Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
DANTIST
Цитата(VOVA 555 @ 6.1.2014, 18:20) *
Греетса она от того у вас что вы не придерживаетесь соотношения епоксидбки и отвердителя заявленую прозводиелем . Неправильно ее розводите . А та что на фото нормально себя видет . Самый лучший вариант дозировки клея и отвердителя ето с помочю шприцов медецынских (стабилное время отвержения ). Все вышеше сказаное лиш мое ИМХО .
VOVA, может тебе проще писать українською? А то так ты напоминаешь Мыколу Янковича. icon_biggrin.gif
satinstaller
Цитата(Павел(Sp) @ 6.1.2014, 18:51) *
И чем можно ускорить отвердевание епоксидной смолы?Есть кроме катализатора еще и ускоритель.Но тут я спрашивал на фирме одной что клеями и всякой ботвой подобного типа занимается, они слышали, как говорится но не видели.Я каркас лепил для транса, так то прямо роды.....на етикетке написано 2 часа затвердевание... ага ....
Тута в китайских (извините...) магазинчиках продают ускоренную,только там 5гр смолы, чтоб транс залить неделю работать надо....
Спешка нужна только в двух случаях, причем ни один из них к сварочникам отношения не имеет.
Смолу смешивать надо правильно и тщательно.
Мало отвердителя - твердеет дольше и хуже, если переборщили с ним- смола твердеет быстрее, но потом она хрупкая, как стекло.
За два часа своей прочности она не наберет никак, можете не стараться.
Обычно, из своего опыта работы с ней, -залитую деталь беру в руки на следующий день, а прочности и твердости эта деталь набирает еще в течении суток-двух. Вот тогда смола уже становится как камень.
Импортную смолу пользовал, разницы не заметил, продукт попался качественный, но отвердитель уж больно вонючий был, заливал ею катушки металоискателей.
Павел(Sp)
точно эпоксидка была или полиэстэр,этот уж воняет так воняет-качественно,но отвердевает в зависимости сколько дашь отвердителя, иногда считанные минуты..
DJPashA
Греется точно не от пропорций. Пропорции делаю примерно правильные. Греется от количества и перемешивания. Тут 100%, наэксперементировался тут как-то из-за частых "попаданий" на всю оставщуюся. Каких только не покупал. Такую как на фотке прям берите и мешайте и нагреется (и МОНО +100 - объём её и расположение или даже "растянутость" её чтоли по посудине решают) и можете проверить - пока не затвердела мешаешь её - греет, оставляет - остывает, и так сколько угодно пока не застынет. На счёт пропорций кстати - пробовал (спецом 10000ХХХ раз эксп-нта ради) и больше отвердителя и меньше, причём как не сильно так и вообще с нарушением всех предписаний произ-ля - не знаю как в плане прочности потом, но по нагреву и затвердеванию никакой заметной разницы вроде не замечено. Но эт уже имха , т. е. только мои личные наблюдения, тут мож у кого и подругому. В плане особой прочности не интересовался - клею каркасы из текстолита или типтого. А вообще - "где не держит проволока, там болту делать нех.й" icon_smile.gif а вы клей какой-то icon_smile.gif
Wasiliy61
Ребята, если уж зашёл разговор об обоксидной смоле, то спрошу тоже: однажды я сделал замес-всё по норме, она сохла 2ое суток, так и не застыла-всё была какая-то липкая, с тех пор всегда отвердителя добавляю больше нормы, в результате смола всегда остаётся, а отвердитель заканчивается.
nikon
Про эпоксидку забыл как про страшный сон, использую это Нажмите для просмотра прикрепленного файла средство для ремонта бамперов автомобилей, тот же блин только с другим отвердителем, чуть переборщил и не успеешь клей нанести. И берегите пальчики от ожога, это в случае передозировки отвердителя.
Wasiliy61
Цитата(nikon @ 7.1.2014, 11:41) *
Про эбоксидку забыл как про страшный сон, использую это средство для ремонта бамперов автомобилей, тот же блин только с другим отвердителем, чуть переборщил и не успеешь клей нанести. И берегите пальчики от ожога, это в случае передозировки отвердителя.
