Kalin Ivanov
Я знаю для предохранителя ,ани там временно.
DANTIST
Цитата(Kalin Ivanov @ 6.5.2013, 9:29) *
Вот некоторые фотографии моей работы остается снабдить меня с другими элементами,и найти информацию о :Тр-1 ,Тр-2 ,Тр-3
Kalin, "...найти информацию о Тр-1, Тр-2, Тр-3" - это, видимо ошибка перевода? Как можно делать печать и практически полностью ее распаять, не имея трансов?
Ты собираешь 100-ку Бармалея? Если так, то на схеме указаны все данные по трансам. Сердечники, витки. Какая еще информация нужна? Как эти трансы мотать?
Посмотри вот это. Может пригодиться.
Да, если есть возможность, сделай, пожалуйста, хоть одно сфокусированное фото.
Kalin Ivanov
Я думаю, что собираются, Бармалея 165 ! ТР1 сделает с ферритовым Ш7х7.
iceland
Kalin, для начало можеть быть выложишь схему по который собираешь. Многие вопросы отпадут. ТР1 и ТР2 наверно трансформаторы дежурки и ТГР. Они мотаются на Е25 с вертикальном сердечником, а ТР3 силовой. Наверное стоит сделать его на Е65. Все ето есть в comet. Сначала запусти дежурку, она на ТОР224. Данные про трансформатор такие: первичка 67 витков, Ф0,2, вторичка 8 витков Ф0,8, обмотка связи 8 витков Ф0,2. Мотаешь сначала пол первички, потом вторичка, обмотка связи и наконец остальная часть первички. Индуктивность первички около 650-1000mkH, подбирается зазором.Дежурка должна выдавать 14V. А етот штырь, который припоял для ТТ случайно не железный?
Kalin Ivanov
Большое спасибо за ответ, что меня интересовало!
И плата к схему,катора которые я положил .
Да ета болт 4мм.
Aleksandrov
Здравствуйте сделал все в корпус поставил две пары ключей на затворах резисторы 2.4 ома транс оставил тот же ток ограничил на 160 амперах. Теперь все чинно варит не шумит ничего тишина сжог сначала 1 элетрод ощупал все холодное дальше уже пошло 6 электродов тройки снова ощупал снаберы потеплели далее две четверки ощупал только снаберы нагрелись (теплые).Ключи холодные диоды тоже чуть теплый дросель. транс ледянной. Спасибо друзья за помощь.Теперь ему предстоит поработать чуть подольше,но все же буду контролировать первое время. по нагреву.Ручка поставил с посветкой от компьютера валялась решил приспособить на бармалейник.Просто не было другой.решил сделать из чего есть. Корпус распилиный древний комп Каркас из алюминивых уголков.Размеры примерно с три блока компьтерного ,большеват конечно но для первого раза пойдет мне не на себе его тоскать.)))
Wasiliy61
Нажмите для просмотра прикрепленного файла Коллеги кто знает как расшифровать эту надпись в ферритовом эквиваленте.
tranzistor3102
Kalin здраствуйте печатные проводники где будет проходить большой ток(диодный мост .входные конденсаторы .силовые транзисторы) нужно усилить медной луженой проволкой а иначе долго не выдержат перегорят а так идете верным путем. удачи. icon_biggrin.gif
Kalin Ivanov
Спасиба,я усилится.
kyzmi4
1)трансформатор дежурного бп:
седечник-Ш7х7 2000НМ
Зазор в сердечнике-0,25мм на каждом керне,расчетный-0,5мм.
1-100 вит диам.0,28мм
2-14 вит диам. 0,8мм
3-15 вит диам. 0,28мм
Мотается так
1: половина первички
2: вторичка
3: половина первички
4: обмотка питания
2) трансформатор драйвера ключей:
Все обмотки по 35 вит диам.0,36мм
Намагничивающая и размагничивающая мотаются параллельно в два слоя между затворными.
