Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
OlegarX-RUS
Впаянный тоже не выдержал.
Подтверждаю!
Предохранитель на 30А горит при условии что украинский автомат на 25А даже не выключается.
Д713
Цитата(OlegarX-RUS @ 13.9.2010, 12:00) *
Подтверждаю!
а автомат и не должен отключаться,на базаре в основном С25,а что это значит можно посмотреть тут-
http://electro.narod.ru/information/automat_type.htm
на предохранителях какая-нить маркировка у вас есть?
Алекс_Н
Уважаемые гуру, зайдите, пожалуйста в ликбез. Я начал стоить СПАРК 1600 от Дантиста и Голуба, есть проблемки...
Dedan
Цитата(KLIM @ 11.9.2010, 23:27) *
Дык не зубник он, скорее всего электронику на самолеты поехали ставить, или учиться, но не зубы мастерить - это точно!
Ребят - у кого есть фото фирменных HGTG30N60A4D? Поидее перемаркер приехал. Поставил их вместо 50B60PD1 - ровно в два раза хуже... по даташиту должно быть точно наоборот.
Из моих запасов. Фотку специально сделал с большим разрешением. У Фаершилд лазером написано.
tigroff
у меня F20A, ширпотреб, обычная стекляшка с проволочкой. пробовал ставить с плоской вставкой - горит еще быстрее.
kyzmi4
А у меня вообще напрямую,без предохранителей.Только автомат.
Надоело мне ,что они горят все время.(я про стеклянные на 20А)
Д713
на предохранители имеется 2 стандарта,по долговременной работе и по току прерывания.
в китайских стандарт мне не известен.
буковка F не предназначена для импульсных цепей.
немаловажное значение имеет сопротивление плавкой вставки.
KLIM
Сфотал свои... определился уже что перемаркер.
Д713
интересно,что является заготовками под перемаркер?
RUS5610
У китайцев надо спросить.
толян
у меня пара попалась irfp460 , пара вообще что-то низковольтное . с тех пор сделал стенд - смотрю v K E при токе порядка 20 ампер , при быстром отборе по парам хватает 10-12 ампер .
Д713
теперь всё на зуб надо проверять что ли?
толян,колись на стенд..
RCH
В догонку привожу фото 100% оригиналов
HGTG30N60A4D
511
Добрый день. Если у кого есть фото оригинальных SGH80N60, выложите, пожалуйста, чтобы не пролететь при покупке.
Konstantin65
Сегодня вот тоже прикупил парочку SGH80N60UFD,также интересует мнение знатоков - фуфел или нет?Нажмите для просмотра прикрепленного файла
Ядерщик
У меня есть один глупый вопрос. Почему снабберы всегда рисуют так, что анод снабберного диода соединен с эмиттером транзистора. Ведь лучше соединять катод снабберного диода с коллектором транзистора, а к эмиттеру подключать конденсатор. Это позволит ставить и диод, и транзистор на один радиатор без всяких изолирующих прокладок.
RUS5610
30N60- сколько ампер при 25грд и 100грд?
ostap
HGTG30N60A4D
Collector to Emitter Voltage. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .BVCES 600V
Collector Current Continuous
At TC = 25oC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .IC25 75A
At TC = 110oC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .IC110 60A
Collector Current Pulsed (Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ICM 240A
Ядерщик
Да, вопрос был глупый. Просто перепутал полярность диода (схему в голове представлял)
вотеклмн
Уважаемые спецы обясните пожалуйста, а почему в схеме Дантиста нет диодов в снаберах которые паралльельно ключам. И нужно ли их ставить. Ведь везде они стоят
Lemm
если есть встроенные в транзисторы - то необязательно .
Д713
глубокомысленно..
golub
потому как клонировалась, не задумываясь, силовая, да и не только она, кольта. При 10 омах диод там без особой надобности.
KLIM
sarmat
Уважаемые, кого интересуют диоды в параллель ключам....у меня стоят ключи HGTG20N60A4 в Спарке Дантиста....параллельные диоды дополнительно не устанавливал....в этих ключах они тоже не встроены...Спарка уверенно проработала почти все знойное лето... заварил классные ворота двухстворчатые со встроенной калиткой (размеры ширина 4 метра, высота 2,5 метра)...несколько одинарных калиток...не считал разные мелочи для соседей...вывод-без диодов пашет...как-то писал, что срабатало тепло после 6 электродов....после этого по теплу ни разу не отключался....наверно Спарк обиделся на форумчан, за то что немного похаяли и решил показать характер....получил уже заказы на несколько аппаратов...заводским не доверяют...говорят ремонту не подлежать....хотя убеждал их, что многие ремонтируются....надо предварительно заглянуть во внутр перед покупкой....
