Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
UVM
Дроссель не видно, он есть?
Дежурка на чём сделана, не греется?
delivero
дросел навит на ферит с диаметар 8мм 12витки шинка 3,5х2мм.
дежурка работает прекрасно она сделана с TNY268
RUS5610
Поздравляю !!! очень красиво!
Схема оригинал или есть свои дополнения? Если можно поподробнее и фото то что под платой.
delivero
я младши участник плоха говорит по руски.
извините меня.
схема добавляю утра.
толян
извините меня.
Говори по болгарски, мы поймём.
Dr. Санчес
delivero , красивый и аккуратный аппарат получился , поздравляю !
Силовой трансформатор стоит в стороне от вентилятора , сильно ли он нагревается при работе ?
dsv
Что такое х.х. ?
oleg1ma
Цитата(dsv @ 25.8.2011, 0:08) *
Что такое х.х. ?
Холостой ход, то-есть без нагрузки.
dsv
все ок андестенд
delivero
това ми е първи апарат в кутия от АТХ платките и схемите не са пълни.
разботя с PROTEL 99SE.
трансформатора Е55 не грее. греят силно IGBT и Диоди.
ето платките и схемите.
http://photo-zona.net/index.php?APP_ACTION...&IMAGE_ID=0
delivero
За IGBT съм направил платка от алуминиев матерял като на електрожените Gysmy. IGBT и диодите HFA15TB60 са запоени на нея за добро топлоотдаване. на снимките е показана: plat1
UVM
3,3n для 55kZ многовато будет, может поэтому IGBT и греется, осцилограммы не снимал, покажи если есть.
серж2105
Всем привет.Подскадите какое напряжение можно считать опасным для транзисторов 50 W под нагрузкой по 300 вольтам?или по переменке 220 вольт? Тойсть при каком напряжении не желательно эксплуатировать.Хочу определится с защитой от понижения наряжения.
UVM
Опасно напряжение при котором возможен останов дежурного БП, но это при условии что к.зап ограничен, обычно 0,44.
Lemm
лишь бы управление затворами не проваливалось ниже 12 вольт . так что обращай внимание на дежурный источник и защиту от пропадания 14 вольт .
stalker-dass
скажите а пойдет ли замена вых. дилда 150 EBU 02 на отечественный ДЧ 151
igorka
Мужики привет.Всех ШАХТЕРОВ Поздравляю с наступаюшим проф.праздником!Желаю чтоб все после смены выезжали на-Гора.Шахтар Лунае Гордо!Тут гдето,а может и не здесь мелькала идейка примастырить к инвертору формирователь "переменки" для сварки алюминия,может ткнете где,добился хто результата чи не?
Lemm
в далеком 2007 на форуме уже пробовали тулить их , они очень медленные и кипят .
dsv
подскажите сжимал феритове сердечники и отламал одно плече
yjriy
так приклей его эпоксидкой или еще каким-нить клеем. И цианопан тоже сойдет
dsv
потерь небудет всетаки зазор
ZPS
Самый оптимальный вариант это на мелкой наждачке наточить с ненужного феррита немного порошка и перемешать с эпоксидной смолой, после этого нанести немного этой смеси на излом феррита и крепко прижать рожик к телу. Вторую половинку так же нужно совместить с раненной для того чтобы раненный рог не ушел в сторону. Перемотайте все это дело изолентой (на время склейки) а как высохнет ее убрать.
yjriy
как не странно вам покажется, в таком случае качество шва на прочность значительно хуже. Лучше не применять никакие заполнители, чистый клей и все
А вообще-то феррит это и есть сплошные зазоры- в определенном понимании конечно. icon_biggrin.gif
Dr. Санчес
delivero Интересный в аппарате Antistik , при какой длительности импульса на выходе UC3844 он срабатывает ?
yura1976
Уважаемые гуру бармалеестроения! Помогите пожалуйста pain23.gif собрал аппарат из ветки "инверторный ПА" - в режиме ММА не поднимается ток выше 80А, дроссель подкидывал другой, перепахал обвяз, токозадающий резистор влияет, но незначительно, куда дальше рыть- не знаю crush.gif (проблема детально описана в "инверторный ПА").
oleg1ma
Вот доклепал аппарат, и сварка и Бп и если нужно то зарядное. Тр-тор ради интереса намотал на строчниках от черно-белых тв, на 2х комплектах.Завтра погоняю в режиме сварки, кому интересно что вышло спрашивайте.Если не понравится выкину и поставлю 63-кольцо.Частота 36 кгц и народные 50U, напряжение на выходе регулируется от 10 до 62в, ток буду уже завтра отстраивать.Вместо шунта применил полоску нержавейки 1х19мм длина рабочей части гдето 9 см.
p210
Конечно,интересно.Управление какое? А зачем 62 вольта? Просто хх такой?
oleg1ma
Управа см.сообщ.№ 11086 и 11088 стр.555, да такой хх.
delivero
Antistik работи тествах го когато настройвах управлението но за сега съм го блокирал и не го използвам в момента.
не мога да кажа при каква широчина на импулса сработва трябва да го тествам.
lapa
Цитата(yura1976 @ 27.8.2011, 15:27) *
.... куда дальше рыть- не знаю .....
Обычно пытают на 0,2 ома, а на 0,8 больше 50 А и не получите. Если заполнение максимально, то аппарат выдает максимальный для данной нагрузки ток. Для дальнейшего повышения необходимо снизить индуктивность рассеяния силового транса.