3)трансформатор тока 2 кольца К20х12х5 М2000НМ
90 витков 0.335
DANTIST
Цитата(Aleksandrov @ 6.5.2013, 14:26) *
...далее две четверки ощупал только снаберы нагрелись (теплые).Ключи холодные диоды тоже чуть теплый дросель. транс ледянной...
'Aleksandrov', ну ты шутник. Или сделал вечный двигатель. Может он у тебя еще и в сеть отдает электроэнергия в процессе сварки?
Когда работаешь 4-кой, из сети (не у тебя) потребляется порядка 25 А. А ты поставил на сеть разъем компьютерный. Зря. Тем хуже, что он может выскочить в самый неподходящий момент. И ХЗ, как дальше себя поведет аппарат.
Что еще. Из каких соображений ты поставил регулятор тока рядышком с разъемами? На лице же полно места. Для прикола? Крутить же неудобно.
Считай это товарищеской критикой. То, что аппарат заработал и работает неплохо - это хорошо. Удачи!
zato4nik
Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла Каталог магнетикса можно скачать http://ferrite.ru/products/magnetics/
ingener99
Если трансформатор после 8 электродов становится ледяным, то это опасно, т.к. может образоваться конденсат и замкнуть высоковольтные цепи схемы. Нужно предусмотреть подогрев трансформатора...
Aleksandrov
это образно сказано просто каким был таким и остался может чуть нагрелся)))
На счет отдачи в сеть электроэнергии не знаю не проверял и незнаю как проверить помоги а вдруг и правда вечный двигатель .Разместим схему тут вечного бармалейника. icon_biggrin.gif Регулятор поставил потому что это кажется что там место есть просто за стенкой этой стоит транс диоды с радиаторами дросель почти вплотную место оказалось только между выводами резистор помещен в экран и в проводе экранированном . а то что все холодное это нормально делал с запасом все что дросель что обмотку транса.А на счет разъема компьютерного так он гараздо больший ток способен провести. Это мелочь уже сгорит поменяю Тем более сварка мне нужна только так скажем тут прихватил там. В общем напрягаться он не будет сильно.Но думаю и под напряг будет все нормально.Стоит четыре кулера два на ключи один на всос другой на выхлоп Один стоит на на диодах и четвертый 120-тый стоит на всос в корпус.И все это дело продувается всеми четырьмя кулерами на сквозь зацепляя и транс и дросель ключи диоды подумываю воткнуть маленький на обдув сенаберов.ТАК ЧТО НЕ ШУТНИК Я!!! к ДЕЛУ ПОДХОДИЛ СЕРЬЕЗНО. За весом не гнался Поэтому и размер корпуса с 3 блока от компа.и вес 5 кг.А то что у вас греется транс ну тык это экономия феррита и проволоки.ТУТ ВАШИ КОСЯКИ У МЕНЯ ТРАНС СЕРЬЕЗНО намотан.65 проводов 0.6 6 витков и пять проводов 1.2 мм 18 витков все в норме на четырех половинках E65.И прокипячен в эпоксидной смоле.И я никогда не мотаю на отечественном ГОМНЕ типа строчников и так далее только epcos и только он.запас по току огромен Но я его ограничил пусть все работает как должно работать а не то что везде перегрев валит.Да вот что еще все кулера и подсветки запитаны от отдельного блока питания точно такого же собрал их два.Радиаторы(хотел медную подложку под ключики но не нашел шинки медной) тоже стоят не не маленькие и не деленные пополам у каждого нагревательного элемента свой радиатор полноценый (кроме диодов выходных)Отсюда и размер Удачи вам !На то и форум чтоб критиковать это помогает устранять все косяки,но и слишком это уже не критика.А то что раз бахнули ключики так это от не доделки не настроил ток ограничения и плюс к тому же использовали длинную тонкую по сечению переноску подключенную на соплях.Для первого раза думаю не плохо получилось.Еще раз спасибо за помощъ тем кто(реально) помогал.