Во, блин здорово, надо взять на заметку.
DJPashA
Надо мешать. Если без подогрева, минут 15-20 - баночка должна начать постепенно теплеть, до того не наносить. А вообще, ты прям по живому icon_smile.gif -- уж я её посмывал, пока не разобрался чё как.
Интересно. Надо попробовать.
ingener99
Правильно замешанная эпоксидка никак не греется вообще. Давеча пришлось готовить большое количество - как раз целая баночка смолы + весь отвердитель из заводской новой упаковки, через сутки была чуть эластичной, еще через сутки окончательно твердая
Ной
Не плохо было бы все рекомендации отправить вКаво-Чаво.
mono
Если надо чтоб застыло быстро то можно использовать полиэфирную смолу, та становиться от количества отвердителя, перелить если - станет за минуту.
Павел(Sp)
Подробней можно?Здается мне что она тут это называют полиэстэром..абсолютно прозрачная и с резким смрадом...?
maxx
Просматривал файлы и наткнулся на полезный документ по эпоксидным смолам и компаундам
Павел(Sp)
Уважаемый Гиратор, типО через А пишется,это раз.
И когда у меня возникнет потребность в Вашем совете, я непременно у Вас спрошу,-это два.
И с чего Вы думаете что русский должен быть родным для всех.
slavyann
бедный гираторр, отовсюду его гонють, на паяльнике вообще войну объявили icon_biggrin.gif
Д713
Цитата(igorka @ 4.1.2014, 12:06) *
Я не заметил в нем , звездной болезни.
там не звездная болезнь..
там болезнь беззвездная..
mono
Почему полиэфирную смолу так называют здесь я не знаю, она разная бывает и с резким смрадом тоже, но в продаже она именно как полиэфирная.
TSL2
Ещё 18 страниц обсуждений про полиэфирную смолу и ёбокситку, и о чудо, форум наконец-то закончится moderator.gif
В девятой части, если она будет, будем обсуждать наверное крутелку для тока со стразами, и в какой цвет покрасить ножки, ну типа чтоб они коллорировали со цветом сетевого шнура help.gif
AS65
icon_biggrin.gif зачёт icon_biggrin.gif .
Nikolay1
владимирон
И тут Остапа понесло.
вот заложил на стапеля пока блок питания но без силовых кондеров
AS65
Мосты диодные видимо.
владимирон
Цитата(Serega30 @ 9.1.2014, 18:41) *
Это че же там такое такими болтищами М6 прикручено если не секрет?
катнул резьбу М6 в мосту и прикрутил довольно удобно получилось
mono
Цитата(TSL2 @ 9.1.2014, 17:04) *
Не хвалюсь, вот-так выглядит транс в скафандре из скотча. И мазюкать всякой херьнёй даже не собираюсь.
И правильно, скотч сам отвалится через несколько лет от нагрева, но если на продажу, то даже выгодно.
Никого не слушайте, а делайте, как душа велит, двойной запас никому не помешает.
Wasiliy61
Да может оно и так ни чего, но я все трансы обмазываю эпоксидкой, уже знаешь что от вибрации витки не будут терется друг о друга, и не нарушат изоляцию, и на душе спокойно- уже не переживаешь за него.
ingener99
А зеленая керамическая индуктивность это что? Выходной дроссель?
http://www.electrik.org/forum/index.php?ac...st&id=30459
oleg1ma
это общий снаббер, к толяну загляните.
Nikolay1
всю эту дисскуссию спровоцировал некий павел(сп). Я вот не понимаю одно, если человек незнает как приготовит эбоксидку и других элементарных радиолюбителских приемов то накуй он взялся за инвертором? Вскорее его не само форум интересует а только категория типа =VIP= тоесть его интересует только количество дурацких сообщение. Например вон Василий61 задавая одни только вопросов стал герой "СПЕЦИАЛИСТ"ом, смещно конешно...
