Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
EVDOGW
Добрый день всем, дайте схему драйверов с отрицательным смещением. Благодарю заранее.
Анатолий
Цитата(fantom-2011 @ 4.3.2011, 19:56) *
А какие транзюки в ключах стоят ?
как по схеме IRG4PC50U
RomzesDn
подробнее ТУТ
Так же в сети много других схем, многие собирают схему от Мультика
Jorg63
смотрю на ветке Баррмалейчика,упорно игнорируется использование в качестве драйвера IR2110/13..Работает данный драйвер превосходно,одно небольшое условие,наличие доп.отдельного питания для будстрепной части драйвера.В качестве примера небольшой файлик.Это не значит что нужно его повторять,я просто хочу уделить внимание на прим драйвера.а реализация самой схемы каждый решает сам
P.S. С выходов микросхемы установить затворные резисторы 27-39 ома
RomzesDn
Тоже думал над этим ,всё хорошо, но сколько лазил по форумам, то даже "старые волки" затрудняются выжать с подобных схем больше 100 А, приходится ставить промежуточные транзисторы для раскачки ключей, тоесть, микросхема служит только как ТГР, только гальванически не золирует управление от силы.. К тому же, резко возрастают требования к монтажу, т.к. микросхема это помехонеустойчива ,а на таких мощностях помехи не хилые.
Это всё ИМХО.
Jorg63
Это всё ИМХО.
согласен,вопрос реализации имеет с данный микрой определенные нюансы..Но правильно вып разводка покрывает все неудобства.Я с данной микрой работаю уже давно и проблем у меня с ней нет.Ставлю как в полумостах так и в мостах сварочных инверторов и ни разу меня не подводила.и меня удивляет почему вы уперлись в 100 ампер,все зависит от мощности ключа,и что надо то и возьмете. поставьте 4063 ключ и 200 возьмете ампер. затворную емкость микра держит успешно 5-10 нан,без ущерба в работе и ухудшения фронтов при послед резисторе 27-33 ом
oleg1ma
Согласен на 100%, сделал себе для дома сварочник qaki, пашет нормально, ключи народные 50UD.Сеть дома не ахти, но тройкой и варит и режет, так что микруху нужно использовать, цена копейки и избавляет от геморойной намотки ТГР.
EVDOGW
Цитата(RomzesDn @ 5.3.2011, 19:43) *
подробнее ТУТ
Насчет резисторов можно их заменить номиналы:
430 на 470 Ом;
4,3 на 4,7 кОм?
Лопух
... меня удивляет почему вы уперлись в 100 ампер,все зависит от мощности ключа,и что надо то и возьмете. поставьте 4063 ключ и 200 возьмете ампер.
С чего это вы решили, что здесь делают только на 100 ампер? У меня давно и успешно работают и на 160 и на 180 ампер. И на один. И не только у меня. Здесь многие такое делали и делают. И зачем IR с ее проблемами и отсутствием гальванической развязки, когда Бармалейник без проблем делает тоже, только надежнее. Или та же фикса, еще проще. Тоже на 180 ампер работает без вопросов. Только далеко не каждая сеть выдаст такой ток. Так что смысла нет в 200-х амперах, только возле подстанции варить. Ну нравиться вам IR и в добрый час. По мне, если уж выбирать, так лучше HCPL3120 или HCPL3180, чем IR2110. Не требовательны к разводке, проще некуда и плюс гальваническая развязка, плюс блокировка при снижении питания. Все в одном флаконе. Красота!
P.S. Здесь народ перепробовал уже все, что можно, и старожилов форума не удивить чем-то, типа драйверов от IR или аппаратом на200 ампер. Кстати, приведенная выше схемка мелькала на мастер сити лет несколько назад и бахнула ЕМНИП на 140 амперах. Автор от нее отказался, вследствие ненадежности.
RomzesDn
430 на 470 Ом;
4,3 на 4,7 кОм?
4,3 Ом на 4,7 кОм? Нет ,нельзя..)))) Если 4,3 Ом на 4,7 Ом - думаю, проблем не будет. 470 Ом вместо 430 Ом думаю тоже не критично. Я не автор данной схемы ,и я не собирал её..) просто вы попросили помочь с поиском - я и помог..)