DANTIST
... За весом не гнался Поэтому и размер корпуса с 3 блока от компа.и вес 5 кг.А то что у вас греется транс ну тык это экономия феррита и проволоки.ТУТ ВАШИ КОСЯКИ У МЕНЯ ТРАНС СЕРЬЕЗНО намотан.65 проводов 0.6 6 витков и пять проводов 1.2 мм 18 витков все в норме на четырех половинках E65. И я никогда не мотаю на отечественном ГОМНЕ типа строчников и так далее только epcos и только он.запас по току огромен Но я его ограничил пусть все работает как должно работать а не то что везде перегрев валит.Да вот что еще все кулера и подсветки запитаны от отдельного блока питания точно такого же собрал их два.Радиаторы(хотел медную подложку под ключики но не нашел шинки медной) тоже стоят не не маленькие и не деленные пополам у каждого нагревательного элемента свой радиатор полноценый (кроме диодов выходных)Отсюда и размер ...
'Aleksandrov', ну чё ты сразу обижаешься? Аппарат действительно серьезный! Даже, мне здается, немного перебдел. А вот вес видимо, определил на глазок. Или 5 кг - это вес транса? Или пустого коробка? Все-таки "...3 блока от компа" - это не шутка! Подожди, ты имешь ввиду 3 системных блока или 3 блока питания?
А чего ты так погорячился и силовой транс мотнул на 2-х комплектах Е65? Частота , что ли, совсем маленькая? Транс греется в любом случае. Большой, маленький, на одном комплекте, на 2-х... На ХХ греется больше.
Столько радиаторов, вентиляторов. Вспомнил. Я как-то тоже сделал аппарат (2-го Бармалея) с 5-ю вентиляторами. Вот это был кабан! Не чета твоему. Фотку покажу. Зверь. Где-то трудится... А может и в утиль пошел уже...Все-таки лет 5-6 назад было.
Кстати, можешь показать нутренности аппарата? Если не секрет?
tranzistor3102
приветствую всех на форуме.всегда интересовал 1 вопрос. ток идуший через обратные диоды HFA15tb60 в схеме бармалея165а примерно равен с током который идет через силовые ключи?просто есть диоды hfa08tb60 можно былобы их использовать заместо hfa15tb60.
oleg1ma
Можно ставить в аппараты до 130а.
DANTIST
Откуда ж там такой же ток, как через ключи. Ток ключей идет в дугу, накачивает дроссель по пути и по ходу дела намагничивает транс. А диоды только перемагничивают транс. Здается мне, твои диоды потянут. Можешь прикрутить какой-нибудь радиатор.
"...всегда интересовал 1 вопрос..." - это полгода? За это время можно было найти и перечитать кучу теории по инверторам Valvola или Multika.
Олег, не отвлекайся от аппарата!
RUS5610
15 диоды на размагничевание,а 8 на снабера.
ingener99
встречалось в одном аппарате (ММА 200А) в качестве размагничивающих диодов баяны из 3-4 штук UF5408
Серёгин
Приветствую всех ! С ПРАЗДНИКОМ ВСЕХ ! С ДНЁМ РАДИО !
tranzistor3102
DANTIST здраствуйте а почему полгода? он всегда меня интересовал. когда я начал заинтересовываться самодельными сварочными инверторами .теорию я читал но на практике как обычно все виднее.
Aleksandrov
DANTIST Да я не обижаюсь нисколько не девочка же icon_biggrin.gif Внутриности покажу чуть позже не охото вскрывать милион саморезов icon_biggrin.gif вот как найду датчик температурный так с фоткаю выложу внутрение кишки.Кстати где можно дернуть датчик температурный на замыкание В продаже нигде нету может посоветуете где стоят такие ??? На счет размеров я говорю что с 3 штуки блока питания комповских а не корпусов комповских icon_biggrin.gif Зачем бы мне такой гроб собирать с трех корпусов системных ахренеть это же тысячник тогда icon_biggrin.gif
DANTIST
Не, Aleksandrov, все-таки у тебя не серьёзный подход к собирательству аппаратов. Детальку припаял - сфоткал. Трансик мотаешь - пофоткал. Вот это подход. А то тут иногда проскакивают такие вопросы по моточным изделиям... Последние 10 волосин дыбом встают!
