Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
KSV
Цитата(kvaka @ 2.1.2015, 18:14) *
Ещё раз. Транзисторы оригинальные. ТТ в этой схеме отсутствует. Здесь шунт.Если фазировка не правельная то на выходе должно быть порядка 100 вольт.
100 вольт точно не будет, есть скайп, пиши в личку
kvaka
Скайпом не пользуюсь.
KSV
Смотрите осцилки, щюпом на начало, должны быть одинаковыми, по скосу видно будет, разница в амплитуде.
kvaka
Осцила с ключа.
KSV
Цитата(kvaka @ 2.1.2015, 18:27) *
Осцила с ключа.
Смотрите сдесь https://yadi.sk/d/2b_b5iikR5L6L специально снимал
kvaka
У меня осцилы практически такие же. Только я не снимал осцил к-э при полной напруге.
KSV
Если а Вал липинский, то можно и провода на шунт попутать, всё зависит от того где он стоит, в плюсе или в минусе
kvaka
Извените не знаю как вас по имени но фигасе? Зачем я фотки выкладывал зачем Олег схемы рисовал?? Шунт стоит в минусе. Схлопывание я проверял( когда чиркал электродом искр почти не было).
KSV
На фото схемы я посмотрел на драйвера, извините, а вы попробуйте ещё раз ОС, если ботнули транзисторы, то причина есть и одна из них, не сработала ОС. Я для проверки, управы на ТЛ494, подавал калибратором но провода, минус на провод к резистору 510 а плюс на общий.
ingener99
Аппарат должен выдерживать работу хотя бы некоторое время вообще без ОС, тем более при управе по среднему, иначе долго ему не жить.
kvaka
Вот снял дохляков.
Wasiliy61
Цитата(kvaka @ 3.1.2015, 21:36) *
Вот снял дохляков.
Слушай, прям как живые.
kvaka
Только все ноги в кз.
Serega30
kvaka, на подделки не похоже.
Ушедшие.
KT117
icon_smile.gif Ну ты и садист! Все ножки им поотрывал
sergey777.68
можно этим корпусам дать второй шанс. icon_rolleyes.gif все лучше чем мусорка.
Wasiliy61
Serega30 ни хрена- кладбище. У меня тоже как-то вылетал один, и как интересно-начал запускать аппарат через лампочку, а она горит- как будто какой ляп. Начал проверять- всё правильно везде, потом выяснилось что рекуперационный диод законтактировал с радиатором, скорей всего был заусенец. Диод чуть шлифонул, поменял прокладку, и всё равно лампочка горит, оказалось ключик покинул нас по тихому, хоть и через лампочку- а диод целый.
Serega30
sergey777.68
Serega30
sergey777.68, колоть, шлифовать надо, или... ?
DANTIST
Цитата(kvaka @ 3.1.2015, 14:36) *
Вот снял дохляков.
Kvaka, как говорил известный персонаж:- меня терзают смутные сомненья. А не перемаркер ли тебе подсунули? И вот этот крестик посредине поля маркировки... Не слева ли он должен быть?
Хотя... Вроде бы и ни чё.
sergey777.68
kvaka
А смысл??
KSV
Цитата(sergey777.68 @ 4.1.2015, 5:24) *
Сергей, а не проще на медную полоску припаять нужное количество, если на выходной выпрямитель, а разрядные особо и не греются.
Сергей_74
Цитата(kvaka @ 4.1.2015, 8:42) *
А смысл??
каждый дро...т так, как хочет
владимирон
добрый день уважаемые назрел такой вопрос . возможно ли из бармалея сделать индукционый нагреватель. если нет то ткните носом где есть чтото путние
DANTIST
Назрел вопрос... Т.е. зрел, зрел и, наконец-то, назрел. Может лучше ацетиленовая горелка. Дешевле будет.
Ну, если назрел, тогда посмотри пока тут. Дальше будет сложнее.
владимирон
просто лежит на столе бармалей собраный на 90 процентов вот и подумал о его целесообразности в качестве индук нагрев. а сложного ни чего не увидел не сложнея бармалея
DANTIST
Так, что, дальше показывать? Или и этого достаточно. Нагреть железку - это одно, а вот расплавить - это другое. Там нужно контролировать частоту резонанса и мощу. Точку Кюри пройдешь и ага. Не будешь же ты сидеть и вручную подстраивать. А если немагнитный материал расплавить нужно? Коронки там золотые, например. icon_biggrin.gif
ostap
http://induction.listbb.ru/viewtopic.php?p=14444#p14444
нет
владимирон
вопрос таки остался можно или нет приспособить бармалея
DANTIST
Тю! Я думал ты уже созрел для переделки. Сам же сказал, что не сложнее чем Бармалея собрать.
Бармалея приспособить можно. Только нужен двухтакт. Или нет... Думаю, ссылка Ostapa поможет.
Для принятия окончательного решения, посмотри еще вот это:
aog1996
Конечно можно. Как кашу из топора. Задействуем ключи с драйверами, литы и корпус. Накачивать индуктор энергией с помощью косого не рационально. Не проходите мимо ссылок от DANTISTа.
DANTIST
Владимирон, смотри окончание. Контрольный выстрел в голову. Чтобы окончательно отговорить тебя от твоей затеи. icon_biggrin.gif
Хотя, может автор и слишком усложнил все... Может быть все можно и проще сделать. Ну, даст Бог, разберешься. Вот только не знаю, куда 6-я часть задевалась. Может есть у кого.