Серега 220
я тоже ради интереса сделал такой квадратный тор тоьлко на трех комплектах(90) но еще не испробовал....некогда icon_sad.gif .
yura1976
После пыток на 0,8 пробовал электродом 3 - плоховато варит, в смысле мало тока. Индуктивность рассеянья здесь вообще не причём - транс Е-70 многослойный и она минимальна.
soud
очень интересно как мотали трансформатор ?каким сечением?сколько витков? гоняли уже на сварке и какие результаты.
витя
Ливия... погляди что может ждать наших детей.
в тему отвечаем
delivero
Здравейте
какъв максимален заварачен ток може да се поличи от ферит Е55 със сечение 17х21мм при честота 50kHz помогнете моля????
80А....100А или 120А????
http://www.kaschke.de/ferrite/pdf/datenbla...erne/E55-21.pdf
благодаря
DANTIST
[quote name='delivero' date='31.8.2011, 13:31' post='198629']
Здравейте
Какие проблемы, брат? Что ты так разволновался? Та снимешь ты с него свои 120 А без проблем. Поставишь в обдув - думаю получишь и 100 % ПВ.
С одного комплекта Е80 люди по 160 А получают. А сечение там практически такое же. 20х20. Окно, конечно, поболее.
Куда-то задевал все свои расчеты по обмоткам. Ладно, сам посчитаешь.
wer_1
on line calclation
http://schmidt-walter.eit.h-da.de/smps_e/smps_e.html#Hdw
dsv
доброго времени суток намотал досель на железе получается такой здоровый подскажите ведь мотают на строчниках подскажите параметры количество витков сколько комплектов собираю прямоход. есче вопросик между чем на затворах смотрят осцилы
DANTIST
Я по началу не поверил своим глазам. Снова вернулся в форум. Да, 11153 сообщение. 11 тысяч сообщений, а люди до сих пор спрашивают на чем дросселя мотать. Да китайцы вообще дросселя не ставят на частотах больше 70 кГц. Хватает индуктивности проводов сварочных.
Какая у тебя хоть частота? Знаешь как её мерять?
Короче. Если частота меньше 50 кГц, возьми 2 комплекта ТВС Сложи их в "Н" и на горизонтальную черточку намотай витков 15-18 (сколько влезет) шиной или жгутиком проводов квадратов 12-16. Сколько не жалко. Будет что-то в районе 50 мкГн. Больше не надо.
Слушай, а здоровый - это в смысле размера или индуктивности? Да, блин, дела!
А я смотрю ты по-фене ботаешь. Прямоход, осцилы. А где эти осцилы смотреть не знаешь. Обычно осцилы смотрят между затворами и эмиттерами ключей. А еще между эмиттерами и коллекторами ключей.
Ну удачи! Думаю, она тебе пригодится.
Mazik
Меня тоже напрягал размер и вес дросселя (набор прямоугольных пластин от упсового транса) плюс к этому 2хЕ70 силовой транс, кое как корпус подобрал под это дело, дроссель мотал медным проводом диаметром 4,5 мм, с начало было 32 мкГн, сварка не понравилась, домотал до 70 мкГн - стало еще хуже да и дроссель сильно грелся, размотал я его полностью и намотал двойным проводом - получилось около 18 мкГн, варить стал отлично, на малых токах дуга не тянется, частота 37 кГц. Сейчас очень жалею что когда то много разного трансформаторного железа выкинул - дроссель получился отличный хоть и тяжелый, но и аппарат не слабый.
delivero
DANTIST Благодаря!
Електрожена ми в АТХ съм направил с 1бр. Е55 и до 90-100А заварява. Развалнувах се защото искам да получа 120А изходен ток но се страхувам да няма БУМ!!!!
При 55KHz съм го навил первичка 24нав. вторичка 8нав. зазор 0.1мм
сега ще сглобявам нов АТХ и трансформатора Е55 ще навивам с медна лента дано стане добре.
DANTIST
Я не все понял, что ты написал. Но, думаю, 24 витка для твоих исходных данных много. Оно хуже не будет, но зачем мотать лишнее? По моим подсчетам получается первичка 15 витков. Вторичка соответственно 5.
По какой формуле ты считал?
pansim
DANTIST, а ты по какой формуле считал? Для Е-55, при 50кхц, 15 витки первичка ето по моему екстрийм. Не путай человека.
delivero
Здраствуй Dantist
я навил Е55 18/6навивки при честота 55kHz лампа 75W тухнет. на халостом ходе работал осцилограми O.K. натоварил на баласт и бум IGBT 2бр. сгорели. потом навил 21/7 включил след 1час ферит Е55 на холостом ходе 60 градуса.
патом навил 24/8 ферит след 1час 48градуса и така включил и работает.
Basill
Интересно, как же тогда работает E55 в серийном аппарате Colt1300 (125A при ПВ15%). Правда, там феррит N97 и зазор, видимо, присутствует. Частота, если не ошибаюсь, 57 кГц.
delivero
моя траф е Е55 17х21мм сечение 360мм2
а в COLT 1300 Е55 17х25мм сечение ета разница 425мм2
DANTIST
Все свои аппараты я считал по общеизвестной формуле: n=10000 x U x 0,5 / f x 2dB x Ae, где 10000 - коэффициент, чтобы сечение подставлять в см кв; U=1,41xUсети = 320 В; 0,5 - максимальное заполнение (скважность); f - частота преобразования в Гц; 2dB - удвоенный размах индукции = 2х 0,3 (2 - это для хорошего феррита); Ae - сечение керна в см кв. Для данного сердечника = 3,57 см кв.
Ну и посчитайте.
Может проблемы с ферритом. Мне как-то попался кривой. Если не ошибаюсь Е80. Ставил 2 комплекта. Подсчеты сильно округлил до 12 витков. И все равно пришлось доматать до 15. В итоге я его таки выкинул.