Скажи, а у тебя между микрухой и силовыми ключами есть какие-нибуть промежуточные звенья? Интересно было бы глянуть на исполнение и схемку.
EVDOGW
[quote name='RomzesDn' date='5.3.2011, 22:56' post='173767']
4,3 это кОм...
Alant6262
А из каких соображений 27-33 Ом ? Интересно, т.к. ставят и 10 и 5. Особливо применительно к указаным Вами ключам
igorka
мужики а скиньте плиз печатки драйверов у кого есть поблочно
Alant6262
А 6 сообщений вверх? Там ссылка
Jorg63
Есть такой нюанс как выброс напряжения отриц. полярности на 5 ноге по отношению к 2 ноге микрухи,вот резак и давит колебательный процесс.Эти резаки косаемо мостов и полумостов,но я думаю в косарях тоже возникает этот выброс.
tnttnttnt
Мужики всем привет!!! ПО вчерашним вопросам- Конденсатор поставил 1,5мкФ 250в К78-2 работает классно,ни нагрева,ни габарита по сравнению с сопротивлением попал с первого раза 110в. По поводу отключения управы и индикации светодиодов - горел все время СТОП-не пропаяна 3 нога таймера 555, отключение происходило по тому,что не правильно подобрал замену диода вторичной обмотки транса блока питания стоял НЕR 307 сильно грелся в течении минуты блок питания работа нормаль потом мгновенно откл. и вкл. через секунд 10-15 опят и так без конца, впаял родной бармалеевский все ок стало.
Дальше вопросы!
Осцилограмма Сток-Исток нижнего ключаНажмите для просмотра прикрепленного файла Напряжение 220в 10мкс дел. Хочется услышать мнение норма или нет???
А потом вот так временами,что это?????Нажмите для просмотра прикрепленного файла
Вроде как фон какой-то, даже радио сбивать начинает шипением. Может быть из-за не пропайки резистора драйвера ??? после баха обнаружил не пропайку,да кстати бах случился после постукивания по плате искал где-что и шевелил компоненты.
Еще эта аномалия начиналась проявляться после напряжения питания по силе более 150в.
Итог : два ключа предохранитель 30А помойка! И отгоревшая дорожка
RomzesDn
Цитата(EVDOGW @ 5.3.2011, 15:00) *
4,3 это кОм...
Тоже думаю, не критично.
Дальше вопросы!
По поводу первой осцилы - как по мне - так нормально.
По второй... У меня такое было, когда сбивалась синхронизация на осцилографе, правда, он у меня старенький....) На вашем такого может и не быть... Это только на нижнем ключе или на верхнем тоже? просто если даже умудрится ( в чем я очень сомневаюсь) подать такой сигнал на ключик, то он быстро стрельнет даже при питании 100 В...
Люди, вот сейчас дошел до вторичных цепей силы (сварочные цепи). Нигде не могу найти выпрямительные диоды. Даже КД29ХХ нету в продаже ,чтоб баяном слепить. Есть ли возможность собрать выпрямитель хотябы на транзисторах? Типа таких ТРАНЗИСТОР или по два последовательно вот ТАКИХ
Или бред будет? Из чего еще можно состряпать выпрямитель или где можно в Украине купить?
oleg1ma
Зайди на ветку "Полумост, мост с конденсаторным баластом", там с 7 по 10 страницу я делал свой девайс и схема там.
Первый раз собираю одноплат, посмотрите при выключении у всех такая фигня и кто как с этим боролся, меня такое неустраивает.Извените за качество снимал телефоном.
Den2
Для RomzesDn
.Диоды можно поискать тут http://radiomarket.lg.ua/advanced_search_r...mp;x=17&y=9
tnttnttnt
Да у меня тоже такая неприятность самое обидное что реле в процессе выключения щелкает раз пять-шесть то есть износ у нее будет в шесть раз быстрее .
[quote name='RomzesDn' date='6.3.2011, 0:34' post='173855']
На втором снимал но не помню вроде не было настраиваю приемущественно по нижнему ключу на эта наводка или не пропайка была не знаю как обозвать на осциле пропадала и появлялась, бывало тускло,ели видно как бы на втором плане я еще думал может силовые провода наводку дают на мозги, все убрал по дальше тоже самое.
