Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
UVM
Цитата(ГонZа @ 23.2.2012, 17:28) *
Приветствую всех на форуме.Вопрос знатокам:за что отвечает резистор 1,6ома по 3ноге(если ставлю 2ома-току меньше,если ставлю 1,6ома -току больше)?Если не прав,то поправьте.Извиняйте за глупый вопрос.Сегодня варил в гараже на хорошей сети,электродом 3мм и при половине оборота регулятора режет 4-5мм железяку.Уважаемые знатоки,подскажите,как проверить ток КЗ и рабочий ток?Я так понимаю ток КЗ -через амперметр и держак на массу?А рабочий ток-через амперметр и просто зажечь дугу?Если не прав,то поправьте.Очень понравилось как варит аппарат(по сравнению с тиристорным)!!!С уважением Гонза.
Вы русский язык в школе изучали?
После знаков препинания: ; . , ! ? и др., а тем более между предложениями нужно ставить пробел, иначе читать просто невозможно!
Да, и почитайте хотябы 1 и 2 часть бармалейной ветки и вопросов станет намного меньше, там всё описано!
kvaka
Люди подскажите. Uc3845 можно заменить на UC 3842. Про напряжение питания знаю.
oleg1ma
Сообщение №12315.
kvaka
Цитата(oleg1ma @ 25.2.2012, 15:45) *
Сообщение №12315.
Это сообщение я видел. Но каюсь не придал особого значения. Только я чёта запутался это как 100% ? Без мёртвого времени?
oleg1ma
Ну 100% на выходе3842 небудет, будет 98.Это к тому пишу, что Вам в бармалейник нужно выставлять частотозадающим конденсатором и резистором коэф.заполнения 0.42-0.44%, это для 3845 у которой 50% цикл, и врядли у Вас получится с 3842 тоже самое.
virgenijus
здраствуите люди, подскажите ето про бармалеиник 165А ставлю на баласт получяю 120А -16вольт ещо уменшаю сопротивление на три витка на выходе получяетса 100А-12вольт что ето может быт, как ето устранит стоким выходом ворить не будет. выходнои трансформатор Ш 20х28 -2000мн 2комплекта перв 18 вит х втор 6 витк.
oleg1ma
Что-бы понять, нужно еще и контролировать сетевое входное напряжение и на банках тоже, может сеть не в дугу, как говорят.
Серёгин
virgenijus.А какая у вас ёмкость конденсаторов(банок) по постоянке ? (по силе).
ГонZа
Приветствую всех на форуме. Серёгин , хотел поинтересоваться, как у вас дела с аппаратом? Я первенца своего обкатал с пристрастием! Родственник принёс тиристорный на переделку, ЗГ я уже собрал (как всегда на монтажке).
Серёгин
ГонZа. Приветствую вас ! Аппарат в процессе настройки .Частоту понизил до 57кГц. Пока не купил ключи, на 740 работает на прогоне на ХХ , ничего не греется . Пробовал немного грузить , до 20 ампер , ток регулируется плавно .
oleg1ma
Ключи могут стоить копейки если ставить в корпусе D2PAK(TO-273AA), дешево и сердито.
Серёгин
oleg1ma.Это конечно хорошо , но мне не нравится их крепление к радиаторам. К тому-же мне кажется, что у них хуже теплоотдача .
oleg1ma
А крепление проще простого, на кусочек медяхи 3мм толщиной, припаиваете пару корпусов, и вперед и с песней.
Серёгин
oleg1ma. Я такие вещи не практикую !
oleg1ma
Ну и зря.
ГонZа
Серёгин, а вы не знаете, чем можно заменить диод 1n5819(в магазине нет), а привезут только через неделю, и почему нельзя в место него поставить обычный диод?
Серёгин
ГонZа.Вот тут погляди тут есть SR . Я ставил они тоже Шотки.
OlegarX-RUS
SS14 (есть на материнках) ss12 тоже подойдёт
он не круглый а прямоугольный
Серёгин
Смотря куда ставить. Если в дрова то SS12 по напруге маловат будет !
OlegarX-RUS
если в дрова то да
Серёгин
Я ставлю SR.
OlegarX-RUS
ставьте кто вам не даёт!
Серёгин
Я про то, что , каждый собирает на тех деталях какие у него в наличии !
