Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Д713
..если его разрезать на 2 части - получиться 2 шунта на 750А - 75 мВ или НЕТ ???
так резать не надо,бо получите две болванки из латуни.
резать правильнее в попендикулярном направлении относительно красной линии.
и далеко не факт,что получится два шунта ровно по 750А-75мВ.
skop224
oleg1ma, как-то я с Вами общался в теме "Однотактный ММА суправлением и сервисом на АТмега8" о феррите e65 и сколько с него можно снять тока. Тогда для частоты шим 80кГц Вы мне сказали, что количество витков получается равным 9/3. Так вот, тот аппарат я решил не трогать, а сделать еще один. На этот раз без МК и других наворотах (ну, кроме антистика). Так вот я его сделал, ключи fgh40n60, трансформатор получился очень коротким: феррит e70 количество витков 8/3. Соответсвенно получилось намотать первичку в один слой, а вторичку в два слоя. Первичка 6 квадратов, вторичка 30 квадратов. Частота работы шим 88кГц. Дросселя нет. Феррит на х.х. немного нагревается. Может быть еще немного поднять частоту?
Проблема в следующем: шим собран на uc3845 схема сдандартная бармалеевская, только применен компенсатор пилы. Резистор регулировки тока на 2,2 кОм. Так вот на минимальном значении тока трансформатор немного шуршит и напряжение на выходе поднимается на несколько вольт (по цифровому мультиметру с 87в до 94в). Дальше если крутить ручку резистора напряжение постоянно, и трансформатор не издает посторонних шумов.
Еще поставлен антистик электровоза на полевиках BSS138. Так вот он у меня вместо того, чтобы рубить ток, наоборот его поднимает (к примеру при залипании электрода, поднимает ток с 30А до 170А). Что может быть?
oleg1ma
Скиньте схему по которой ваяете, для лучшего понимания.
denis25
Мужики у меня такой вопрос: можно ли на выходе Бармалейника использовать емкость для лучшего поджига, скажем так 470 мкФ на 200В (опасно ли это и куда лучше поставить до дросселя или после), а то вот получилось у меня так что на выходе напряжение около 40В, трансформатор намотал 30 первички и 8 вторички..или лучше скинуть пару витков с первички напряжение ведь должно подняться? Спасибо
skop224
denis25, Чтобы использовать емкость нужен мощный резистор. У меня стоял 40Вт (набранный из 10Вт) на 5Ом. Но греется он как печка.
oleg1ma, сейчас нарисую схему.
Д713
для лучшего поджига емкости на выходе не нужны.
denis25
[quote name='skop224' date='14.10.2012, 23:30' post='252147']
то есть конденсатор поставить можно но с ним последовательно необходим резистор мощный..т.е. получается резистор с кондером последовательно и это всё подключаем на клемы сварочника параллельно, а куда лучше до дросселя или после?
oleg1ma
после
skop224
oleg1ma, вот схема. Еще вопрос по ней - можно ли схему термо защиты подключить к первому выводу uc3845?
mono
Не надо парится с емкостями и резисторами, проще отмотать первичку витков 5, либо домотать 3 витка вторички, железо и частота какая?
denis25
частота около 35 кГц, сердечник - 6 строчников, вторичка намотана первой,первичка последней
oleg1ma
На полевичках скорее всего сделано ограничение на ХХ, встречал где-то, непомню, по 1 ноге и включают всякие защиты и блокировки.Вот посмотрите файл, как там реализовано.
Можно спокойно отмотать, до коеф.тр-ции 1/3.
mono
Частоту можно поднять, если ключи выдержат, если первичка последней намотана, значит проще её отмотать.
oleg1ma
Я на 6строчниках от ч/б телеков делал свой первый инвертор RytmArc, который был выложен в журнале радио, там частота 27кГц и моточные 21/7 трудятся досих пор.
kyzmi4
Я тож на строчниках собираю,первый работает уже года три....
Правда долго изготавливать транс,жгуты,намотка на оправку,пропитка эпоксидкой.....
Частота 33кГц помоему.