Серега 220
а у меня другая проблема слчилась. все работало нормально осцилки были в норме ну думал все скоро буду проверять при работе. нечаянно посадил соплю на базу и землю IRF540. подгорел резюк на 22 ома и началось ....таймер запускается нормально светодиоды стопа и работы работают но микрухи стали незначительно греться ...перепроверил всю обвязку, заменил микрухи диоды и та же картина .плюс к этому всему пропал сигнал с 6 ноги вообще!!!! тоже все перепроверил ....все детальки сменил,микрухи ставил с буквами N. DN(думал может че подгорело) ан нет тоже не помогло и она тоже греется незначительно. вот осцилка что сейчас на 6 ногеНажмите для просмотра прикрепленного файла пробовал убирать ТГР, не помогло.мерял напругу на UCшке относительно земли: 5-1- 1.48в;5-2- 2.49в;5-3 - 1.97В; 5-4 - 2.09В; 5-6 - 0В; 5-7 - 14,3В; 5-8 - 4.98В. Плата сделана как одноплат "Виктора.". мужики кто нить сталкивался с такой проблемой????
maxon
5-3 - 1.97В;
Если правильно понимаю то на 3 ноге у вас 1,97в. Если так то на 6 выводе и не будет ничего, так как при достижении напряжения на 3 ноге равного 1в микросхема блокируется. Смотрите обвязку 3 ноги.
ИМХО я бы не за контакты реле переживал, по сути они замыкаются и размыкаются в холостую (вилка то из розетки выдернута). А вот то что ШИМ тоже дергается не есть гут.
RomzesDn
Постарайся всё-таки посмотреть, что в это время на верхнем ключе творится... Я ж говорю, что может просто осцил выпендривался, причем, как бы я не экранировал от наводок. Если же в это время на верхнем всё хорошо - тогда будем дальше думать...)
Цитата(Den2 @ 6.3.2011, 0:21) *
Для RomzesDn
Я бы с радостью, но нету у них в наличии и неизвестно когда будут... уже обзвонил все магазины, что мне известны, все в один голос говорят, что IR их временно не выпускает, и сейчас типа можно купить либо неизвестный левак, либо только старые запасы...
oleg1ma
От многократного клацанья реле после отключения, у себя поставил конденсатор на 100мкфх16в паралельно база-емитер кт805 и увеличил сопротивление, то что на базу с 750 Ом до 4.3кОм.Клацанье пропало.
Лопух
Ага, а если в процессе сварки напряжение моргнет на пару секунд и в тот момент, когда релюха клацает снова появиться? Последствия могут быть непредсказуемые.
oleg1ma, вот так сделайте и забудьте Нажмите для просмотра прикрепленного файла Там если БП и икнет пару раз, релюшка не включится, а напряжение на банках будет вольт 50-60, уже безопасно.
oleg1ma
Цитата(Лопух @ 6.3.2011, 13:31) *
oleg1ma, вот так сделайте и забудьте Там если БП и икнет пару раз, релюшка не включится, а напряжение на банках будет вольт 50-60, уже безопасно.
Спасибо, сделаю, но в следующем, тут-то уже все запаял переделывать нетянет, прилеплю еще кондер для зарядки банок как у Вас, да может притулю стабилитрон на питание 3845, на этом думаю остановится, там покажет.
Серега 220
[quote name='maxon' date='6.3.2011, 11:56' post='173910']
проверил всю обвязку 3 ноги и отцепил ее вообще ( в воздухе) напруга 2,03В на ней есть. на выходе )6 нога 0В). что еще можете посоветовать? что проверить или поменять?
Лопух
Цитата(logic777 @ 6.3.2011, 14:16) *
объяснте пожайлуста:
Объясняю. Выложена схема Бармалея с его данными, в которой изменено только подкючение светодиодов и реле. При повторении схемы каждый руководствуется своими соображениями и даташитом. И 48% заполнения совсем не обязательно приводят к выгоранию ключей. Мало того, при использовании схемных решений, ограничивающих кзап на ХХ, максимальное заполнение только на пользу. Стабилитроны тоже бармалеевские, их выбор зависит от параметров вашего питания управы и ТГР. Разброс от 13 до 18 вольт. Если почитать даташит на используемые ключи, можно понять, почму так.
maxon
Не очень понял 2,03в на обвязке 3ноги, или на на самой ноге? В воздухе оставлять третью ногу по моему не особо правильно (мало ли какие наводки). З ногу на землю и смотрите что на 6.