Ко всему этому, почти у всех торгашей комплектацией, склады почти пустые....только на заказ, со всеми отсюда вытакающими ценовыми последствиями....наверно тоже на нашем форуме тусуются...изучают спрос
OlegarX-RUS
А что действительно со складами происходит???? В чём дело???
sarmat
Скорее всего таможня душит....поэтому не хотят завезти ничего лишнего...только под конкретный заказ
KLIM
Поставщик росийский оптовый, на котором скупляются Имрады Космодромы и т.д. обнуляет склады... зачем - незнаю, чтото они там переорганизовывают... Поэтому на рынке такая каша, и будет еще хуже и незнамо на сколько. Я вот напрямую лезу к производителям... за бугор. Причем в России тоже самое.
OlegarX-RUS
Печально!
golub
Цитата(KLIM @ 16.9.2010, 17:53) *
тостующий, вот вы и прокрутите в SwCad. Для тех ключей которые вам ДАНТИСТ посоветовал.
Д713
KLIM,ситуация обыкновенная-посадили на дешевую иглу,отключили,цену потом сами назовем..
KLIM
Достучался до америкосов - цена приятно порадовала, скажем так - раз в 5 ниже чем на Имраде, ну или в 2 раза чем у более спокойных поставщиков. Причем сказали - если работать по договору - можно поговорить о снижении цены. Остальную рассыпуху будет с Китая или Тайвани заказывать (шоб не здохнуть) и выбирать лучшее (слава Богу есть из чего). Походу выдавливают мелких, несостоятельных производителей! Как говорится - решительный шаг вперед как правило результат хорошего пинка под зад!
Это 30N60 ? Я их не покажу, бо нет у меня их модели, но если на 4PC50W и зависимость с и без диода - никто не против?
yjriy
Ты должен решить проблему со службой доставки, потому как тебе в инвайс впишут ее цену и ты приятно порадуешь таможню. Выше 200 Евро будешь платить налог более 20%. Но при больших партиях, допустим несколько тысяч штук это вроде как и не очень ощутимо. Потом на форуме разошлешь и бабки отбьешь. Я и сам у тебя куплю их
Wiew
вотеклмн
Извините , но я так и не понял из всего сказанного выше
глубокомысленно..
Так нужно ставить или нет. Транзисторы иксусы без внутреннего диода- спарены по 2 штуки, транс Е70 и хочу чтобы не менее 150- 170 ампер отдавал. Радиаторы большие поставлю. Что с диодами? Ставить или нет при 10 Омах и емкости конденсатора 4700 пФ
golub
Нет
вотеклмн
спасиба Голуб за ответ
Levs
Цитата(Wiew @ 17.9.2010, 11:00) *
-"В очередь, сукины дети" (Шариков П.П. "Собачье сердце") icon_smile.gif icon_smile.gif
Сначала он будет всем рассылать, а со временем купит настольно-шлифовальный и лазерно-гравировальный станочки и .......
RUS5610
Мужики кто нибудь пробовал настраивать частоту под определенный сердечник и витки по минимальному потреблению тока на холостом ходу.Типа в разрыв питания от банок амперметр и крутить частоту.В двухтактниках это срабатывает.
kyzmi4
Кто знает, на какие номиналы нужно заменить резисторы в цепи контроля тока,чтоб 140Ампер получить.
Схема:
http://s51.radikal.ru/i133/1009/53/b49c5ef786c2.jpg
yjriy
Изменением нагрузочного резюкА в цепи ТТ
RUS5610
Увеличивай резюк ТТ упадет ток
kyzmi4
Мужики,спасибо!
sarmat
Мужики, как называется прозрачный клей, которым китайцы фиксируют что надо и не надо в аппаратуре?
kyzmi4
Он помоему продается в виде "палок" для клеевого пистолета.
spesso
Это который "китайские сопли"? Вот http://www.shtok.ru/-2/19001-80
KLIM
icon_wink.gif Всё я понял... проплатил... жду ответ. Чтото всё хуже и хуже у поставщиков, стрём берет!
OlegarX-RUS
Да шооо вы, це ж таможня лютуе. Пымборы ж на носу. Уплюдки в очередь на пымборы пошли (уроды безголовые!)
Надо партию сваркостроителей срочно создавать и достойную кандидатуру на президентский пост снарядить!!!
KLIM
По ходу все ждут принятия нового налогового кодекса. Со знакомыми говорил - вешаются... проверки заколебали, в очередь выстраиваются... Если так и дальше - по подвалам будут прятаться....
RUN1
[quote name='KLIM' date='13.9.2010, 18:36' post='149053']
Клим приветствую!Блин я точно таки же взял как у тебя на фотках и что теперь делать как узнать то на что они способны?(((Вот бля засада с этими китаезами !!!!!! да дело дрянь и еще почти по 10 уев за штуку