Vlasov
Просьба к oleq1ma.Если можно выложите пожалуйста вашу схему и печатки в лойоте на вашу спарку.Можно ли поставить по одному Е80 и как посчитать витки.Очень понравилась ваша схема спарки.
oleg1ma
Вот держите, а поставить е80 конечно можно, но где смысл? Это-ж какая громадина выйдет. Колечко стоит 2.3бакса одно, и влегкую выдает 100ампер, тоесть в спарке имеем 200ампер на выходе.
Vlasov
oleq1ma Большое спасибо.
oleq1ma не поделитесь секретом изготовления шунта.Отрицательное смещение на затворы необязательно.
oleg1ma
Шунт представляет собой полоску нержавейки шириной 19мм, длинной 27мм и толщиной 1мм.Раздвигаются тиски на ширину 12мм, ложится нержавейка, сверху хвостовик сверла диаметром 10мм и пару раз молотком по сверлу, для придания заготовки нужной формы.Шунт вставляется прямо в плату, так чтобы выступал со стороны пайки на 1.5мм и запаивается.С отрицательным смещением спарка не пошла, только как в выложенной схеме.
Vlasov
oleq1ma можно ли снизить частоту наспарке до 50кгц.и какой коффициент заполнения.
oleg1ma
Можно, у меня 0.43.
olegators68
Слушайте ГУРУ, приток в 100-200Вт погоды не сделает, зато жизнь как облегчите всем деталькам.
Vlasov
oleq1ma есть ли смысл поставить управу на атмега8 или это ничего не даст.
Vlasov
oleq1ma какой проницаемости кольца в вашей спарке.
oleg1ma
На схеме указан материал сердечника, Р4, нач.прон. 2200
Vlasov
oleq1ma я вам наверное уже надоел,но последние два вопроса.Прошивка Липина 140или180А.и подойдут ли IRGP4063DPBF на75кгц.
или прошивка ваша.
oleg1ma
Зачем вам 75кГц и такие мощные тр-ры в спарке, обьясните, я недоганяю.
Serg SP
Могу предположить, что 75 кГц - с целью снизить габариты моточных.
Насчёт IRGP4063D - снизятся потери на ключах, следовательно, и температура, следовательно, увеличатся и КПД, и надёжность аппарата. А для себя любимого переплата пары сотен рублей в угоду спокойного сна, - не вопрос.
Если для продажи - стоит задуматься, а надо ли оно...
oleg1ma
Я понимаю, когда делать простого косого, одной пары 4063 хватит на 180а, ну а в спарке зачем?Мощность так-же, как и частота на выходе удваиваются, зачем 150кГц, чтобы диоды кипели.
Vlasov
По поводу транзисторов-просто у меня других сейчас нет .oleq1mf хотелось бы узнать про прошивку.
Serg SP
Мощность потерь на диоде складывается из мощности проводимости (UxI) и потерь переключения (обратного восстановления).
При увеличении частоты в 2 раза потери проводимости останутся прежними, вырастут лишь потери переключения, а они обычно меньше потерь проводимости.
Кроме того, при частоте 75 кГц каждый из двух диодов выходного выпрямителя будет работать с частотой 75 кГц (выпрямлять один полупериод).
ИМХО, частоту выше 50 кГц лучше не поднимать. Это оптимум с точки зрения габариты/проблемы.
oleg1ma
Serg SP диоды горячее в спарке, вых 80кГц, чем в простом косом на 40кГц. при одинаковом выходном токе.
oleg1ma
Зазор делали?
oleg1ma
Да с зазором вы перемудрили, от того и ток такой, я на 40кГц мотаю обычно 33витка,мотайте вторички 10-11витков, работать будет на 50кГц нормально.
maxon
Цитата(Efisher @ 20.10.2012, 19:39) *
Ответте на вопрос и я его уберу.
Трансформатор на 63 кольце,частота в районе 45кГц,30 витков,ток намагничивания 7А.Пойдет,или большой ток?
Частоту увеличил до 50кГц,32 витка,ток намагничивания 4,5А.Если я намотаю вторичку 11 витков,пойдет?
