Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
шумный
Какой спор разгорелся. Для определенной работы нужен свой инструмент, это всем извесно. Если надо варить метрами, то аппарат не может быть маленьким. Если варим сантиметрами да ещще на мачте то малютка в самый раз. Так я думаю хотя могу и ошибаться.
RUS5610
Не мужики 3-4 электрода это не сварка.Как минимум хотябы 10 электродов до остановки по перегреву.
strannicmd
шумный
Вот фотосы моего творения,
А что за синие электролиты по сети? Они имеют около 5 выводов? Как они себя ведут? Похоже у меня такие-же, вот и интересуюсь, как они в сверкальниках ведут себя...
RUS5610
Привет Слава! Как успехи?
ozzy
Цитата(Alex_rost @ 13.7.2010, 21:02) *
Прошу Выложить фото SPARKa 1600... есть вопросы по включению sg3525
дак тут http://www.electrik.org/forum/index.php?sh...st&p=133057
Alex_rost
Спасибо, почитаю
fantom-2011
Я с вами согласен. Судя по вашим фоткам корпус у вас не маленький и кулеров нормально стоит. Я думаю что-то с расчетом силового трансформатора или дросселя напортачили.
RUN1
А зря вы Парни так на малышей давите в АТХЕ ))) вот этот например при токе 100А не хрена не отключается при темп.30С в тени ну трансик с дросселем конечно греются здорово))) Нажмите для просмотра прикрепленного файла
САНЕК
Цитата(шумный @ 14.7.2010, 18:05) *
Разбуди мужика на заднем плане,а то уснёт
Нормальный аппаратец.
олегу
[quote name='шумный' date='14.7.2010, 18:05' post='142490']
шумный
strannicmd
Конденсаторы PHILIPS 470мкФ*450В, два вывода.
САНЕК!, мужик не спит, просто смотрит в комп.
олегу
Дроссель как-то не так намотан
поясните что имеете ввиду. Дроссель намотан 24витка на бруске.
fantom-2011
поясните пожалуйста что имеете ввиду?
DANTIST
[quote name='RUN1' post='142546' date='15.7.2010, 5:27']А зря вы Парни так на малышей давите в АТХЕ ))) вот этот например при токе 100А не хрена не отключается при темп.30С в тени ну трансик с дросселем конечно греются здорово)))
RUN1, а скажи, пожалуйста, на сколько градусов стоит в нем термостат? Если он там, конечно, есть. И на чем он конкретно стоит?
А то я постоянно ставлю 75-ти градусные. Может я не прав? По sheetу с ростом температуры катастрофически падает ток через ключ. Или все ставят такие могучие ключи, что для них 100 градусов - мелочь?
RUN1
[/quote]
DANTIST да вроде термостаты как бы ставлю а то в друг антифриз закипит)))) на поршнях 70С а на диодах 90С ))) там у меня просто люминия в 2 раза больше чем у бармалея)) да трансик с ктр 4 почти намотан))
strannicmd
RUS5610,
Off Привет Руслан. Пока никак, времени катастрофически не хватает.., то свадьба, то похороны, то опять похороны... Се ля ви, как говорят японцы... icon_sad.gif
RUS5610
Чему быть- того не миновать.Все будет хорошо!
Дантист! при 15 витках на 50кгц какой ток намагничевания?
DANTIST
Лампа 100W еле теплится. Обычно его не измеряю. Падение на лампе вольт 30...40. Первое же включение через лампу. Если все гут, че мерять ток?
Сейчас заканчиваю аппарат. Гляну специально.
Теоретически, для Е65 и 15 витков ток намагничивания должен быть 2,2 А. От частоты не зависит.
OlegarX-RUS
В каком месте он не зависит????
DANTIST
В месте конечной формулы.
I1м=IWм / W1.
IWм = напряженность магнитного поля в зазоре х ширина зазора + Вm х Lср магнитной линии.
W1 зависит от частоты. Ты это имел в виду?
Вопрос был для конкретных витков. Чё тут умничать?
OlegarX-RUS
Конкретные витки зависят от частоту, что тут умничать
Wiew
Вы забыли что Вm зависит от частоты (длительности), при прочих равных условиях.
electrovoz
Все правы по своему. Дантист прав, что для 15 витков допустимый ток 2 А. Или 3. Или сколько там определяется шириной зазора. Потому что ток насыщения - это свойство индуктора, не особо зависящее от частоты. А остальные правы, что в конкретном девайсе может достигаться режим индуктора, превышающий допустимый ток намагничивания. Хотя насыщается он на любой частоте одним током.
sarmat
Sarmat, покажи как ты собрал внутренности.
На счет шести электродов - это ты погорячился. Зачем так насиловать аппарат, тем более в такую жару?
Есть печать нижней платы, улучшенной в плане охлаждения диодов. Плата свеженарисованная. Если есть желание, можешь попробовать.
[/quote]
Дантист, я в курсе насчет другой компоновки. Следующий будет как раз по этой печатке. Этот собран почти один в один по твоей конструкции. Только дроссель на ферритах от ТВС. Термодатчики от аккумуляторов переносных радиостанций (70 град). Кто-то упрекнул, зачем нужен такой аппарат, который срабатывает после 6 электодов. Попробуйте в таких условиях варить китайским аппаратом. Сами убедитесь, что защита там сработает раньше. Этот аппарат меня устраивает. В любом случае каждый останется при своем мнении.
Д713
"кто-то"-это был я,и придерживась этого мнения.