кабельщик
Серега 220, одним микробом меньше...
Серега 220
сдоха микруха что ли?
2.03В на 3 ноге микрухи
RUS5610
под замену!
maxon
Меняйте микросхему, но предварительно проверив всю обвязку. Я перед тем как микросхему впаиваю сначала проверяю что она рабочая (надо то 1кондер и 3резистора), а то потом выпаивать геморно.
Серега 220
. у меня панелька запаяна. но проверять теперь тоже буду на всяк случай
maxon
Панельками пользуюсь только на макетке, а в готовое устройство предпочитаю впаивать намертво.
maxon
Вопрос к профи. Дошел до 6ветки но ответа на свой вопрос не получил. Объясните популярно процесс выключения силовых транзисторов и как именно цепь снаббера организует траекторию выключения транзистора. Нашел только в одном месте Гиратор отвечал на такой вопрос, но к сожалению кривульки удалены. А самому мне с МС пока не удалось подружиться, выскакивает "матрица сингулярна"
Серега 220
схема проверки такая ?Нажмите для просмотра прикрепленного файла
tnttnttnt
Цитата(Серега 220 @ 6.3.2011, 19:13) *
Не видно ни чего!
maxon
Нет. Так работать не будет. Нужно еще конденсатор с 4 ноги на минус ( это частотазадающий элемент). Да и для проверки микры не обязательно обвязка первой и второй ног схемой задатчика тока (все равно он работать не будет, пока не будет сигнала с ТТ на 3 ногу)
На резисторе R3 смотрите сигнал с микросхемы, меняя С1 и R2 подбираете необходимую частоту. Номинал С1 также будет влиять на Кзап. Чем меньше емкость тем больше Кзап и наоборот.
tnttnttnt
Цитата(Серега 220 @ 6.3.2011, 19:39) *
Совсем другое дело!!!
Серега 220
maxon
СПАСИБО ЗА СХЕМКУ БУДУ ПРОВЕРЯТЬ
RA6XOJ
http://www.chipdip.ru/product/b66371-g-x187.aspx кто что посоветует хочется примерно 160 ампер получить
RUS5610
Эталон! Ис Е65 с одного комплекта можно получить 160А, а с Е70 все 200А (только ключики соотв.)
oleg1ma
Вопрос не в тему:как увеличить мне размер в моем ящике для отправки сообщений и файлов на форум, а то уже использовал 49.5мегабайт и не могу отправить фотки.Подскажите.
Jorg63
Удалите все лишнее и будет свободное место.На жесткий диск надеюсь сумеете нужное перенести
Лопух
Да ладно, "траекторию выключения". Все просто. Когда управляющий импульс меняет полярность, драйвер разряжает затвор ключа, что помогает ускорить закрытие транзистора. В момент закрытия ключа в силу особенностей работы на индуктивную нагрузку, формируется выброс, этакая короткая иголка с напряжением значительно выше напряжения питания. Вот как раз этот выброс и глотает снаббер. Он уменьшает скорость нарастания тока. Это позволяет удержать транзистор в пределах ОДЗ. А вот весьма известный Чукча вообще не использует снабберы, зато использует ключи, ОДЗ которых позволяет обходится без оных. В общих чертах так, хотя и грубовато.
oleg1ma
Неправильно наверное написал.Хочу скинуть фото на форум и внизу когда хочу загрузить файл раньше писало макс. размер файла 2 мб, а теперь всего осталось из 50мб всего 470кб.Причем тут жесткий диск?
tnttnttnt
Дорого Очень Вот https://ferrite.ru/warehouse/2/1270/
Я открываю фото в паинте и уменьшаю размер фото процентов на 50.
RA6XOJ
[quote name='tnttnttnt' date='6.3.2011, 23:33' post='174022']
спасибо как я понимаю везде одна штука это одна половинка