Цитата(Efisher @ 20.10.2012, 20:50) *
Почти прорезал поперек,04мм,индуктивность1,3мген
Efisher при индуктивности 1,3мгн, частоте 40кгц (с заполнением 0,5) и питании от 300в амплитуда тока намагничивания не должна превысить 3А. При условии конечно что магнитная проницаемость сердечника не становится меньше чем начальная. Судя по вашим измерениям проницаемость все таки падает, а случается это либо при близости к насыщению сердечника (как вариант плохое размагничивание транса в паузе, и превышение расчетной индукции в сердечнике) либо при применении материала сердечника с отличной от №87 характеристикой зависимости МЮ от В. И помнится у вас изначально были проблемы с маленьким током намагничивания (из-за высокой индуктивности первички).
В качестве примера небольшая иллюстрация.
oleg1ma
Вот проверил проницаемость колец R63/38/25, разных цветов, что есть у меня в наличии.Т.зеленое продавали как материал Р4, салатное брал у толяна(видимо Р3), белое продавали, как материал 3С90.Проницаемость считал по проге, которую скидывал, намотав на каждое по 10витков: результат Р4=2675; Р3=1983;3С90=2377.
Serg SP
Логично. Вы же увеличили частоту в 2 раза.
ingener99
Если не трудно, посчитайте мои колечки (указанная прога не запускается на компе)
Индуктивность 10 витков = 1,22мГн.
Кольца К63 серого и белого цветов, добыты из сетевого 3-фазного фильтра мощного сварочного оборудования.
На одном уже собран сварочник (жесткий мост), фото транса, но о проницаемости до сих пор нет ни малейшего понятия)
Serg SP
gyrator, спасибо за развёрнутый ответ.
Что касается обратного диода при работе на общий дроссель: в двухтакте его обычно не ставят именно из за малой паузы (большем общем Кзап) и сломано немало копий в спорах, нужен ли он в двухтакте.
Могу сказать из опыта ремонта мощных буржуйских ЗУ по двухтактной топологии: там замыкающих диодов нет.
oleg1ma
Какой размер кольца?
KT117
Неплохо бы размеры колечек указать. Для кольца 63х38х25 при вашей индуктивности и 10 витках, программа мюКалк дает эффективную магнитную проницаемость 4928.811
ingener99
KT117
Сравнивая проницаемость вашего кольца и данные Епкоса, можно утверждать , что они сделаны из материала №30 , вот цитата из даташита Епкос по применению:
" – для дросселей фильтров питания, помехоподавления: N30, T65, T35,
T37, T38
Высокая начальная магнитная проницаемость, в сочетании со способностью
иметь ее высокие значения в широком диапазоне частот, обеспечивает данным
материалам преимущества при применении в импульсных источниках питания для
подавления помех, в частности, в синфазных (токо-компенсирующих) дросселях
Наиболее часто для помехоподавления используются сердечники марок N30
и T37 (ближайшие российские аналоги М4000НМ и М6000НМ1 соответственно)"
По применению в сварочнике-рекомендации дадут другие, я еще плаваю во всем этом icon_smile.gif
mono
Цитата(gyrator @ 21.10.2012, 13:45) *
В спарке однотактов этого не происходит из-за отсутствия магнитной связи между обмотками трансформаторов и необходимости размагнитить сердешник сбрасыванием тока намагничивания в источник.
А если намотать транс на одном кольце с разделёнными обмотками?
zario
вот что нашол: http://www.cqham.ru/ferrit.htm
mono
Цитата(gyrator @ 21.10.2012, 18:05) *
получим циркуляционный ток в первичке, который увеличивает статические потери в ключиках. Миниморум этого тока будет при разнесении первичек на разные половинки сердешника, но полностью избавится от него не получится.
Просто хочется мягкой комутации и не дают покоя две картинки, первая вроде срисована (не мной) с неплохого сварочника, а вторая вообще шедевр, но грамоздкая управа.
Фраемворк на компе установлен? Без него не запустится.
Serg SP
Вторая обычно применяется при высоком входном, можно использовать более низковольтные ключи в конверторе.
mono
Это бесспорный плюс второй схемы, но не главный.
tranzistor3102
здравствуйте можно ли заместо диода HFA16tb120 использовать диод HFA15tb60 durak.gif используемый в снабберных цепях
zario
ОБЪЯСНИТЕ ТУПОМУ, ТАКОГО КАК Я, для чего служит резистор на выходе