владимирон
Ну не можешь сам сделать, посмотри как делают другие
Я то как раз могу сделать сам. конечно не ахти по внутреннему дизайну а так абсолютно рабочие аппараты получаются внешняя оболочка все скроет
я так думаю аппарат делается для проведения сварочных работ а не для выставки в противном случаи корпус надо делать прозрачным .
satinstaller
Всё, закончил "малыша".
Решил сильно мелкими формами не заморачиваться, плату малыша воткнул вертикально в такой вот коробочек, получился легкий и удобный аппаратик, пригодный для ношения, вожения в машине и для всякой мобильной работы.
Строго не судите, за магазинным видом не гнался, делалось для работы, а не на выставку.
slavyann
ну что, красота icon_smile.gif, где алюминия столько набрали ?
Павел(Sp)
Ну зачем так???... Я такую же спецательно 3,5 тыщы километров вез,кстати очень круто получилось- в стиле ретро. icon_mrgreen.gif
Уважаемый Николай Н-й.
Я не некий, я вполне определенный, у меня есть пол, возраст и фотка в профиле........
Я не гонюсь за количеством ,,дурацких,, сообщений.
Статус Vip мне нужен как тут человек подсказывал .. как ручник к сварочнику..(читай: рыбе зонтик, попу гармошка,мертвому кадило и тд.)
Если б не было так геморно , я б для таких как Вы уважаемый кажный день бы регистрировался, да вот беда, мне иногда и 15 минут не выпадает чтоб хоть почитать... если есть что почитать на форуме.
А форум ,как тут до меня говаривали и существует для того чтоб на вопросы иногда даже и дурацкие получить ответ который к великой Истине выведет.
А если зрить в корень то вон, мой пост где я осцилки вешал последние скоро мхом поростет,а в ответ тишина...
....он вчера не вернулся из боя-а-а-а....
А статус Vip у меня есть на другом форуме.
А вообще-то чего это я...как говорится: молчи глухой и от греха подальше...
TSL2
Во во. ingener99 тоже специалист, а мощный проволочный резистор видит впервые. А рядом по фото намотан сам дроссель, но он привык, что дроссель мотается только на кольцах. Ну век живи, век учись. Хотя для специалиста это.........
Ставил такие пока были в наличии. В последнем аппарате стоят импортные прямоугольные керамические.
Wasiliy61
Да я не гонюсь за фишками,я от них богаче не стал. Да когда я делал 1ый аппарат- распросов было много, я просто долго не занимался, и надо было войти вкурс дела. Зато я не сжёг ни одного ключа, спасибо ребятам с форума, что разжевали. После этого первого- я сделал несколько аппаротов, кое что я выставлял, А ВЫ уважаемый, однако просто язык чешете- а поделок твоих не видно. Выстави, и люди оценят, а языком легко трепать, он без костей.
ingener99
Цитата(TSL2 @ 10.1.2014, 5:27) *
Во во. ingener99 тоже специалист, а мощный проволочный резистор видит впервые... привык, что дроссель мотается только на кольцах.
Нет, встречались дроссели не только на кольцах, но и на тороидальных сердечниках, это Вы зря...
Serega30
Мой конструктив. Готовность около 60%. Спичечный коробок(для сравнения размеров) лежит на месте выходного дросселя.
DANTIST
...Строго не судите, за магазинным видом не гнался, делалось для работы, а не на выставку.
Красиво получилось. Очень аккуратная работа.
Есть пару замечаний, как на мой взляд.
Я бы несколько раздвинул байонеты. Мне кажется, не очень удобно подключать сварные концы.
И вот этот компьютерный сетевой разъем... Не настолько уж он там крепко сидит. Как бы не выскочил в самый неподходящий момент. Все-таки сварочник - это не стационарное устройство, как системник. Да и жилы в этом кабеле не очень...
Цитата(Serega30 @ 10.1.2014, 7:28) *
Мой конструктив. Готовность около 60%. Спичечный коробок(для сравнения размеров) лежыт на месте выходного дросселя.
Шутка, повторенная дважды, становится понятнее...
Serega, ты не знаешь, как править сообщение?
Спички, я так понимаю, дугу зажигать?