Vs55
Ее, наверное, не существует. Во всяком случае я не встречал.
ingener99
Конденсаторы контура размещены не совсем правильно. Работать, конечно, будут, но с потерей добротности контура и неравномерной их нагрузкой. При параллельном соединении нужно в схему включать противоположные концы соединительных шин. Чтобы итоговое расстояние от каждой емкости до конца шин было равным.
kotofei
О выборе сердечника для силового транса. Я так прикинул, что ~десяток мониторов я смогу разобрать за 2-3 месяца, так что идею использовать их строчники пока отложил. Возможно, еще вернусь к ней. Пока что рассматриваю ЕЕ65 и ЕЕ70.
Кому лень искать параметры (габариты и т.д.) - см. тут: http://www.ferrics.com/en/ProductShow.asp?ID=61
Типовая конструкция "бармалея" - ЕЕ65. Видимо, исторически сложилось, или раньше только они и были доступны. 18 витков первичка.
Посидел с калькулятором. Обратная пропорция витки/площадь сечения центрального керна дала 14 витков для ЕЕ70. Правильно оценил?
С учетом бОльшего окна у ЕЕ70 мне не понятно, почему их не используют? Цена-то примерно одинакова, доступны оба.. или и так ЕЕ65 хватает?
Отдельный вопрос: монстроидные советские кольца, 125 или 135мм диаметром. Марка феррита 400НН или 600НН (продаван путается в показаниях) icon_smile.gif Сечение у них не большое, 2 таких кольца по сечению не дотянут до одного ЕЕ65, соотв. видимо и мощность ниже будет. А 3 шт таких колец уже дороже ЕЕ65+шпуля получается. Выходит смысла нет ?
ingener99
Цитата(kotofei @ 6.1.2015, 22:37) *
монстроидные советские кольца, 125 или 135мм диаметром. Сечение у них не большое,
Зато периметр большой. Т.е. объем феррита. Такая форма, кстати, очень хороша для улучшения охлаждения. Правда, ломать такое кольцо опасно - зона склейки мала, может отломиться склееное. На неломаном колечке 100мм есть опыт транса 30/10 на частоту 80кГц.
rcmk
Вопрос по интеграции примочки Толяна в бармалея
Как я понимаю в АВТ используется изолированный источник 18 вольт из-за шунта. поскольку нет гальванической развязки. В бармалее управа гальванически развязана. Так ли уж необходимо использовать отдельный источник 18 В ? КМК вполне можно ограничится тем же источником, от которого запитана управа.
Какие там подводные камни еще?
avlozitski
Не знал про такие параметры кольца
ERika
Ага, среднюю длину магнитной линии Lm знаю, про периметр теперь тоже буду - век живи, век учись.Тоже ведь геометрический объект, значит есть и периметр. А то как в детской шутке - опа есть, а слова нетicon_smile.gif. А если серьёзно, чем она (Lm) больше, тем больше магнитное сопротивление потоку, что приводит, например, к увеличению Iнам (что-то вроде введения распределённого немагнитного зазора) и увеличивает потери в сердечнике. Обычно стараются обойтись минимально возможной Lm в СТ. В данном случае думаю не критично.
Полностью согласна, когда смотрела фото данной конструкции, тоже этот момент про себя отметила.
Цитата(rcmk @ 7.1.2015, 13:32) *
Вопрос по интеграции примочки Толяна в бармалея. Как я понимаю в АВТ используется изолированный источник 18 вольт из-за шунта. поскольку нет гальванической развязки. В бармалее управа гальванически развязана. Так ли уж необходимо использовать отдельный источник 18 В ? КМК вполне можно ограничится тем же источником, от которого запитана управа.
Необходимости использовать отдельный источник питания как в АВТ для бармалея нет. Так что если религия (некоторым философам к примеру мешает, что управа гальванически связана с выходом сварочника, и пмсм что-то в этом всё же есть...) не запрещает icon_biggrin.gif, никаких подводных камней нет.
kvaka
Цитата(KT117 @ 2.1.2015, 20:46) *
А дежурка нормально работает? Может ключам для полного открытия напруги нехватило?
Здрасти всех с Рождесатвом ХРИСТОВЫМ. Сегодня нашлось время для инвертора. После проверок выяснилось что на одном канале питание 15 вольт а на втором 12 вольт думаю в этом и была проблема. Перемотал трансформатор дежурки. Получилось на одном канале 19.8 а на другом канале 19.4 теперь думаю проблема пройдёт???
oleg1ma
kvaka
Цитата(oleg1ma @ 7.1.2015, 19:24) *
Больше не поместилось. отказался от отрицалки.
KT117
А как же тогда осцилки на транзисторах были в норме? На затворах должно было быть видно, что размах меньше 16В. А дежурка нормальная?
kvaka
Дежурка 14.
Каюсь посмотрел форму а размах и не смотрел.
rcmk
Именно этот момент и настораживает. Но это на уровне чуйки, а она не всегда права поскольку всегда стремится перебдеть )
А практического опыта видимо ни у кого нет (((
TSL2
Как это нет? А Липинский чем плох...
avlozitski
А еще промышленные САИ
rcmk
Все бармалеи да АВТ перед глазами )))))