Серёга Я
Доброго всем дня. Разрешите новичку присоединиться к форуму и если возможно, то получить ответ на такой вопрос. Как правильно намотать Тр-2? Где-то на форуме читал что мотать нужно 4-мя проводами сразу.Заранее благодарен.
igorka
Всем привет!Жара задалбала!Обращаюсь к пользователю "кадет"уважаемый вы мне както подгоняли схемку осциллографа Ф4372 за что спасибо!А,нет ли у вас схемки на внешний делитель к нему,ато меряет до 150в максимум(маловато)буду признателен!
RUS5610
Дантист спасибо. Я всегда думал что 2 а намагничевания это много и всегда стремился его уменьшить,т.к сердечник нагревается на таком токе прелично.
kadet
Извините, но чего нет, того нет...
golub
можно, но качество изоляции должно быть на высоте. Обычно так на кольцах мотают.
Lemm
намедни достался мне транс от неоновой рекламы - именно транс , залитый , весом около 6 кг . так вот проводил с ним опыты (там на холостом около 7 Кв на выходе) на пробой по изоматериалам . были : майлар , мгтф , обычный пхв и.т.д. Так вот - наш мгтф на высоте - держит как 2 слоя майлара (желтого) . а если еще и пропитать - за изоляцию можно не переживать .
petr0757
[/quote]
А кто бы спорил.
sorry
Nikolay80 а Вы приняли решение по поводу ТС180?
Nikolay80
To Sorry:
Да, принял. Буду брать. Только речь шла не о ТС-180, а о ТС-80 - сечение 7 квадратов, Окно - 13 квадратов. Парочку комплектов возьму попробую. Всё же удобнее чем кольца от феррорезононсников пилить...
Информацию нашёл здесь
http://www.radioman.su/pages/986/index.shtml
витя
Мужики подскажите обозначение термовыключателей которые дантист ставил.
sorry
Доброго всем здравия. Хотел сегодня посмотреть осцылки на выходе ТГР и драйверов. Может кто выложит для сравнения?
golub
1,2- фронт 100 нан и 1 мкс на клетку
3,4- спад
на картинках совмещены выход уски и затвор ключа с поданной силой, ноль- клетка вниз от осевой
только на 70 и выше.
sorry
3,4- спад
Спасибо за быстрый ответ 100нан это нагрузка драйвера? Я силу пока не подключал. Осцил не мой на работе хотел посмотреть форму, амплитуду и какая частота получилась. До этого делал в слепую без осцила какие установки сделать на осциле чтобы увидеть полный сигнал?
Д713
это 100 наносекунд на деление,горизонтальной развертки естественно.
возможна засада с "сидением" одного из выводов на корпусе.
САНЕК
Однако,мурашки по телу........................ :eek:Если не знать что 100 нан.
golub
засады нет, "сидение"- есть. В комплекте с ними кебрики трубчатые идут. Ставил и такие же, и такие.
Д713
какую поправку на силиконовые кембрики делать?
golub
у меня получилось 1,5-2 градуса. Он там кокой-то не совсем силиконовый, жёсткий и с диагональными насечками.
Д713
с учетом технологического разброса биметалла-это сущая ерунда.
Basill
С учетом их толщины, думаю, лучше сразу отложить в сторону. Скорость теплопередачи от радиатора к корпусу датчика из-за них получается черепашья. Не могу привести цифр, но субъективная оценка температурного градиента (с помощью миниатюрного пирометра, купленного по рекомендации Геннадия) приводит к такому выводу. Себе сделал так (уже приводил, кажется). Номакон можно (лучше) заменить на слюду:
sorry
Ну извините коль что не так. нанами ведь разные величины измеряют.
Попросил человека,чей осцил использовать хотел, картинку внятную не увидел поэтому спросил что и как делать. Осцил такой Нажмите для просмотра прикрепленного файла о котором спрашивал здесь http://www.electrik.org/forum/index.php?ac...&pid=139333.
Но у него я нашел раритетный осциллограф ЛО-70 и получил такую картинку Нажмите для просмотра прикрепленного файла на выходе драйвера. И то приятней чем обрывки сигнала с ОСУ-20. Может мне и этот аппарат собирать без осцила? Как говорится меньше знаеш - крепче спиш.
Д713
Попросил человека,чей осцил использовать хотел, картинку внятную не увидел поэтому спросил что и как делать. Осцил такой о котором спрашивал здесь http://www.electrik.org/forum/index.php?ac...&pid=139333.
Но у него я нашел раритетный осциллограф ЛО-70 и получил такую картинку на выходе драйвера. И то приятней чем обрывки сигнала с ОСУ-20. Может мне и этот аппарат собирать без осцила? Как говорится меньше знаеш - крепче спиш.
раритетный ло-70-ф топку.
то,шо повыше сойдет.
вообще-то хвастать положено не осциллографами и осциллограммами,а положенными швами..
заради чего все и делалось..
sorry
Полностью согласен, как только буду варить сфотографирую шов. Хотя швы мало кто выкладывает видел токио обычные бармалеевские и Ваши в аргоне. А с управлением по среднему - чтото не припомню.
bell
golub
не поспоришь. Но девайс полтора года в работе, однако, а ещё и на довольно хлипких радиаторах.
Д713
непонятно почему народ не пользуется аргоном,вроде все данные были уже неоднократно опубликованы.
а ведь это оч-чень неплохая технология..
или кроме калиток больше нет задач?
golub
апосля колиточные задачи обычно появляются с приходом пенсии. Трохи подождать осталось.
Да и баллон с аргоном как-то не очень эстетичен в коровнике или на огороде.