А по поводу термостатов зайди на сайт Kosmodrom. Я у них как-то покупал. Давненько, правда. Были у них и на замыкание и на размыкание.
TSL2
Ток через размагничивающие диоды равен току намагничивания силового транса. Так-что смело ставьте HFA08. Сам такие ставлю в AVT-ку. Нагрев практически никакой. А в снаббера транзюков и 3 амперных вполне достаточно. Хорошо работают HER508.
Wasiliy61
У меня в снабберах стоят по 2шт HER508, работают отлично.
TSL2
Ставлю по одному, полёт нормальный. В сотке Бармалея вобще одноамперные стояли, и ничего. Главное не нарваться на перемаркер. Как-то взял 10 штук HER308, пока вёз домой в кармане, практически у всех стёрлась маркировка. Рисковать не стал, применил в другом деле.
Aleksandrov
На будущее буду иметь ввиду что фоткать как то не привыкну к этому То забудешь фоткнуть то не охото Надо завести себе такую привычку.
Wasiliy61
Коллеги, правда ведь ерунда какая-то с буржуйскими ферритами, чёт заитересовался, почитал и у многих стран [компаний] один и тот-же цвет означает разную проницаемость.
p210
Хотите ГОСТ-ов? Так они есть. Но в каждом монастыре - свои. icon_biggrin.gif
Aleksandrov
http://ferrite.ru/ вот сайт феритов заказывал именно тут быстро не дорого за пять дней привезли авторейдингом расстояние 2000 км от меня за доставку всего 210 рублей отдал не мучайтесь а закажите да и все.Правда один минус заказ должен быть не меньше 1000 рублей.оплата через сбербанк можно и через другой кому как удобно.Разместил тут думаю не нарушил правила сайта
DANTIST
Цитата(Aleksandrov @ 7.5.2013, 12:57) *
...Кстати где можно дернуть датчик температурный на замыкание В продаже нигде нету может посоветуете где стоят такие ???
'Aleksandrov', я нашел термостат. Как раз для твоего аппарата. Смотри! 1NT01F-6329 Термостат, термопредохранитель Температура включения, °C: 2…8. Температура выключения, °C: -10…-2. Тип контактов: NO Рекомендую! Можно поставить на силовой транс. И цена смешная. Всего 20 грн.
Только зачем тебе лишняя запчасть в аппарате?
Вот несколько фоток моего 2-го Бармалея. Первым была 100-ка. Тут тоже пара фоток с нее. В корпусе из-под какого-то звукового генератора. Гораздо меньше, конечно.
Обрати внимание на силовой транс. Твой, по сравнению с ним, младенец! На вторичке 120 проводов 0,6 мм с петли размагничивания.
Wasiliy61
Да ферритов дома много, просто надо опредилиться на чём сделать.
Aleksandrov
толку то от твоих сто двадцати проводов тебе гобариты сердечника не позволят их использовать на полную шутник. а с дачиком поставь его себе на свой апарат младенец есть и поменьше твоего если ты решил похвастаться. а в петле размогничивания с телека (если ты об этом то там стоят провода 0.4 мм )так что твой супер нагревающийся аппарат сделан со всеми нарушениями . И вообще чего ты прицепился .С такими не интересно даже общаться.Хотя чего тут говорить запорожье говорит само за себя. Приходилось мне общатся с такими одним словом совки гнилые, и если ты как ты ранее варазился ОБИДЕТЬ то врядли у тебя это получится ,меня может обидеть только интелентный человек к тебе это не относится.Удачи
Wasiliy61
Товарищи, а если намотать ТГР на 2ух кольцах 20*12*6 проницаемость точно не знаю, но похоже они не для в/ч. так как стояли в цветомузыке. Там их 5 шт.
RUS5610
Часто пользовал термо датчики с НЗ контактами через реле повторитель.Запитываем реле через термодатчики,а контакты НЗ реле на вход таймера.