А жи и ши, пишется с буквой "и". А не так, как тебе слышится!
truevoxdei
А с каких пор образно "кольцо" не тождественно "тороидальный" сердечник? А то это "но" как бы говорит об обратном.
satinstaller
Байонеты раздвинуть не могу, внутри все собрано на "раме" из уголков от телевизионных шасси(от советских телевизоров, если что - на аппарате можно сидеть icon_biggrin.gif ), впереди (за передней алюмишкой)эти уголки стоят так, что по ширине между ними влезает два байонета впритык и все.
Да и байонеты по току пришлось купить здоровые, мелких в продаже у того продавца на тот момент не оказалось.
covex
Всем привет, собираю дешевый липинский на кольце R55х32х18. и ТГР.
Хочу снять 120-140А, на выходе 1+2 диода STTH60W03, ключи STGW45HF60WD.
Дроссель на альсифере 2 х К55х32х11 13 витков.
Имеет смысл поднятие частоты до 50-60 кгц, кто пробовал и к чему это привело?
Или такую частоту лучше использовать в паре с оптикой, т.к форма сигналов будет не очень хорошей и будем иметь потери на переключении? Хотя позже сам посмотрю осцилки.
Павел(Sp)
Просветите по поводу колечка а то у меня с английским как то в жизни не сложилось.....
http://www.mantech.co.za/ProductInfo.aspx?Item=14M5520
Павел(Sp)
Цитата(Wasiliy61 @ 11.1.2014, 17:03) *
Памятка ТОРОИДАЛЬНОМ магнитопроводе, СУПЕР-MSS(MS) МАТЕРИАЛ, ПРОНИЦАЕМОСТЬ=60u,
Внешний ДИАМЕТР=47.63, внутренний ДИАМЕТР=23.32, ШИРИНА=18.92
спаибо, Vasiliy, только это все я понял, наверное правильней спросить 60u это сколько ? т.к. проницаемость 1000-2000..... а 60u сколько будет на наши как говорится?а то сегодня нарыл это и 2 поменьше, 2,50 за кг, все равно когда нибудь на что то да сгодится..и что такое super-MSS(MS) MATERIAL
Павел(Sp)
Цитата(gyrator @ 11.1.2014, 17:29) *
Дык, альсифер это, ежели по-русски. Проницаемость= шидьсят.
Спасибо.
mono
Цитата(satinstaller @ 9.1.2014, 19:15) *
Строго не судите,
Советую проверить разъём 220 вольт, последние китайские идут стальные, а не цветные, ну и подводящие провода минимум 1.5 квадрата, если малыш на 100А.
Velgosh
Всем здрасте, на конец полностю собрал инвертор, все сделал как здесь http://radioskot.ru/publ/svarochnyj_invert...malej/1-1-0-632, все детали, трансформатори, дросель - все точно как там. Включил - дыму, выстрелов и прочей всякой срани не было, транзисторы и диоды холодные, но на выходе получил 0вольт, сварка не работает icon_sad.gif . Включал через лампочку 100вт, лампочка не засветилась, вентыляторы крутятса, блок питания выдает 14 вольт, на 6-ой ноге 3845 - есть 6 вольт. Может кто подскажет в чем может бить проблема, осцылографа у меня нету, так что я в полном тупике icon_sad.gif icon_sad.gif
sergey777.68
если это первый тупик на твоём пути сделай фото аппарата и жди помощи. icon_biggrin.gif
KT117
Если на выходе нет напряжения-не открываются ключи. ( При условии, что все детали исправны, нет косяков в пайке и плата разведена верно). Значит не работает ШИМ, или ТГР. Без осцилографа тяжело будет запустить.
ПыСы. Посмотрите напряжение на З-Э транзистора, должно быть примерно 10В. Если нету-смотреть ТГР и ШИм. Может термореле выключено icon_smile.gif
Wasiliy61
Ребята, а ВЫ помните-у нас на форуме кто-то собирал без ослика аппарат, вроди даже запустил. Конечно дальнейшая судьба аппарата нам не известна.
KT117
Можно конечно запустить и без ослика. Но нужно быть уверенным на 120% в исправности всех деталей и качестве монтажа.