STASKIN
А где их взять то?
igorka
Здраствуйте,подскажите кому нетрудно,извините что не в тему.Вот схема http://saveimg.ru/pictures/25-02-12/7fe4e1...f90cbc11b64.gif Так как материал транса т.е марка феррита не известна количество витков в обмотках решил определить практическим путем с помощью (калькулятора лысого) последовательно испытуемой первички включил резюк 1 Ом и на нем осцилом смотрел пилу или треугольник (как правильно сказать,хотя тоже в разных случаях он то пила то треугольник) что б ток типо линейно нарастал.Осциллограмма была чуть кривовата то ли щупы звенели ну да ладно вроде ток линейно рос.При сетевом напряжении 230 В ток намагничивания транса составил 45 мА,ток потребляемый от сети составил 7,6 мА,все это было замерено при Коэф.зап.-0,06.Ключ имеет температуру порядка 60-70 С,все остальное холодное.Вопрос в следующем мне витки первичной обмотки при максимально возможном напряжением сети подбирать на минимальном заполнении импульса или же при максимальном заполнении?
Влад-Ко
А паяете сплавом Розе или обычным ПОС-61?
virgenijus
три кондика 470мкf х 400вольт на них стоит 300вольт
oleg1ma
И когда 120а, тоже 300 вольт?
Простым польским.
virgenijus
300вольт на халастом а на баласте падает 15вольт ето 285вольт
oleg1ma
Понятно, сеть нормальная.Когда на баласте крутите руль, ток нормально регулируется?И напишите какой резистор токозадающий стоит по 3 ноге 3845, и сколько витков в ТТ.
virgenijus
ток регуллируетса, на 3 ноге 3845 стоит 150 ом перед неи стоит 1,5ом один конец в землю. трансформатор ТТ 100 витков.
maxon
virgenijus на чем намотан дроссель, число и витков и индуктивность?
oleg1ma
Что-то здесь не то, при таком ТТ и сопротивлении, ограничение по первичке получается 66А, на баласте уже должен был стрельнуть.Какие ключи стоят и сколько и какая частота?
virgenijus
дросель намотан на ферит сточника телевизора 3000мн две половинки формы Н 18 витков
Ключи стоят SGH80N60UFD по одному в плече частота 40кгц ключи пока целы ну греетса быстро.
maxon
Может дросселек в насыщение влетает, отсюда и ключики нагреваются.
oleg1ma
Покажите свои оцилы на затворах.
virgenijus
От выходново дроселя может нагреватся ключики ? Что то мне неверися,опишыте как ето влияет на ключи.
maxon
Ну если не верится, то я настаивать не буду.
eger
попросили же покажи осцылы , если упр имульс корявый то ключи могут открываться медленней , отсюда нагрев ,как пример
zario
Цитата(ГонZа @ 16.2.2012, 23:55) *
Увеличить
Увеличить
Увеличить
Увеличить
Увеличить
Это мой первенец.Очень хотелось проверить работоспособность и повторяемость.Сейчас вижу,что не так сложно настроить хороший аппарат.Сегодня варил аппаратом-самое горячее это дроссель.В место транса на ТВСах подставлял транс на феррите от ОСки(первичка 36витков,вторичка 12).Аппарат работал,но упала частота(свистела дуга),а так как и на ТВСах.Серёгин,на одном фото видно монтажную плату,на которой делал ЗГ и всю разводку до ключей.
UVM
Ха-а, ещё один сварочник в чемодане!
Серёгин
virgenijus.Приветствую. Ну как, вы разобрались со своей проблемой ?
virgenijus
Выкладываю осцылу З-Е 5вольт дел 5мкс дел
ГонZа
Приветствую всех на форуме. zario,UVM вы зря прикалываетесь, главное что работает!
Серёгин
ГонZа. Не обращай на них внимания.
STASKIN
Цитата(zario @ 28.2.2012, 12:21) *
Чет я не увидел фото Ваших аппаратов icon_sad.gif ?
zario
в смысле?
STASKIN
Цитата(zario @ 29.2.2012, 8:03) *
в смысле?
Чтобы над чужим ухмыляться надо бы своими аппаратами ставить пример как надо делать! Ваших-то никто не видел icon_confused.gif: . Может стесняетесь?
virgenijus
maxon, что трудно челавеку пояснить если низнает, а не сразу настаивать не буду. Tак что там влияет с выходнова дроселя на ключики что они может грется.
oleg1ma
Ключи греются только когда нагружаете на баласт или на ХХ тоже?