Aleksandrov
Спасибо.за совет
DANTIST
Ну вот, уже и обиделся...А говоришь, что тебя может обидеть только интеллигентный человек. Значит я этот человек и есть. А ты - нет. В 5-ти предложениях сделал кучу орфографических ошибок. Для безграмотных,- Запорожье - это название города. И должно писаться с заглавной буквы. Или ты хотел меня этим обидеть?
А ты, вообще, откуда?
Пиндюрок малоразмерных я никогда не стремился делать. Но всегда стремился к тому, чтобы внешний вид аппарата соответствовал его содержимому, и аппарат был максимально удобным в эксплуатации.
Хотя, зачем я тебе все это пишу... В петлях размагничивания, отечественных телевизоров, ставили провод 0,6 мм.
Ладно, будь здоров, Aleksandrov!
Напоследок покажу тебе еще один свой аппарат. Из крайних.
Wasiliy61
Молодец, есть на что посмотреть. Каллеги что-то мы стали ругаться, давайте по дружнее будем, ведь у нас общее дело, БАРМАЛЕЙ.
sergey777.68
Aleksandrov
Ну что ж я рад за тебя что на старость то лет сбылась мечта (сказал бы кого) но думаю сам допетрешь ведь ты же взумал проверять на орфаграфию,стало быть понятно что докапаться тебе не до чего вот и ищешь разные не влияющие на жизнь аппарата ляпы. но ты посмотри ты его создал с третьего раза и и с более жизненом опытом .А я его сделал с первого раза и на ток поболее твоего.и все сделано на коленке А не с помошью заводских примочек.Был бы ты человеком не говорю уже про интелентность ты бы не стал писать так. Про провод тебе тоже написано лаковая изоляция сними ее и смотри провод.О чем я и писал совок далеко забытых 80 годов. Если честно запорожье оно и африке запорожье хоть с большой буквы хоть с маленькой.И тебе не кашлять!
P.S Ну и на последок хочу тебе ДАНТИС icon_biggrin.gif сказать теперь я понимаю почему падают самолеты,думаю ты догадаешься о чем я.
Серёгин
Прошу прощения что встреваю , но я много лет занимался ремонтом телеаппаратуры , в петлях размагничивания идёт провод 0,3 с небольшим .Измерял микрометром в нескольких телевизорах , так как
сам делаю из них трансы к сварочникам .
tranzistor3102
можно попробовать вот так как на схеме .требуется 1диод 1резистор 1 термо датчик с НЗ контактами
Aleksandrov
О чем я и говорю.Видимо телеки в запорожье выпускались по спец заказу. icon_biggrin.gif
Серёгин
tranzistor3102 . Такая схема включения отлично работает у меня на 100-ке .
Wasiliy61
Серёгин, добрый вечер. Провода скручиваешь в лицендрат, или как лентой.
Серёгин
Добрый вечер.
Пробовал и так и так .Но ещё делал шлейф на малярном скотче ,делается долго и муторно ,
но потом очень легко мотается и места немного занимает .Последний раз делал на резонансник , на вторичку ,получилось 14мм2 , проводом 0,3 .
Wasiliy61
Цитата(Серёгин @ 8.5.2013, 0:40) *
Добрый вечер.
но потом очень легко мотается и места немного занимает .Последний раз делал на резонансник , на вторичку ,получилось 16мм2 , проводом 0,3 .
Шлейф- это не скрученный пучёк проводов обвёрнутый мал.скотчем, да.
sergey777.68
В петлях размагничивания провода бывают разного диаметра все зависит от размера кинескопа (монитор или телик).
Серёгин
Цитата(Wasiliy61 @ 7.5.2013, 22:45) *
Шлейф- это не скрученный пучёк проводов обвёрнутый мол.скотчем, да.
Да , это просто по очереди приклеиваешь по одному проводу на скотч , на липкую сторону ,без зазора между проводками , до нужного сечения , а потом сверху ещё один скотч .
