Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
витя
Если лампа до кондера то она нах не нужна и ничего не спасает.
В разрыв от кондера до транса лампу ставим.
владимирон
это знаем проходили
владимирон
есть ферит от блока питания компа ш образ 33 ширина 28 высота керно 12,5 на 10 на нем сколько мотать чего
slavyann
Цитата(владимирон @ 17.1.2014, 12:27) *
и зазор у меня на центральном керне 1 мм
с таким зазором из магазина можно вообще не выходить, прям там их убивать
опять неизвестный феррит с зазором ? сточите вы его нафиг и подгоняйте по индуктивности
Wasiliy61
Сердечник указан чуть не верно, вот расчёт на комповый феррит, высчитан двумя прог-ами, есть не большая разница, я бы поверил второй картинке, пользуюсь ей- хотя многие пользуются и первой-работают нормально. Зазор считается общий на 3 керна, но не как на один центральный. Это расчёт для 14 вольт, я делаю 15 волть Б.П. Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файлаВторичка указанна в 2е или в 3и жилы, мотаю всегда одним проводом-примерно 0,8.
slavyann
зазор считается по двум кернам
владимирон
этот без зазора
DJPashA
piexpert пользовать однозначно! В вашем случае получается сердечник ЕЕ33. Если в проге такого не окажется, можно выбрать ЕЕ35, т. е. в большую сторону а не наоборот. Мотаем что там скажут и главное соблюсти указанную индуктивность(зазором)(1мм вроде многовато, прога всё скажет). Эт он ещё "икает", чаще просто не запускается и всё. Но по моему 33-й для ТОР22х великоват. Рассмотрите ТОР24х-250. Витков меньше, мощи больше (пускай шепчет, не тужится) и кой-какие защитные примочки по желанию. Для него 33-й в самый раз. Конструктив - снаббер чуть "усиляется" и всё(+ 2 рез-ра и конд-р высоковольтная керамика).
slavyann
вот что говорит PI Expert
Wasiliy61
Да, пардон-я просто не так выразился, делится на 2, но одинаковый будет для всех трёх.
владимирон
все верно 10на13 мм керно ширина 33,5
все намотал по второй проге. витки индуктивность . при 170 вольт сапресор закипает сразу температура ползет за сотню нагрузка 300 ма вот индуктивность транса
Wasiliy61
Пришлось ключики садить с медной пластиной, радиаторы оказались силуминовые и я что-то побоялся за ключики.Нажмите для просмотра прикрепленного файла
DJPashA
В инете находим типы - размеры сердечников, раз такое дело, как например http://www.bec.spb.ru/soft_ferrites.html, находим свой по размерам, смотрим название. Выбираем его в пиксперте в меню. Если его там нет, выбираем ближайший по размерам той же формы в большую сторону нежели имеем на руках. Напр у нас ЕЕ33, если в меню его нет, значит выберем ЕЕ35. И главное индуктивность зазором!
Но для ТОР22х + ЕЕ33(35) там всё печально. А может какнить и получится.
Wasiliy61
Слушай, сердечник та помему EI, тогда и расчеты другие.
владимирон
ни чего не понимаю чего ему мало раньше делал 7на7 2000 ферите 100 витков сетевая зазор лист от принтера запускался с пол пинка 1,5 ампера держал спокойно сапресор был обсолютно холодный а это чо за хрень целый день убил а результата 160 вольт только чем еще считать незнаю и изменение индуктивности не к чему не приводит запускается от 63 вольти до160 все хорошо чуть больше сразу сапресор кипит
DJPashA
Он и будет греться. А если б взял сильно меньший феррит, феррит бы грелся, но работал. Габариты сердечника должны соответствовать или самоиндукция так и будет тебе отапливать жилплощадь. Я вместо ЕЕ29 ставил ЕТД39(он правда работал от розетки) но и то он грел снаббер не по детски(так выбросы и не удалось победить - переделал), а ты камаз буксируешь мопедом.
Wasiliy61
Для EI 50х6х6 и по 2ой проге 56х7х8 последняя сервис.
sergey777.68
Собирал на комп ферритах работают до сих пор и нагрева не замечал.1-40вит 2-6вит вых 22вольт.
Wasiliy61
Цитата(Serega30 @ 17.1.2014, 22:40) *
А что у Вас за печать...? Как-нибудь можно взглянуть ежели не в лом?
Я его выставлял, пост 19427 стр927. Там весь проект , шим, Б/П. две силы под такие радиаторы.
Я не собирал на EI-34 врать не буду, а на другом комповском б.п, на EI 28-собирал, работает изумительно. Как-то я с витками сильно не заморачивался, посчитал прог-ой, сразу мотаю первичку- и промазываю лаком, изоляция и остальние обмотки так, ни разу не перематывал. Правда с одним б/п. я повозился не мог запустить-мы его здесь обсуждали, потом поменял ТОР, и он сразу запустился.
Velgosh
Цитата(AS65 @ 15.1.2014, 11:28) *
Velgosh
Твои исходные данные:
На силовых кондёрах 310 есть,
на 6 ноге UC 6 вольт по мультиметру есть - возможно импульсы, бум считать что есть
если была бы постоянка то получили бы коротыш по питанию управы через ТГР.
Смотри греются или нет резисторы 200 Ом после ТГР,если тёплые смотри мультиметром
на затворах силовых транзисторов при наличии импульсов намеряем 6-8 вольт.
Если есть то косяк в силовых цепях если нет то ТГР и драйвера.
ребята перемотал ТГР, включил без силовой, на затворах появилось по 2,3в, ета нормольно? подключаять 300в?
Wasiliy61
А как себя чувствуют резаки по 200ом.
Velgosh
негреютса
Wasiliy61
Цитата(Velgosh @ 17.1.2014, 23:52) *
негреютса
Не порядок, они должны быть сильно тёплые, или слегка горячинькие, посмотри напряжение на 1ой ноге микры, при вращении задатчика-напряжение должно менятся примерно от2 до 5и вольт.
Velgosh
Цитата(Wasiliy61 @ 17.1.2014, 19:02) *
Не порядок, они должны быть сильно тёплые, или слегка горячинькие.
может на дольше включить? я в ключал толька на несколько сек
Wasiliy61
Да конечно, хотя 3-5мин.
владимирон
нашел еще кольцо м2000нм1-36 наружный диаметр 31 внутр 18 толщина 7мм может его применить здесь хоть марка известна кому не внапряг можете расчитать в програме. спасибо.
Velgosh
перемерял 3845:
1- 1,7-4,3в
2 - 2,5в
3 - 0в
4 - 1,9в
6 - 6в
7 - 14в
8 - 5в
после 2-3 мин вроде чуть теплее стал, но трудно сказать
так что скажете? зпускать полностю? жалко транзюки палить
владимирон
размер феррита можно узнать
sergey777.68
на плате написано icon_biggrin.gifзазор 0.3
Velgosh
Цитата(KT117 @ 14.1.2014, 19:46) *
Если на выходе нет напряжения-не открываются ключи. ( При условии, что все детали исправны, нет косяков в пайке и плата разведена верно). Значит не работает ШИМ, или ТГР. Без осцилографа тяжело будет запустить.
ПыСы. Посмотрите напряжение на З-Э транзистора, должно быть примерно 10В. Если нету-смотреть ТГР и ШИм. Может термореле выключено icon_smile.gif
а если там 2,3в?
Wasiliy61
Цитата(Velgosh @ 18.1.2014, 1:48) *
а если там 2,3в?
Этого мало, при таком напряжении ключики посто чуть-чуть приоткроются -и получится БАХ.
Сейчас померил для интереса- прибор показал 10,2 вольта.
Velgosh
а в чем может быть проблема?
Wasiliy61
В обвязке микры у тебя всё верно, напряжения совпадают, ищи дальше.
KT117
Если на 6 ноге есть генерация-проблема в ТГР и обвязке. Проверьте транзистор раскачки ТГР, размагничивающий диод
Если имеется частотомер( можно и самодельный) проверьте частоту на 6 ноге уски. Если номиналы как на схеме-у вас будет частота 34кГц (правда и заполнение 47%-лучше убавить)
Wasiliy61
Проверь какае напряжение после IRF, на 1 обмотке ТГР относительно массы ,должно быть практически напряжение питания.
Velgosh
после IRF, на 1 обмотке ТГР относительно массы - 14в
ребята может дело в количестве витков в обмотках ТГР, я мотал как написано (35 витков проводом от витой пары)?
а з размагничивающим диодом что может быть?
slavyann
перепроверь, у тебя первичка ТГР точно включена как на схеме ? т.е. начало одной половины с концом другой ?
и вторички относительно первички правильно сфазированы ? ? ?
пробой, обрыв
KT117
А с диодом все что угодно может быть. От обрыва, до неправильного номинала.
С осликом давно бы уже было ясно-кто виноват и где. А так гадание будет долго продолжаться
DJPashA
Подскажите пожалуйста. Такие вот осциллы получаются. В чём может быть причина. Всё снято при 5мкс/кл, через 1/10(кроме З-Э).
Павел(Sp)
Прибор Гумерова-Зуева в массы!!!
Народ HELP!!!
Никак не победю чертов прибор....
вместо нелинейного нарастания тока полка на вершине импульса растет...
шоб попроще калькулировать было влепил измерительный резистор 1ом,вот типа такого получается....
RadioГубитель
Транзистор не слабоват? Очень похоже на насыщение сток-исток транзистора...
Павел(Sp)
Респект!
транзистор поставил 12N60 другого без диода не было..
проверил сейчас тестером а у него G-E звонятся где-то 800ом..
Поменял на какойто задрипаный IGBT 26nm60,он правда с защитным диодом, не знаю как это отразится на работе прибора,
тут вот написано что должОн быт без диода.
Jorg63
Цитата(Павел(Sp) @ 18.1.2014, 17:44) *
Респект!
Тот что указан транзюк в схеме с защитным диодом уже. Наличие отсутствие диода тут погоды не делает.12N60,если это мосфет а не ИЖБИТ тоже с диодом,но у него большое сопротивление канала,ну очень хорошая печка будет.
Павел(Sp)
Да уж обратил внимание на глобальное потепление..
поменял на irfp264,этот вроде лучче усех,пробовал разные: g4ph40u,80n60,gp4068d.....
владимирон
нашел еще кольцо м2000нм1-36 наружный диаметр 31 внутр 18 толщина 7мм может его применить здесь хоть марка известна кому не внапряг можете расчитать в програме. спасибо. помогите кто чем может
Jorg63
Если только для умножалки кольцо пригодиться-хотя последняя нужна как зайцу стоп-сигнал
владимирон
а что вы хотите сказать что на кольцах не мотают трансформаторы ?
Jorg63
для сварника этого сечения мало,для блока питания до ватт 200-300 думаю вполне хватит для двухтакта
владимирон
Цитата(Jorg63 @ 18.1.2014, 20:25) *
для сварника этого сечения мало,для блока питания до ватт 600-700 думаю вполне хватит
от него надо 14 вольт 1 ампер и 2 по 15 вольт 100 ма на оптику
Jorg63
Можно куда больше мощи.Но колечко,если обратноход делать питатель желательно разломать и потом склеить,сделав зазор. Проще взять от комповых блоков питания транс и намотать на нем транс блока питания
